Synology Photos Synology Photos Mobile: Neue Version: 2.2.0-556
Kachelkaiser
22. Feb. 2018
Version: 2.2.0-556​
(2025-01-06)
Important Note​
  1. The version is expected to be available in all regions within the next few days. The actual time of release may vary slightly depending on the region.
What's New​
  1. Supports adding photo widgets to the home screen to shuffle photos from throwbacks or selected albums.
  2. Supports filtering items by folder, file size, or date taken before deleting files to free up space.
  3. Supports shuffling and speed adjustment in slideshow mode.
  4. Supports editing taken date and time of items.
  5. Supports pinch-to-zoom during video playback.
  6. Supports three options when re-enabling Photo Backup: scan and back up all photos, resume the previous task, and back up new photos only.
Bug Fixed​
  1. Fixed an issue where items that have local copies might not be downloaded to the phone.
  2. Fixed an issue where the mobile app might crash when browsing items.
  3. Fixed an issue where some backed-up items were not marked as deletable in the Free Up Space feature.
  4. Fixed an issue where the mobile app might crash when viewing a large GIF file in certain photo models.
  5. Fixed an issue where items were backed up again even after being deleted from the mobile app.
  6. Fixed an issue where edited items might not be backed up.
  7. Fixed an issue that caused the Synology NAS to wake unexpectedly when no backup tasks were running.
  8. Fixed an issue where items on SD cards might not be deleted simultaneously when removed through the mobile app.
  9. Enhanced the efficiency of backup in the background.
  10. Fixed an issue where uploading items via third-party apps might not be successful.
Interessant könnten die Throwback-Widgets und auch die Steuerung der Speicherplatzfreigabe sein.
siehe auch: https://community.synology.com/enu/forum/1/post/191059
Jetzt dachte ich, dass ich eine ältere Version hätte... Musste aber dann doch feststellen, dass ich die Version seit zwei Wochen im Einsatz habe.
Insofern kurzes Feedback: Läuft stabil. Die Widgets sind nett, aber nutze ich nicht. Mit der Speicherplatzfreigabe habe ich noch nicht experimentiert.
ja habe das heute auch erst entdeckt, als ich die App aufgerufen habe. Da kam dann kurz ein Hinweis auf die Widgets.
Bei mir das gleiche......
hab mir jetzt aufgrund der Beschreibung so ein Widget eingerichtet....
Find ich (noch) super.
Grüße
Reaktionen: dil88
Bei mir schon ab 14ten Januar drauf. für den freigebenen Speicherplatz gibt es nun, wählbar, Vorschau für die zu löschenden Medien. Die Widgets sind leider zweireihig, passt nicht mehr aufn Homescreen. brauch ich aufgrund der Beschreibung auch nicht wirklich.
Ich schwanke immer noch zwischen Immich und Synology Photos, arggghhh
Wie kann man bei einem Androiden die Widget Einstellungen ändern?
Schaffe es nicht.....
Bei meinem Galaxy A52s einfach lange auf das Widget drücken und dann kommt ein kleines Menü mit Einstellmöglichkeit
Reaktionen: niklas
Ich habe Immich längst verworfen.
Allerdings nutze ich auch Synology Photos auch nicht wirklich.
Ich habe da seit langem mein eigenes Archiv zusammengestellt, was gut über DLNA am TV funktioniert.
Himm dann ist das wohl ein Samsung ding. Zur Not entfernen und neu hinzufügen
Reaktionen: niklas
Hallp zusammen,
Leider habe ich seit kurzem das Problem, dass in der Synology Photo App meine Bilder nicht mehr in der Karte (Album->Ortr) angezeigt werden. Gibt es dafür eine Lösung?
Lg
Ich nutze beide. In der Hauptsächlichkeit Synology Photos und parallel Immich. Während Immich als App geschlossen sein kann und alles hochläd, ist die Syno-App da leider unzuverlässig. Nur wenn die App dauerhaft im Hintergrund läuft, wird hochgeladen. Trotzdem unter Akku "nicht eingeschränkt" gesetzt ist.
Ich habe jetzt mal Photos wieder aktiviert, schau mer mal.
Reaktionen: ElaCorp
moin, die Version 2.2.0-556 scheint nur die Android Version zu sein. Meine iOS Version ist bei 2.2.0-528, vom 7.Januar, es ist keine aktuellere verfügbar. Diese kann aber schon Widgets, Speicherplatz angepasst freigeben usw...
Reaktionen: Kachelkaiser
Brauch mal das geballte Schwarmwissen, da ich in der Hilfe nichts gefunden habe.
Habe heute in der Monatsansicht verschiedene kleine weiße Symbole links unten im Vorschaubild gefunden. Leider sind sie beim erneuten Schauen weg gewesen. War ne Wolke, ein weiser gestrichelter Kreis und Pfeile - glaube ich.
Kennt ihr die oder gibt's dazu eine Beschreibung?
Nein, kenne ich so nicht.
  • Sad
Reaktionen: c0smo
Meines Wissens ist der "gesteichelte Kreis mit einem upload-pfeil" während des Uploads zu sehen und anschließend eine Wolke mit einem pfeil drinnen kurz danach zu sehen. (Sozusagen die zuletzt hinzugefügten), beim nächsten Mal sind die Icons weg
