die Syno war jetzt 20 min. ohne Netzwerkkabel.
login 1 ssh
Synology strongly advises you not to run commands as the root user, who has
the highest privileges on the system. Doing so may cause major damages
to the system. Please note that if you choose to proceed, all consequences are
at your own risk.
Could not chdir to home directory /var/services/homes/Chris: No such file or directory
Chris@fvdvvv:/$ sudo -i
Password:
root@fvdfvfd:~# find / -mount -cmin -5
/run
/var/lib/diskutil
/var/lib/diskutil/diskutil.conn-shm
/var/lib/diskutil/system
/var/lib/diskutil/diskutil.conn-wal
/var/log/partition.log
/var/log/router.log
/var/log/systemd/nginx.service.log
/var/log/iscsi.log
/var/log/kern.log
/var/log/synopkg.log
/var/log/bash_err.log
/var/log/synocrond.log
/var/log/synoscheduled.log
/var/log/synocontentextractd.log
/var/log/datascrubbing.log
/var/log/rm.log
/var/log/samba/log.nmbd
/var/log/synoinstall.log
/var/log/auth.log
/var/log/synosnmpcd.log
/var/log/messages
/var/log/scemd.log
/var/log/disk.log
/var/log/synofeasibilitycheck.log
/var/log/synosystemd.log
/var/log/synoplugin.log
/var/log/synoindex.log
/var/log/boot-time-detail.log
/var/log/space_operation.log
/var/log/postgresql.log
/var/log/systemd.log
/var/log/apparmor.log
/var/log/synoschedmulti.log
/var/log/synolog
/var/log/synolog/.SYNOCONNDB-shm
/var/log/synolog/.SYNOACCOUNTDB
/var/log/synolog/.SYNOSYSDB
/var/log/synolog/.SYNOCONNDB-wal
/var/log/synoscheduler.log
/var/log/nginx/error_default.log
/var/log/synoscgi.log
/var/log/synorelayd.log
/var/log/bash_history.log
/var/log/syslog.log
/var/tmp/.bash_history
/var/tmp/nginx/test/plugin_config/sites-enabled
/var/tmp/nginx/test/plugin_config/sites-enabled/synowstransfer-nginx.conf
/usr/local/packages/@appdata/SMBService/log/synowstransfer.log
/usr/local/etc/nginx/sites-enabled
/usr/local/etc/nginx/sites-enabled/synowstransfer-nginx.conf
/usr/local/etc/nginx/sites-available
/usr/local/etc/nginx/sites-available/bb4a52b7-5982-4737-86d7-9f649d3155c9.w3conf
/usr/syno/etc/synorelayd
/usr/syno/etc/synorelayd/services.conf
/usr/syno/etc/synorelayd/synorelayd.conf
/usr/syno/etc/synorelayd/env.conf
/usr/syno/etc/www
/usr/syno/etc/www/nginx_config.json
/etc
/etc/systemd/system/multi-user.target.wants
/etc/systemd/system/multi-user.target.wants/upnpd.service
/etc/resolv.conf
/etc/portforward
/etc/portforward/rule.conf
/etc/firewall_6_rules_security.dump
/etc/iproute2/rt_tables
/etc/iproute2/config
/etc/iproute2/config/gateway_v4_priority
/etc/iproute2/config/resolv4.conf
/etc/iproute2/config/multi_table_config
/etc/iproute2/config/gateway_database
/etc/iproute2/config/eth0-table-rule
/etc/firewall_rules_security.dump
/tmp
root@sycwcwe:~#
!!!!das ist doch Deaktiviert oder wie kann das laufen ? !!!!!
