DSM 6.x und darunter Updates für DSM7 und DSM6
AndiHeitzer
30. Juni 2015
Das IT-Blog 'Caschys Blog' hat über die Updates berichtet:
https://stadt-bremerhaven.de/synology-updates-fuer-den-diskstation-manager-6-und-7/
Es täte geben ...
DSM 7.0.1-42218 Update 1
DSM 6.2.4-25556 Update 3
Im Download bei Syno (https://archive.synology.com/download/Os/DSM) ist noch nicht alles angekommen, das Update für DSM7 fehlt noch.
Auf meiner virtuellen DSM6 Kiste läuft das 6.2.4-25556-3 unauffällig und konnte ohne Reboot eingebracht werden.
Edit meint:
https://www.synology.com/de-de/releaseNote/DSM?model=DS0918
DSM7 (2022-01-11)
Important Note
  1. Your Synology NAS may not notify you of this DSM update because of the following reasons. If you want to update your DSM to this version now, please click here to manually update it. Only Synology NAS with DSM 7.0.1 installed can be updated to this version.
    • The update is not available in your region yet. The update is expected to be available for all regions within the next few days, although the time of release in each region may vary slightly.
  2. This update will restart your Synology NAS.
Fixed Issues
  1. Fixed an issue where package logs weren't rotated after a switchover was performed on SA3200D.
  2. Fixed an issue where Synology Account might be signed out unexpectedly.
  3. Fixed an issue where the user interface response time might be longer when users ran user-defined scripts that included bind mounts.
  4. Fixed an issue where the time attribute of files on an exFAT-formatted external storage device was displayed incorrectly.
  5. Fixed an issue where there might be unexpected file permission changes in Surveillance Station due to multi-threaded file processing.
  6. Fixed an issue where SSD caches might stop functioning when there is insufficient system memory.
  7. Fixed an issue where mounting an encrypted shared folder on a Btrfs volume might fail.
  8. Fixed multiple security vulnerabilities. (Synology-SA-22:01)
DSM6 (2022-01-11)
Important Note
  1. Your Synology NAS may not notify you of this DSM update because of the following reasons. If you want to update your DSM to this version now, please click here to manually update it. Only Synology NAS with DSM 6.2.4 installed can be updated to this version.
Fixed Issues
  3. Updated the renewal rule of the built-in certificate to prevent DSM connection errors.
  4. Fixed an issue where users couldn't expand a RAID 1 storage pool on the active server in a Synology High Availability cluster when the active server's RAID 1 storage pool is smaller than the one on the passive server.
  5. Fixed multiple security vulnerabilities. (Synology-SA-22:01)
Gestern bereits das Update 1 auf DSM 7 installiert. Bisher keine Auffälligkeiten.
Woher konntest Du das U1 für DSM7 ziehen?
und wie lädst du die Datei herunter?
@AndiHeitzer also gestern sah das ungefähr so bei mir aus:
Bei 2 stand wiederum Update 1
welche version erhälst du dann?
Bin auf der Arbeit. Kann das hier leider nicht testen. Aber warum sollte es eine andere sein als in Release Notes?
Scheinbar wurde das U1 für DSM7 mal wieder zurückgezogen :unsure:
Reaktionen: mayo007
Gerade den Support angechattet. Der Support hat keine Ahnung, ob ein Update zurückgezogen wurde.
Dazu ist mir zumindest nichts bekannt. Ich würde Sie bitten, zu diesem Thema einmal ein Ticket zu erstellen unter https://account.synology.com, damit unser Expertenteam darüber schauen kann
:rolleyes:
Also bei mir hieß es zurückgezogen. Naja egal. Update ist nicht da und gut ist.
@Ulfhednir Das Expertenteam hat auch keine Ahnung, die wissen noch nicht mal, daß es ein Update geben soll. Hatte ein Ticket aufgemacht. :-)
  • Sad
Reaktionen: Ulfhednir
  1. This update has been recalled on January 12, since permission errors occur in the license files of packages.
Da findet sich nun der Grund für das Zurückziehen. Auch wenn es ärgerlich ist, dass der Support da keine Ahnung hatte, finde ich, dass die Transparenz doch gestiegen ist. Bei DSM 6 waren die Updates in der Regel einfach weg und plötzlich unter der gleichen Buildnummer, aber verändert, wieder da und es gab überhaupt keine Information zu Gründen.
Reaktionen: AndiHeitzer
