- 05. März 2013
Es gibt eine neue Version für ABfB.
Neben ein paar Security Fixes wird hier die Kompatibilität für macOS Sequoia 15 erwähnt:
https://www.synology.com/de-de/releaseNote/ActiveBackup?model=DS918+&os=DSM&version=7_x_series
Ich sehe grade, dass die History für den zugehörigen Client auch ganz interessant ist:
https://www.synology.com/de-de/releaseNote/ActiveBackupBusinessAgent
Version: 2.7.1-23234
(2025-01-06)
Compatibility and Installation
Version 2.7.1-23234 is for models running DSM 7.2.
What's new
Added support for macOS Sequoia 15.
Fixed Issues (General Issues)
Fixed a security vulnerability regarding SQL injection.
Fixed security vulnerabilities regarding heap-based and stack-based buffer overflows.
Fixed a security vulnerability regarding arbitrary access, creation, modification, and deletion of files.
Fixed Issues (Physical Server)
Fixed an issue where restoring to virtual machines might fail.
Anmerkungen:
This version is released in a staged rollout.
Version: 2.7.1-3234
(2025-01-06)
Updated to be compatible with Active Backup for Business 2.7.1.
Important Note
To ensure data integrity, Active Backup for Business will perform a full backup of Windows PCs and physical servers during the initial backup after updating to version 2.7.1 or above.
What's new
Enhanced backup performance for macOS 14.
Fixed Issues
Fixed an issue where extending volumes on Windows might result in incomplete backups.
Fixed an issue where backing up multiple block devices on the same general disk on Linux might result in incomplete backups.
Fixed an issue where backing up Macs with OpenCore Legacy Patcher might fail.
Fixed an issue where file restorations might fail.
