- Mitglied seit
- 30. Jun 2015
- Punkte für Reaktionen
- 509
Das IT-Blog 'Caschys Blog' hat über die Updates berichtet:
https://stadt-bremerhaven.de/synology-updates-fuer-den-diskstation-manager-6-und-7/
Es täte geben ...
DSM 7.0.1-42218 Update 1
DSM 6.2.4-25556 Update 3
Im Download bei Syno (https://archive.synology.com/download/Os/DSM) ist noch nicht alles angekommen, das Update für DSM7 fehlt noch.
Auf meiner virtuellen DSM6 Kiste läuft das 6.2.4-25556-3 unauffällig und konnte ohne Reboot eingebracht werden.
Edit meint:
https://www.synology.com/de-de/releaseNote/DSM?model=DS0918
DSM7 (2022-01-11)
Important Note
DSM6 (2022-01-11)
Important Note
Es täte geben ...
Edit meint:
DSM7 (2022-01-11)
Important Note
- Your Synology NAS may not notify you of this DSM update because of the following reasons. If you want to update your DSM to this version now, please click here to manually update it. Only Synology NAS with DSM 7.0.1 installed can be updated to this version.
- The update is not available in your region yet. The update is expected to be available for all regions within the next few days, although the time of release in each region may vary slightly.
- This update will restart your Synology NAS.
- Fixed an issue where package logs weren't rotated after a switchover was performed on SA3200D.
- Fixed an issue where Synology Account might be signed out unexpectedly.
- Fixed an issue where the user interface response time might be longer when users ran user-defined scripts that included bind mounts.
- Fixed an issue where the time attribute of files on an exFAT-formatted external storage device was displayed incorrectly.
- Fixed an issue where there might be unexpected file permission changes in Surveillance Station due to multi-threaded file processing.
- Fixed an issue where SSD caches might stop functioning when there is insufficient system memory.
- Fixed an issue where mounting an encrypted shared folder on a Btrfs volume might fail.
- Fixed multiple security vulnerabilities. (Synology-SA-22:01)
DSM6 (2022-01-11)
Important Note
- Your Synology NAS may not notify you of this DSM update because of the following reasons. If you want to update your DSM to this version now, please click here to manually update it. Only Synology NAS with DSM 6.2.4 installed can be updated to this version.
- Updated the renewal rule of the built-in certificate to prevent DSM connection errors.
- Fixed an issue where users couldn't expand a RAID 1 storage pool on the active server in a Synology High Availability cluster when the active server's RAID 1 storage pool is smaller than the one on the passive server.
