DSM 7.2 DSM 7.2-64561
Monacum
03. Jan 2022
Moin, heute ist die Final von DSM 7.2 erschienen. Anbei die Release Notes.
Danke an @DKeppi für den Hinweis!
Version: 7.2-64561​
(2023-05-22)
Important Note​
  1. After installing this update, you will not be able to downgrade to a previous DSM version.
  2. This update will restart your Synology NAS.
  3. Starting from this version, logs for drives will no longer appear in Storage Manager > HDD and will be available only in Log Center.
  4. Removed the "Automatically create port forwarding rules" option from QuickConnect advanced settings to increase network security.
  5. Users can now create a Btrfs volume of up to 1 PB on specific Synology NAS models. This update automatically converts existing volumes that use the Btrfs (Peta Volume) file system to Btrfs. However, to create a volume larger than 200 TB, a RAID 6 storage pool and at least 64 GB of system memory are still required.Learn more
  6. The maximum single volume size supported by RS2423+/RS2423RP+ has been adjusted to 200 TB (with a minimum system memory requirement of 32 GB).
  7. Starting from this version, Windows Server 2008 domains will no longer be supported. After installing this update, current Windows Server 2008 domains will be unavailable.
  8. For the models below, you can only download the upgrade patch from Synology Download Center because you won't receive notifications for this update on your DSM.
    • FS Series: FS3017, FS2017, FS1018
    • XS Series: RS18016xs+, RS4017xs+, RS3617xs+, RS3617xs, RS3617RPxs, RS18017xs+, DS3617xs, DS3617xsII, DS3018xs
    • Plus Series: RS2416RP+, RS2416+, DS916+, DS716+II, DS716+, DS216+II, DS216+, DS1817+, DS1517+, RS2818RP+, RS2418RP+, RS2418+, RS818RP+, RS818+, DS1618+, DS918+, DS718+, DS218+, RS1219+
    • Value Series: DS416, DS416play, DS216, DS216play, DS116, RS816, DS1817, DS1517, RS217, DS418play
    • J Series: DS416slim, DS416j, DS216j, DS418j, DS218j, DS419slim, DS119j
What’s New​
  1. Added support for WriteOnce shared folders. This feature is based on the Write Once, Read Many (WORM) technology and can be enabled to prevent files from being modified, deleted, or renamed for a specified period.
  2. Added support for volume encryption. All volume encryption keys are stored in the Encryption Key Vault, which can be set up on a local Synology NAS or via KMIP on a remote Synology NAS.
  3. Added more Synology NAS models to support M.2 NVMe SSD storage pools. Learn more
  4. Added more Synology NAS models to support the M2D18 adapter card: RS822RP+, RS822+, RS1221RP+, and RS1221+.
  5. Added more SSD cache group management options, including changing the RAID type and replacing a drive.
  6. Added support for inline zero-block removal to increase the efficiency of data deduplication.
  7. Adjusted how drive information is presented in Storage Manager. Users can now quickly check the condition of their drives by looking at the "Drive Status" field.
  8. Users can now view the amount of used and free space for each storage pool and volume in Storage Manager.
  9. Added a warning notification for when the available shared folder quota is low.
  10. Supports deleting individual desktop notifications.
  11. Supports sending DSM notifications via additional webhook providers, including LINE and Microsoft Teams.
  12. Supports creating custom notification rules for system events, giving users greater control over what notifications to receive.
  13. Supports exporting a list of users and of groups.
  14. Added support for SAML to integrate DSM with external SSO servers.
  15. Added the option to allow non-admin users to safely eject USB devices.
  16. Users can now manually input the IP addresses or FQDNs of one or more domain controllers in the trusted domain. This allows Synology NAS to sync domain data directly with the specified domain controllers.
  17. Users can now enable Synology's email server to send DSM notifications directly to their Synology Account.
Fixed Issues​
  1. Fixed an issue where adding drives to a JBOD storage pool did not expand its capacity.
  2. Updated Mbed-TLS to version 2.28.2 to fix multiple security vulnerabilities (CVE-2021-36647, CVE-2022-46392, CVE-2022-46393).
