- 26. Okt. 2009
Hi!
Heute morgen wurde mir über den DSM ein Update auf die Version 4482 angeboten, sogar mit Release-Notes. Im Downloadcenter von Synology konnte ich jedoch noch nichts dergleichen finden. Auf den Downoadservern unter http://ukdl.synology.com/download/DSM/5.0/4482/ aber schon.
Tommes
Version: 5.0-4482
(2014/04/24)
Compatibility and Installation
After installing this version of DSM on DS214play, the device will shut down and then power on automatically after two minutes.
DSM 5.0 4482 Change Log
*This feature includes GeoLite data created by MaxMind, available from http://www.maxmind.com.
- Added the GeoIP* feature in Firewall settings, enabling you to allow or block IP addresses from certain countries.
- Added an option to save files in UTF-8 (with BOM) format in Text Editor.
- Fixed a security issue of Windows File Service to prevent remote attackers from obtaining access. (CVE-2013-4496)
- Fixed several security issues related to cURL. (CVE-2014-0139, CVE-2014-0015, CVE-2013-6422)
- Fixed an issue where CGI programs could not run on Personal websites.
- Added feature to disconnect user connections to HTTP(S) services after a user's password is changed.
- Improved the stability of iSCSI target service.
- Improved the stability of file transfers via Apple File Protocol.
Tommes
