DSM 7.3 Neue Version 7.3.2 – 86009
luxdunkel
22. Mai 2023
Eine neue Version ist verfügbar, Release Notes sind noch nicht online.
Die 1621+ informierte mich über die Verfügbarkeit per E-Mail.
1621+, 720+ und 218+ ohne Probleme auf die neueste Version gebracht, ein paar Pakete wurden zusätzlich aktualisiert.
Version: 7.3.2-86009
(2025-12-02)
Important Note
After installing this update, you will not be able to downgrade to a previous DSM version.
This update will restart your Synology NAS.
If auto update does not run, perform a manual update in Control Panel. Before updating, follow the instructions and complete the required actions to ensure success.
To uphold our commitment to quality, every DSM release undergoes rigorous validation. To ensure optimal stability, the models listed below will not receive this update on your device and will remain on their most suitable version. You can only download the upgrade patch from Synology Download Center because you won't receive notifications for this update on your DSM.
FS Series: FS3017, FS2017, FS1018
XS Series: RS18016xs+, RS4017xs+, RS3617xs+, RS3617xs, RS3617RPxs, RS18017xs+, DS3617xs, DS3617xsII, DS3018xs
Plus Series: RS2416RP+, RS2416+, DS916+, DS716+II, DS716+, DS216+II, DS216+, DS1817+, DS1517+, RS2818RP+, RS2418RP+, RS2418+, RS818RP+, RS818+, DS1618+, DS918+, DS718+, DS218+, RS1219+
Value Series: DS116, DS216, DS216play, DS416, DS416play, DS1517, DS1817, DS418play, RS217, RS816
J Series: DS216j, DS416j, DS416slim, DS419slim, DS418j, DS218j, DS119j
Fixed Issues
Fixed an issue where backup files containing encrypted volumes might not function properly when restored to DSM 7.3.
Fixed an issue where users might be required to re-enter their license keys after updating to DSM 7.3 when migrating a system or operating in an SHA-enabled environment.
Fixed an issue where users could not authenticate using Approve sign-in or FIDO2-compliant hardware security keys before authorization in OAuth Service.
Fixed an issue where users might fail to authenticate when configuring SSO clients to use C2 Identity as the identity provider with the SAML protocol.
Fixed an issue where DSM might fail to send files from File Station as attachments when accounts were configured through Outlook.
Fixed an issue where notification profiles might be incorrect when restoring from configuration backup files.
Fixed an issue that prevented certain UPnP renderers from playing MP3 files after updating to DSM 7.3.
Fixed a security vulnerability.
Anmerkungen:
This version is released in a staged rollout.
Ich brauchte einen zweiten Neustart auf der DS920+ (DX517), da der NVME-SSD Speicherpool offline war, wegen nicht unterstützter NVME Module. Es lief wieder diese komische Paketaktualisierung (ich hatte vorher extra im Paketzentrum geschaut, es wurden keine Updates angeboten) während des Neustarts, welcher wohl das Ausführen des hdd_db Scripts verhindert.
Nach dem erneuten Neustart, läuft alles wie gewohnt.
Wurde mir auf der DS420+ sogar schon angeboten: Installiert, die üblichen Bereinigungen durchgeführt, läuft...
DS216+ II, DS720+, DS 923+ und DS2419+ ohne Probleme
Da hat es Synology ja eilig. Nicht nur ein Updatepack, sondern gleich als Vollupdate.
Und dann noch mit sofortigen Rollout - oder wir sind diesmal in Region 1 ;)
Bei mir ist noch nix da :-(. wird dann später manuell gemacht
Ich habe es auch manuell gemacht.
Natürlich, Pakete wurden angeboten, warum soll denn die
Neue Version 7.3.2 – 86009​
angeboten werden :LOL:❓
RS820RP+ und DS1621+ ohne Probleme manuell aktualisiert.
Vorsicht bei der Aktualisierung von Synology Photos auf 8.1.2-10090. Mir fiel auf, dass die DS1522+ seither wie verrückt rödelt. Das ist wohl die Personenerkennung, die erneut läuft, "~60.000 Fotos werden in Kürze erkannt ...". Inzwischen sind es noch 40.000. Das wird wohl noch eine ganze Zeit dauern und macht hoffentlich nichts kaputt. Bei einer leistungsschwächeren DS kann das durchaus tödlich sein.
Hmm habs auch heute morgen geupdatet. Bei mir passierte gar nix. Kein Rödeln und auch keine Anzeige.
Reaktionen: anmi4345
Mmh, sonderbar :unsure: Na ja, jetzt sind's noch 30.000 und am Bestand der bereits zugeordneten Personen ändert sich um Glück nichts.
Manuell installiert auf DS218 und DS723+, läuft alles.
Reaktionen: maxblank
Ist bei meiner 224+ auch problemlos durch. Allerdings ist Active Insight wieder installiert und sofort wieder runtergeflogen und der UDEV-Treiber brauchte wie immer auch einen Schubs.
Gruß... Atze
Folgende Meldung kommt bei der DS1621xs+ in Bezug auf "SynoCLI Disk Tools". Dies wird wohl bei diesem Paket immer der Fall sein, egal welches Synology-Modell.
_____________________________________________________________________________________________________________________________________________________________________________
Zwei NVMEs aus dem Speicherpool mit vier NVMEs im RAID5 (Synology Adapter) sind weg, Scripte laufen beim Hochfahren und Herunterfahren als Task durch. Deckt sich also mit dem, was @ctrlaltdelete bereits erwähnt hat.
Nach einem weiteren Neustart ist dann auch noch die Erweiterungseinheit weggeflogen - läuft!
Zwei Neustarts später und dem manuellen Ausführen aller benötigten Scripte, bin ich dann auch wieder am Start. :)
Zertifikat der DS1621xs+, auf welche ich die BeeStation sichere, war nach dem Update von DSM auch nicht mehr gültig.
Ob die Probleme eher im Update des Speicher- bzw. SAN-Managers begraben liegen anstatt am DSM-Update an sich?
Die hatte ich vor dem DSM-Update aktualisiert, allerdings nicht neu gestartet.
Und alle virtuellen Maschinen sind weg, großes Kino!
Fazit: Passt mit diesem Update auf, falls ihr virtuelle Maschinen auf NVMEs betreibt! Dabei spielt es auch keine Rolle, auf welchem Volume VMM installiert ist (in meinem Fall auf SATA-SSDs), die nicht betroffen waren. Vorher unbedingt die VM sichern bzw. exportieren. Diese sind in Hyper Backup nicht enthalten.
So, meine Personen-Indexierung ist durch. Keine erkennbaren Schäden(y)
Ich hab grad auch meine DS925+ upgedatet, in diesem Fall manuell, die hat sich halt noch nicht gemeldet. All die kleinen Anpssungen musste ich natürlich auch hier wieder aktivieren.
Ich hab keine Probleme feststellen können. Es laufen ABfB, Hyper Backup und Docker. Die LUN, die ich für die Raspi-Sicherung nutze, ist auch noch da und geht.
Eine Frage: stoppt ihr zur Sicherheit die Paket auf dem nvme - volume vorher?
Das macht, denke ich, keinen Unterschied. Also nein, mache ich nicht.
Wenn was schiefläuft oder die geupdatet werden, ist es egal, ob die vorher liefen oder nicht.