  3. Updated Libksba to version 1.6.3 to fix a security vulnerability (CVE-2022-3515).
  4. Updated SQLite to version 3.40.0 to fix a security vulnerability (CVE-2022-46908).
  5. Updated Certifi to version 2022.12.07 to fix a security vulnerability (CVE-2022-23491).
  6. Updated Node.js to version 14.21.1 to fix a security vulnerability (CVE-2022-43548).
  7. Updated cURL to version 7.86.0 to fix multiple security vulnerabilities (CVE-2022-27774, CVE-2022-27775, CVE-2022-27776, CVE-2022-27781, CVE-2022-27782, CVE-2022-32205, CVE-2022-32206, CVE-2022-32207, CV E-2022-32221, CVE-2022-35252, CVE-2022-42915, CVE-2022-42916).
  8. Updated PHP to version 8.1.9 to fix multiple security vulnerabilities (CVE-2019-11043, CVE-2021-21705, CVE-2022-31625).
  9. Updated Sysstat to version 12.7.1 to fix a security vulnerability (CVE-2022-39377).
  10. Updated OpenSSL to version 3.0.7 to fix multiple security vulnerabilities (CVE-2022-2068, CVE-2022-2097, CVE-2022-2274, CVE-2022-3358, CVE-2022-3602, CVE-2022-3786).
  11. Updated Expat to version 2.5.0 to fix a security vulnerability (CVE-2022-43680).
  12. Updated Libtirpc to version 2.87 to fix a security vulnerability (CVE-2021-46828).
  13. Updated GnuPG to version 2.2.39 to fix a security vulnerability (CVE-2022-34903).
  14. Updated OpenVPN to version 2.5.8 to fix a security vulnerability (CVE-2022-0547).
  15. Updated libxml2 to version 2.9.14 to fix a security vulnerability (CVE-2022-23308).
  16. Updated GMP to version 6.2.1 to fix a security vulnerability (CVE-2021-43618).
  17. Updated ImageMagick to version 6.9.12-61 to fix multiple security vulnerabilities (CVE-2020-25664, CVE-2020-25665, CVE-2020-25666, CVE-2020-25667, CVE-2020-25674, CVE-2020-25675, CVE-2020-25676, CVE-2020-27560, CVE-2020-27750, CVE-2020-27751, CVE-2020-27752, CVE-2020-27753, CVE-2020-27754, CVE-2020-27755, CVE-2020-27756, CVE-2020-27757, CVE-2020-27758, CVE-2020-27759, CVE-2020-27760, CVE-2020-27761, CVE-2020-27762, CVE-2020-27763, CVE-2020-27764, CVE-2020-27765, CVE-2020-27766, CVE-2020-27767, CVE-2020-27768, CVE-2020-27769, CVE-2020-27770, CVE-2020-27771, CVE-2020-27772, CVE-2020-27773, CVE-2020-27774, CVE-2020-27775, CVE-2020-27776, CVE-2020-29599, CVE-2021-20176, CVE-2021-20224, CVE-2021-20241, CVE-2021-20245, CVE-2021-20246, CVE-2021-20309, CVE-2021-3574, CVE-2021-3596, CVE-2021-39212, CVE-2021-4219, CVE-2022-1114, CVE-2022-1115, CVE-2022-28463, CVE-2022-32545, CVE-2022-32546, CVE-2022-32547).
  18. Updated FFmpeg to version 4.1.9 to fix multiple security vulnerabilities (CVE-2020-20892, CVE-2020-20902, CVE-2020-21688, CVE-2020-21697, CVE-2021-3566, CVE-2021-38114, CVE-2021-38291).
