Duuuval
- 05. Juni 2024
SAS drives definitely return a lot less SMART information than SATA drives do.Witzig sind die SMART Werte bei SAS Platten. Da kommt ja gar nichts zurück.
What's the benefit of this scheduled test? As far as I understand all disks update their SMART counters if there is any event. And this will be reported by syno_smart_info's next run.I have quick SMART tests scheduled to run on all drives at once at 7am every day.
Synology_SMART_info v1.4.26 - by 007revad
HD6500-Cluster HD6500 DSM 7.2.2-72806-4
Using smartctl 6.5
Drive 10 HAS5300-16T 23B0T9RA0A09ZFE3H /dev/sas8
SMART Health Status: OK
Total uncorrected read errors: 0
Total corrected read errors: 0
Total uncorrected write errors: 0
Total corrected write errors: 0
5 Elements in grown defect list: 0
194 Current Drive Temperature: 35 C
Drive 11 HAS5300-16T 23B0T9RA0A09JFE3H /dev/sas13
194 Current Drive Temperature: 36 C
Drive 12 HAS5300-16T 23B0T9RA0A064FE3H /dev/sas18
Drive 13 HAS5300-16T 23B0T9RA0A0AXFE3H /dev/sas4
194 Current Drive Temperature: 30 C
Drive 14 HAS5300-16T 23B0T9RA0A06AFE3H /dev/sas9
Drive 15 HAS5300-16T 23B0T9RA0A0BFFE3H /dev/sas14
Drive 16 HAS5300-16T 23B0T9RA0A042FE3H /dev/sas19
Drive 17 HAS5300-16T 23B0T9RA0A04XFE3H /dev/sas5
Drive 18 HAS5300-16T 23B0T9RA0A044FE3H /dev/sas10
Drive 19 HAS5300-16T 23B0T9RA0A045FE3H /dev/sas15
194 Current Drive Temperature: 33 C
Drive 1 SAT5220-960G 2420X2R475Z9R /dev/sas1
SMART overall-health self-assessment test result: PASSED
SMART Error Counter Log: No Errors Logged
1 Host_UNC_Error_Count 0
9 Power_on_hours 12109
194 Temperature 31
Drive 1 SAT5210-480G 22C0TXRK4HT0C /dev/sata1
9 Power_on_hours 12111
194 Temperature 33
Drive 20 HAS5300-16T 23B0T9RA0A09AFE3H /dev/sas20
194 Current Drive Temperature: 34 C
Drive 21 HAS5300-16T 23B0T9RA0A05XFE3H /dev/sas21
194 Current Drive Temperature: 29 C
Drive 22 HAS5300-16T 23B0T9RA0A04BFE3H /dev/sas23
Drive 23 HAS5300-16T 23B0T9RA0A05UFE3H /dev/sas25
Drive 24 HAS5300-16T 23B0T9RA0A05YFE3H /dev/sas27
194 Current Drive Temperature: 32 C
Drive 25 HAS5300-16T 23B0T9RA0A05KFE3H /dev/sas22
194 Current Drive Temperature: 28 C
Drive 26 HAS5300-16T 23B0T9RA0A05NFE3H /dev/sas24
194 Current Drive Temperature: 31 C
Drive 27 SAT5220-960G 2420X2RYEN301 /dev/sas26
9 Power_on_hours 11965
194 Temperature 34
Drive 28 SAT5220-960G 2420X2R7NJ7G6 /dev/sas28
194 Temperature 34
Drive 2 SAT5220-960G 2420X2R52W241 /dev/sas6
194 Temperature 33
Drive 2 SAT5210-480G 22C0TXRR97GT2 /dev/sata2
194 Temperature 34
Drive 3 HAS5300-16T 23B0T9RA0A07LFE3H /dev/sas11
Drive 4 HAS5300-16T 23B0T9RA0A04CFE3H /dev/sas16
Drive 5 HAS5300-16T 23B0T9RA0A08RFE3H /dev/sas2
Drive 6 HAS5300-16T 23B0T9RA0A06QFE3H /dev/sas7
Drive 7 HAS5300-16T 23B0T9RA0A07MFE3H /dev/sas12
Drive 8 HAS5300-16T 23B0T9RA0A0AWFE3H /dev/sas17
Drive 9 HAS5300-16T 23B0T9RA0A0AKFE3H /dev/sas3
Finished
Using smartctl 6.5
194 Current Drive Temperature: 37 C
9 Power_on_hours 12110
194 Temperature 32
9 Power_on_hours 12113
194 Temperature 33
9 Power_on_hours 11967
194 Temperature 34
194 Temperature 33
194 Temperature 35
194 Temperature 34
Finished
sudo synodisk --get_location_form /dev/sas1
sudo synodisk --get_location_form /dev/sata1
sudo syno_slot_mapping
