- 05. März 2013
Es gibt eine neue ABfB-Version: 2.7.0-23218
U.a. werden bei Linux neue Kernel unterstützt, die Release Notes:
https://www.synology.com/de-de/releaseNote/ActiveBackup?model=DS918+#7_x_series
What's new
Added support for Linux kernel versions up to 6.8 and the following physical server distributions:
RHEL: 8.7, 8.8, 8.9, 8.10, 9, 9.1, 9.2, 9.3, 9.4
Ubuntu: 24.04
Fedora: 38, 39, 40
Debian: 12
Fixed Issues (General Issues)
Fixed an issue where setting the retention period to a higher number might cause retention errors.
Improved an issue where backup versions were corrupted due to power outages.
Fixed a security vulnerability regarding cross-site scripting (XSS) in file server backups.
Fixed Issues (Linux)
Fixed an issue where backing up Linux devices with RAID volumes might fail.
Fixed an issue where the agent couldn't be installed due to a permission error.
Fixed Issues (Mac)
Fixed an issue where backups failed because volume snapshots couldn't be found.
Fixed Issues (DSM)
Fixed an issue where backup data couldn't be viewed in the Recovery Portal when the source NAS was backed up to the same destination using both Migration Assistant and Active Backup for Business Agent (DSM) simultaneously.
Fixed Issues (Server and Workstations)
Fixed an issue where backing up XFS systems might cause services to unexpectedly stop or result in incorrect backup data.
Fixed Issues (Virtual Machine)
Fixed an issue where restoring virtual machines to VMware might fail if the disk sizes weren't 4k aligned.
Fixed Issues (File Servers)
Fixed an issue where SMB backups might stop unexpectedly.
Limitations
Active Backup for Business Portal does not support browsing and restoring data from Fedora 40 with XFS file systems.
Anmerkungen:
This version is released in a staged rollout.
Leider funktioniert es anscheinend nicht mit Linux Manjaro
. Vorher ist nix mit Wilma ... Wenn Wilma dann auf meinem 17Zoll ASUS als Testkandidat
Und mein Dualboot-HP lass ich mal schön außen vor ... nicht das ich im Sommerwohnsitz durch die doch 3,50m hohe Decke schieße
Was dann tatsächlich funktioniert und was nicht, werden dann wohl nur echte Praxistests von Usern ergeben, weil Synology ja scheinbar auch nicht wirklich alles richig nachvollziehbar beschreibt.