  19. Fixed a security vulnerability regarding Netatalk (CVE-2022-45188).
  20. Fixed multiple security vulnerabilities regarding Python3 (CVE-2020-10735, CVE-2021-28861, CVE-2022-45061).
  21. Fixed multiple security vulnerabilities regarding iproute2 (CVE-2022-3527, CVE-2022-3529, CVE-2022-3530).
  22. Fixed multiple security vulnerabilities regarding D-Bus (CVE-2022-42010, CVE-2022-42011, CVE-2022-42012).
  23. Fixed a security vulnerability regarding syslog-ng (CVE-2022-38725).
  24. Fixed a security vulnerability regarding inetutils (CVE-2022-39028).
  25. Fixed a security vulnerability regarding DNSmasq (CVE-2022-0934).
  26. Fixed a security vulnerability regarding BusyBox-udhcp (CVE-2019-5747).
  27. Fixed multiple security vulnerabilities regarding Linux Kernel (CVE-2021-22600, CVE-2021-38209, CVE-2021-4037, CVE-2022-0168, CVE-2022-1016, CVE-2022-1729, CVE-2022-1786, CVE-2022-20141, CVE-2022-20368, CVE-2022-2078, CVE-2022-2639, CVE-2022-2905, CVE-2022-29581, CVE-2022-32250, CVE-2022-3524, CVE-2022-3566, CVE-2022-3567, CVE-2022-36879, CVE-2022-36946, CVE-2022-42703).
  28. Fixed a security vulnerability regarding Nginx (CVE-2022-3638).
  29. Fixed a security vulnerability regarding ghostscript (CVE-2023-28879).
  30. Fixed a security vulnerability regarding curl (CVE-2023-23916).
Kurt-oe1kyw
10. Mai 2015
Ja ZUERST auch von mir DANKE an @DKeppi für seinen Hinweis und an Monacum für das eröffnen des neuen Themas DSM 7.2 da diese jetzt final ist.
kurze Vorabinfo:
laut Release ist eine Rückkehr auf eine niederigere Version unterhalb von DSM 7.2 nicht möglich.
Quickconnect eventuell neu starten, da Weiterleitungen deaktiviert werden, können aber wieder aktiviert werden.
Ein Haufen Paketupdates laufen.
Wichtig!
Beim Hinweisfenster über das Update müsst ihr ganz ans Ende hinunterscrollen und den Haken setzen, ansonsten könnt ihr das Upadate auf DSM 7.2 nicht starten:
DSM 7.2 final wird ausgerollt und kann ab sofort hier heruntergeladen werden:
https://archive.synology.com/download/Os/DSM/7.2-64561
Zeit nehmen! Das Update dauert länger, vor allem da sehr, sehr viele Programmpakete aktualisiert werden!
Also je nachdem was ihr alles installiert habt, dauert es entsprechend.
Update auf meiner Test-DS118 läuft noch:
Also für das Update wirklich Zeit nehmen! Das dauert eine Weile! Läuft jetzt bei mir seit 25 Minuten seit Klicken auf Update.
Reaktionen: Iarn und Monacum
Monacum
03. Jan 2022
Reaktionen: Benie und Kurt-oe1kyw
Andy+
25. Jan 2016
Es werden noch nicht alle DSn beliefert, zB. DSx15+ fehlen (noch).
Nach Update von RC 7.2 auf final 7.2 musste NVME-Volume online zusammengestellt werden. Und 42 Pakete repariert werden.
Kurt-oe1kyw
10. Mai 2015
So nach 35 Minuten meldete sich die DS118 mit DSM 7.2 mit ihrem Anmeldebildschirm zurück.
Es wurden bei mir nur 16 Pakete automatisch repariert, da ich auf der DS118 nicht so viel im Moment drauf habe.
ABER es schaut, sehr, sehr gut aus!
Ich hatte nur ein einziges Paket (WebDAVServer) der mir im Paketzentrum angezeigt wurde und nach Klicken auf "Reparieren" war auch dieses Paket unter DSM 7.2 vorhanden.
Alle anderen Pakete wurden automatisch mit dem DSM 7.2 Update aktualisiert/repariert. Nur eben WebDAVSever musst ich manuell einmal auf "Reparieren" im Paketzentrum klicken.
Ansonsten, alles gut bisher.
Für mich persönlich Wichtig:
Der AvrLogger von @BigRonin läuft auch immer noch unter DSM 7.2!
