- 22. Feb. 2018
oder weil @Hagen2000 eine DS725+ hat? Das würde wiederum die Aussage von @DaveR untermauern.
/usr/libexec/syno-update-settings --set-autoupdatetype-notify but maybe I didn't run the command.
DSM 7.2.2 - 2025 models
DSM 7.3 - All models
Disable DSM Auto Updates
Removes schedule setting in Control Panel > DSM Update > Settings
/usr/syno/etc/update.conf
{"autoupdate_type":"notify","smart_nano_enabled":true}
Enable DSM Auto Updates
Restores schedule setting in Control Panel > DSM Update > Settings
{"autoupdate_type":"hotfix-security","smart_nano_enabled":true}
Disable Package Center Auto Updates
Shows "Disable auto-update" option in Package Center > Setting > Auto-update
/etc/synoinfo.conf
show_autoupdatetype_notify="yes"
Enable Package Center Auto Updates
Removes "Disable auto-update" option in Package Center > Setting > Auto-update
/etc/synoinfo.conf
show_autoupdatetype_notify="no"
Disable Package Center Auto Updates and DSM Auto Updates
sudo /usr/libexec/syno-update-settings --set-autoupdatetype-notify
Enable Package Center Auto Updates and DSM Auto Updates
sudo /usr/libexec/syno-update-settings --unset-autoupdatetype-notify
show_autoupdatetype_notify="no"show_autoupdatetype_notify="yes"show_autoupdatetype_notify="no"show_autoupdatetype_notify="no"Probably another measure to patronize the user.Only the 2025 models haveshow_autoupdatetype_notify="no"
{"autoupdate_type":"notify","smart_nano_enabled":true}{"autoupdate_type":"hotfix-security","smart_nano_enabled":true}sudo synosetkeyvalue /etc/synoinfo.conf show_autoupdatetype_notify yessudo synosetkeyvalue /etc/synoinfo.conf show_autoupdatetype_notify no
)sudo /usr/libexec/syno-update-settings --set-autoupdatetype-notifysudo /usr/libexec/syno-update-settings --unset-autoupdatetype-notifyWenn du das Forum hilfreich findest oder uns unterstützen möchtest, dann gib uns doch einfach einen Kaffee aus.
