DSM 7.3 7.3.1-86003
luxdunkel
22. Mai 2023
7.3.1-86003 steht zum Download bereit:
Version: 7.3.1-86003
(2025-10-28)
Important Note
After installing this update, you will not be able to downgrade to a previous DSM version.
This update will restart your Synology NAS.
If auto update does not run, perform a manual update in Control Panel. Before updating, follow the instructions and complete the required actions to ensure success.
To uphold our commitment to quality, every DSM release undergoes rigorous validation. To ensure optimal stability, the models listed below will not receive this update on your device and will remain on their most suitable version. You can only download the upgrade patch from Synology Download Center because you won't receive notifications for this update on your DSM.
FS Series: FS3017, FS2017, FS1018
XS Series: RS18016xs+, RS4017xs+, RS3617xs+, RS3617xs, RS3617RPxs, RS18017xs+, DS3617xs, DS3617xsII, DS3018xs
Plus Series: RS2416RP+, RS2416+, DS916+, DS716+II, DS716+, DS216+II, DS216+, DS1817+, DS1517+, RS2818RP+, RS2418RP+, RS2418+, RS818RP+, RS818+, DS1618+, DS918+, DS718+, DS218+, RS1219+
Value Series: DS116, DS216, DS216play, DS416, DS416play, DS1517, DS1817, DS418play, RS217, RS816
J Series: DS216j, DS416j, DS416slim, DS419slim, DS418j, DS218j, DS119j
Compatibility & Installation
To ensure compatibility, Replication Service will be automatically updated or will require a manual update to a compatible version.
Fixed Issues
Fixed an issue where the LED brightness adjustment function might stop working on certain models.
Fixed an issue where connected external devices might not appear when selecting files or folders.
Fixed an issue where external storage devices might trigger false alerts.
Fixed an issue where a UPS connected via USB might fail to function after a system update.
Anmerkungen:
This version is released in a staged rollout.
Zitate bitte als Zitat und nicht als Code einfügen und die Quelle verlinken.
Reaktionen: luxdunkel
Who will be the beta tester to find the bugs in this version?
Never mind. I'm installing it now...
EDIT The LED brightness adjustment function now works on my DS1821+. I never had any of the other issues.
Manuelles Update ist auf der 418play gerade durchgelaufen. Hyper Backup, Hyper Backup Vault und Active Backup wurden automatisch aktualisiert, PHP 7.4 manuell deinstalliert.
Bis jetzt keine Auffälligkeiten, ob die Backups durchlaufen sehe ich dann Morgen.
Auf der 218+ dasselbe Spiel, auch hier keine Auffälligkeiten, die SS läuft problemlos weiter.
extFAT-Thema ist erledigt :)
DS720+, DS923+ und DS2419+ ohne Auffälligkeiten.
DSM 7.3.1 is available for the RS822+ and RS822RP+.
Wundert mich etwas, dass die Build-Nummer (86003) so viel höher ist beim Vorgänger - bei den wenigen Fixes.
Edit: Uih, wurden da auch viele andere Pakete aktualisiert. :oops: Da hat Synology die letzten Tage aber schwer geackert 😅
DS1520+ Update durch
LED-Steuerung funktioniert wieder
Active Inside wurde wieder mal neu installiert - manuell deinstalliert
Active Backup for Business erwartete ein Update - Update installiert
läuft
Kann ich nicht behaupten bei meiner 218+. Bei meiner 218 schon.
Öffne ich das Fenster Hardware & Energie funktioniert es, Fenster zu, wieder hell, übernehmen, leuchten sie auch wieder hell.
Witzig: Wenn ich das Fenster offen lasse und mich abmelde funktioniert es. Saufen die bei Synology zuviel Kaffee.
Mal beiden DS‘en upgedated,bisher läufts - auch die LEDs bzw. die eben nicht (weils so konfiguriert ist) :-P
Bei meiner DS116 waren die LED nach dem Update auch gleich wieder aus, wie konfiguriert. Angezeigt wurde mir das Update aber auch nicht automatisch, obwohl ja schon 7.3 drauf war.
Achja, Active Insight wurde auch mal wieder installiert, wie üblich halt.
Probleme könnte es für ABB-User geben. Beim Update wird ABB ja auf die neueste Version hochgezogen. Zumindest bei mir war das nicht ganz friktionsfrei. Ich habe das mal HIER gepostet.
Bei mir hats bei dem Update erstmal gefühlt alles zerlegt. Während die Pakete repariert wurden, ist das nvme-Volume rausgeflogen (wegen Inkompatibilität). Dann wurden die Pakete alle auf dem anderen Volume installiert. Dadurch waren alle Daten weg. Hyper Backup Jobs, AB4B Jobs, Drive Einstellungen, VMs. Nach Ausführen des HDD_DB_Scripts + Neustart konnte ich das nvme-Volume wieder "online zusammenstellen". Danach alle Pakete deinstalliert und auf das nvme Volume neu installiert. Dann war eigentlich alles wieder da. Nur wollten sich die Clients nicht mehr mit dem Drive Server verbinden. Man solle doch einfach "eine neue Verbindung anlegen". Klar. Bevor ich nun alle Clients neu anbinde und sämtliche Sync-Jobs neu anlege, habe ich gleich die Gelegenheit genutzt und die Windows-Clients auf Syncthing umgestellt. Das hatte ich eh schon für die mobilen Devices am Laufen. Also in dem Sinne positives Endergebnis. Das Update hat dazu geführt, dass ich noch weniger Synology Apps und Dienste nutze als eh schon. Dieses Mal hat es den Drive Server getroffen.
Frage dazu. Brauchtest du das DB-Script auch schon, um deine Samsung 970 EVOs als Volume einzurichten? Ich brauchte das, warum auch immer, bei den 980 Pro noch nie.
Da hast Du aber echt großes Pech gehabt.:(
Ich bei meiner 920+ ja, habe auch die 970 EVO plus, bei mir ist es schon mit dem DSM 7.3 Update ähnlich wiebei @plang.pl gelaufen, allerdings wa nur die Dockerapp betroffen. die war schnell gelöscht und neu installiert. Die Daten waren noch alle auf den NVMEs vorhanden und Docker hat diese zum Glück auch wieder übernommen.
Hier wurde schon mal etwas ähnliches dazu berichtet.
https://www.synology-forum.de/threa...ynology_m2_volume.129745/page-11#post-1261103
Reaktionen: plang.pl
Schön zu sehen dass ich vorgestern den richtigen Riecher hatte auch wenn das einige als unnötig ansahen.
Werde direkt updaten damit exfat Geschichte ist.