Das einzige was mir aufgefallen ist, früher wurde ein Fenster im DSM Desktop geöffnet, jetzt öffnet sich ein weiteres Webbrowserfenster für AvrLogger, ist aber kein Problem ich verkleinere es und ziehe es auf den gewünschten Platz im DSM-Desktop.
usbshare Nummern können nach wie vor auch unter DSM 7.2 frei definiert werden, siehe mein Beitrag von damals 2016:
https://www.synology-forum.de/threads/usb-laufwerken-feste-bezeichung-zuweisen.76629/#post-632301
Auch unter DSM 7.2 funktioniert das nach wie vor:
Erster Eindruck:
Synology hat gut geliefert.
Reaktionen: vater und Benie
Hier mal das ganze auf deutsch:
DSM Version: 7.2-64561
(2023-05-22)
Wichtiger Hinweis
Nach der Installation dieses Updates können Sie kein Downgrade auf eine frühere DSM-Version durchführen.
Mit diesem Update wird Ihr Synology NAS neu gestartet.
Ab dieser Version werden Protokolle für Laufwerke nicht mehr im Speicher-Manager > HDD angezeigt und sind nur noch im Protokollcenter verfügbar.
Die Option "Portweiterleitungsregeln automatisch erstellen" wurde aus den erweiterten QuickConnect-Einstellungen entfernt, um die Netzwerksicherheit zu erhöhen.
Benutzer können jetzt ein Btrfs-Volume von bis zu 1 PB auf bestimmten Synology NAS-Modellen erstellen. Dieses Update konvertiert vorhandene Volumes, die das Dateisystem Btrfs (Peta Volume) verwenden, automatisch in Btrfs. Um ein Volume größer als 200 TB zu erstellen, sind jedoch weiterhin ein RAID-6-Speicherpool und mindestens 64 GB Systemspeicher erforderlich. Weitere Informationen
Die maximale Größe eines einzelnen Volumes, die von RS2423+/RS2423RP+ unterstützt wird, wurde auf 200 TB (bei einem Mindestsystemspeicherbedarf von 32 GB) angepasst.
Ab dieser Version werden Windows Server 2008-Domänen nicht mehr unterstützt. Nach der Installation dieses Updates sind die aktuellen Windows Server 2008-Domänen nicht mehr verfügbar.
Für die folgenden Modelle können Sie den Upgrade-Patch nur aus dem Synology Download Center herunterladen, da Sie keine Benachrichtigungen für dieses Update auf Ihrem DSM erhalten.
FS-Serie: FS3017, FS2017, FS1018
XS-Serie: RS18016xs+, RS4017xs+, RS3617xs+, RS3617xs, RS3617RPxs, RS18017xs+, DS3617xs, DS3617xsII, DS3018xs
Plus-Serie: RS2416RP+, RS2416+, DS916+, DS716+II, DS716+, DS216+II, DS216+, DS1817+, DS1517+, RS2818RP+, RS2418RP+, RS2418+, RS818RP+, RS818+, DS1618+, DS918+, DS718+, DS218+, RS1219+
Value-Serie: DS416, DS416play, DS216, DS216play, DS116, RS816, DS1817, DS1517, RS217, DS418play
J-Serie: DS416slim, DS416j, DS216j, DS418j, DS218j, DS419slim, DS119j
Was gibt's Neues
Unterstützung für freigegebene WriteOnce-Ordner wurde hinzugefügt. Diese Funktion basiert auf der WORM-Technologie (Write Once, Read Many) und kann aktiviert werden, um zu verhindern, dass Dateien für einen bestimmten Zeitraum geändert, gelöscht oder umbenannt werden.
Unterstützung für die Volume-Verschlüsselung wurde zugefügt. Alle Volume-Verschlüsselungsschlüssel werden im Verschlüsselungsschlüsseltresor gespeichert, der auf einem lokalen Synology NAS oder über KMIP auf einem Remote-Synology NAS eingerichtet werden kann.
