- 04. Jan. 2012
Manueller Download via Download-Zentrum.
(2021-08-31)
What’s New
- Supports migrating SA3200D system configurations when users perform HDD migration.
- Added support for memory cache mirroring across controllers for better data consistency on SA3200D.
- Added support for the "Sync remote mounted folders" option for Shared Folder Sync.
- Supports creating volumes of up to 1 PB in Btrfs (Peta Volume) format on the XS/XS+, SA (SA3200D excluded), and FS-series models. (Learn more)
- Added support for data deduplication on Btrfs volumes on certain models. (Learn more)
- Supports notifying users when there is insufficient storage for metadata.
Fixed Issues
- Fixed an issue where DSM might not automatically reconnect to a VPN after disconnection.
- Fixed the sorting issue on the View Details page in Resource Monitor > Performance > Disks when a USB drive is connected.
- Fixed an issue where the display in Volume Settings in Storage Manager was incorrect once users pinned the desktop widgets.
- Fixed an issue where the throughput in Resource Monitor might not be displayed correctly when the system network traffic or the throughput of disks or volumes was heavy.
- Fixed an issue where when users used third-party extensions to change the DSM theme, they couldn't customize the wallpaper.
- Fixed an issue where when non-administrator users shared files with password-protected links, the file names were displayed incorrectly.
- Fixed an issue where a healthy drive might be falsely detected as malfunctioning after it was swapped with a failed drive in the same storage pool when the system was shut down. The issue would cause the degraded storage pool to crash or become missing.
- Fixed multiple security vulnerabilities. (Synology-SA-21:25)
