- 30. März 2022
I actually created this because you and @Tommes mentioned you wished there was a package repository that was better than cphub and synocommunity, and I didn't want to deal with SynoCommmunity's rules to publish my own packages.
Rather than forcing people to make spk files that conform to what my repository requires or expects, I decided to make it flexible enough to cope with:
I haven't decided if I want to release the source code yet. I don't want a bunch of copycat package repositories out there while I'm trying to get people to use my package repository.
I just added SynoOCR to the GitHub workflow and your packages highlighted 3 issues with my GitHub workflow, and CloudFlare worker, that I've now fixed. The issues were:
Now Medusa has a friend
- Missing keys in the INFO file.
- Whatever naming and versioning format authors have already.
- It even works if there are no releases and the spk files are in the repo's file tree (complete with inconsistent file names) like https://github.com/BenjV/SYNO-packages.
- GitHub workflow was not finding the PACKAGE_ICON_256.PNG in your spk files.
- GitHub workflow was trying to create the same packagename_120.png for both DSM6 and DSM7 packages. It now creates packagename_DSM6_120.png for DSM 6 packages and packagename_120.png for DSM 7 packages.
- CloudFlare worker needed changing to map x86_64 (and all other arches) to the various CPU platforms (all 37 of them).
So install was failing but upgrade and uninstall were working.
Currently it (incorrectly) assumes all spk files in the latest release a not beta, and it only gets the list of spk files from the latest release.