Weitere Synology NAS-Modelle zur Unterstützung von M.2 NVMe SSD-Speicherpools wurden hinzugefügt. Weitere Informationen
Weitere Synology NAS-Modelle zur Unterstützung der M2D18-Adapterkarte wurden hinzugefügt: RS822RP+, RS822+, RS1221RP+ und RS1221+.
Es wurden weitere Optionen für die Verwaltung von SSD-Cache-Gruppen hinzugefügt, einschließlich des Änderns des RAID-Typs und des Austauschs eines Laufwerks.
Unterstützung für die Inline-Zero-Block-Entfernung wurde hinzugefügt, um die Effizienz der Datendeduplizierung zu erhöhen.
Die Darstellung von Laufwerksinformationen im Speicher-Manager wurde angepasst. Benutzer können jetzt schnell den Zustand ihrer Laufwerke überprüfen, indem sie sich das Feld "Laufwerksstatus" ansehen.
Benutzer können jetzt die Menge des belegten und freien Speicherplatzes für jeden Speicherpool und Datenträger im Speichermanager anzeigen.
Es wurde eine Warnmeldung hinzugefügt, wenn das verfügbare Kontingent für freigegebene Ordner niedrig ist.
Unterstützt das Löschen einzelner Desktop-Benachrichtigungen.
Unterstützt das Senden von DSM-Benachrichtigungen über zusätzliche Webhook-Anbieter, einschließlich LINE und Microsoft Teams.
Unterstützt das Erstellen benutzerdefinierter Benachrichtigungsregeln für Systemereignisse und gibt Benutzern eine bessere Kontrolle darüber, welche Benachrichtigungen empfangen werden sollen.
Unterstützt das Exportieren einer Liste von Benutzern und Gruppen.
Unterstützung für SAML wurde hinzugefügt, um DSM in externe SSO-Server zu integrieren.
Es wurde die Option hinzugefügt, Benutzern ohne Administratorrechte das sichere Auswerfen von USB-Geräten zu ermöglichen.
Benutzer können jetzt die IP-Adressen oder FQDNs eines oder mehrerer Domänencontroller in der vertrauenswürdigen Domäne manuell eingeben. Auf diese Weise kann Synology NAS Domänendaten direkt mit den angegebenen Domänencontrollern synchronisieren.
Benutzer können jetzt den E-Mail-Server von Synology aktivieren, um DSM-Benachrichtigungen direkt an ihr Synology-Konto zu senden.
Behobene Probleme
Es wurde ein Problem behoben, bei dem das Hinzufügen von Laufwerken zu einem JBOD-Speicherpool dessen Kapazität nicht erweiterte.
Mbed-TLS wurde auf Version 2.28.2 aktualisiert, um mehrere Sicherheitslücken zu beheben (CVE-2021-36647, CVE-2022-46392, CVE-2022-46393).
Libksba wurde auf Version 1.6.3 aktualisiert, um eine Sicherheitslücke zu beheben (CVE-2022-3515).
SQLite wurde auf Version 3.40.0 aktualisiert, um eine Sicherheitslücke zu beheben (CVE-2022-46908).
Certifi wurde auf Version 2022.12.07 aktualisiert, um eine Sicherheitslücke zu beheben (CVE-2022-23491).
Node.js auf Version 14.21.1 aktualisiert, um eine Sicherheitslücke zu beheben (CVE-2022-43548).
cURL wurde auf Version 7.86.0 aktualisiert, um mehrere Sicherheitslücken zu beheben (CVE-2022-27774, CVE-2022-27775, CVE-2022-27776, CVE-2022-27781, CVE-2022-27782, CVE-2022-32205, CVE-2022-32206, CVE-2022-32207, CV E-2022-32221, CVE-2022-35252, CVE-2022-42915, CVE-2022-42916).
PHP wurde auf Version 8.1.9 aktualisiert, um mehrere Sicherheitslücken zu beheben (CVE-2019-11043, CVE-2021-21705, CVE-2022-31625).
Sysstat wurde auf Version 12.7.1 aktualisiert, um eine Sicherheitslücke zu beheben (CVE-2022-39377).
OpenSSL wurde auf Version 3.0.7 aktualisiert, um mehrere Sicherheitslücken zu beheben (CVE-2022-2068, CVE-2022-2097, CVE-2022-2274, CVE-2022-3358, CVE-2022-3602, CVE-2022-3786).
Expat wurde auf Version 2.5.0 aktualisiert, um eine Sicherheitslücke zu beheben (CVE-2022-43680).
Libtirpc wurde auf Version 2.87 aktualisiert, um eine Sicherheitslücke zu beheben (CVE-2021-46828).
GnuPG auf Version 2.2.39 aktualisiert, um eine Sicherheitslücke zu beheben (CVE-2022-34903).
OpenVPN wurde auf Version 2.5.8 aktualisiert, um eine Sicherheitslücke zu beheben (CVE-2022-0547).
libxml2 wurde auf Version 2.9.14 aktualisiert, um eine Sicherheitslücke zu beheben (CVE-2022-23308).
GMP wurde auf Version 6.2.1 aktualisiert, um eine Sicherheitslücke zu beheben (CVE-2021-43618).
ImageMagick auf Version 6.9 aktualisiert 12-61 zur Behebung mehrerer Sicherheitslücken (CVE-2020-25664, CVE-2020-25665, CVE-2020-25666, CVE-2020-25667, CVE-2020-25674, CVE-2020-25675, CVE-2020-25676, CVE-2020-27560, CVE-2020-27750, CVE-2020-27751, CVE-2020-27752, CVE-2020-27753, CVE-2020-27753, CVE-2020-27753, CVE-2020-27753, CVE-2020-27750, CVE-2020-27753, CVE-2020-27753, CVE-2020-27750, CVE-2020-27753, CVE-2020-27753, CVE-2020-27753, CVE-2020-27753 e-2020-27754, CVE-2020-27755, CVE-2020-27756, CVE-2020-27757, CVE-2020-27758, CVE-2020-27759, CVE-2020-27760, CVE-2020-27761, CVE-2020-27762, CVE-2020-27763, CVE-2020-27764, CVE-2020-27765, CVE-2020-27766, CVE-2020-27767, CVE-2020-27768, CVE-2020-27769, CVE-2020-27770, CVE-2020-27771, CVE-2020-27772, CVE-2020-27773, CVE-2020-27774, CVE-2020-27775, CVE-2020-27776, CVE-2020-29599, CVE-2021-20176, CVE-2021-20224, CVE-2020-20176, CVE-2021-20224, CVE-2020-20277 21-20241, CVE-2021-20245, CVE-2021-20246, CVE-2021-20309, CVE-2021-3574, CVE-2021-3596, CVE-2021-39212, CVE-2021-4219, CVE-2022-1114, CVE-2022-1115, CVE-2022-28463, CVE-2022-32545, CVE-2022-32546, CVE-2022-32547).
FFmpeg wurde auf Version 4.1.9 aktualisiert, um mehrere Sicherheitslücken zu beheben (CVE-2020-20892, CVE-2020-20902, CVE-2020-21688, CVE-2020-21697, CVE-2021-3566, CVE-2021-38114, CVE-2021-38291).
Eine Sicherheitslücke in Bezug auf Netatalk wurde behoben (CVE-2022-45188).
Mehrere Sicherheitslücken in Bezug auf Python3 behoben (CVE-2020-10735, CVE-2021-28861, CVE-2022-45061).
Mehrere Sicherheitslücken in Bezug auf iproute2 behoben (CVE-2022-3527, CVE-2022-3529, CVE-2022-3530).
Mehrere Sicherheitslücken in Bezug auf D-Bus behoben (CVE-2022-42010, CVE-2022-42011, CVE-2022-42012).
Eine Sicherheitslücke in Bezug auf syslog-ng wurde behoben (CVE-2022-38725).
Eine Sicherheitslücke in Bezug auf inetutils wurde behoben (CVE-2022-39028).
Eine Sicherheitslücke in Bezug auf DNSmasq wurde behoben (CVE-2022-0934).
Es wurde eine Sicherheitslücke in Bezug auf BusyBox-udhcp behoben (CVE-2019-5747).
Mehrere Sicherheitslücken in Bezug auf den Linux-Kernel behoben (CVE-2021-22600, CVE-2021-38209, CVE-2021-4037, CVE-2022-0168, CVE-2022-1016, CVE-2022-1729, CVE-2022-1786, CVE-2022-20141, CVE-2022-20368, CVE-2022-2078, CVE-2022-2639, CVE-2022-2905, CVE-2022-29581, CVE-2022-32250, CVE-2022-3524, CVE-2022-3566, CVE-2022-3567, CVE-2022-36879, CVE-2022-36946, CVE-2022-42703).
Eine Sicherheitslücke in Bezug auf Nginx wurde behoben (CVE-2022-3638).
Eine Sicherheitslücke bezüglich Ghostscript wurde behoben (CVE-2023-28879).
Eine Sicherheitslücke in Bezug auf curl wurde behoben (CVE-2023-23916).
Einschränkung
S.M.A.R.T.-Tests für M.2-NVMe-SSDs werden nicht mehr unterstützt.
Ab DSM 7.2 Beta unterstützt Virtual Machine Manager das Erstellen von Clustern mit älteren DSM-Versionen nicht mehr. Aktualisieren Sie jeden Host im Cluster auf dieselbe DSM-Version oder höhere Versionen, damit der Virtual Machine Manager-Cluster ordnungsgemäß funktioniert.
Anmerkungen:
Diese Version wird in einem gestaffelten Rollout veröffentlicht.
Ulfhednir
26. Aug 2013
DS1618+ verlief ohne Probleme; 1221+ hängt fest: "Der freie Speicherplatz dieses Systems ist unzureichend." :rolleyes:
d0zer
31. Jan 2014
Für die, die die finale 7.2 installiert haben, wie ist die bisherige Erfahrung mit Drittanbieter SSDs als NVME Volume?
Kurt-oe1kyw
10. Mai 2015
Andy+
25. Jan 2016
Ich lese das erst mal so, dass Du bereits ein NVMe-Volume eingerichtet hattest und nach dem Update war das erst mal wieder weg? Waren dann auch die Daten weg?
Andy+
25. Jan 2016
Ulfhednir
26. Aug 2013
Reaktionen: Kurt-oe1kyw
Daten sind alle noch da.
Andy+
25. Jan 2016
Das ist erst mal das wichtigste ... (y)
Könnte bitte mal jemand etwas für mich testen?
Ich habe seit DSM7.2 (RC und Final) und der zughörigen Version von "Synology Photos" (aktuell 1.4.0-0458) das Problem, dass ich bei den Rechten für den Freigegeben Bereich keine nicht-administrativen Gruppen (wie z.B. "users") hinzufügen kann, d.h. ich kann sie zwar hinzufügen, aber nach dem Speichern ist wieder alles weg. Es gehen nur administrative Gruppen bzw. einzelne Benutzer. Ist das bei euch auch so?
Nochmal kurz zur Erklärung:
Das NVME-Volume war nach dem Update nicht verfügbar/online. Es wurde im Speichermanager die Option online zusammenstellen angeboten und die Meldung, das diese NVME-Laufwerke nicht unterstützt werden angezeigt.
Ich habe dann online zusammengestellt, das Script nochmals ausgeführt und alle Pakete repariert (die Pakete laufen bei mir alle auf dem NVME-Volume.
Dann Neustart und alles war wieder in Ordnung.
Andy+
25. Jan 2016
Bei mir liegen da nur die vDisks vom VMM. Sollte nun da was sein, könnten die VM´s aus Sicherungen bzw. Exports wieder hergestellt werden, es wäre dennoch umständlich, wenn das wegen DSM-Updates jedesmal in die Binsen gehen würde. Ich denke mir, dass sich das Onlinezusammenstellen bei weiteren Updates nicht mehr wiederholt, weil NVMe-Volumes nun ja supported werden.
Monacum
03. Jan 2022
Die sind dann aber auch schon mit dem Release Candidate unterstützt worden.
