I built my own 3rd Party Synology Package Repository
I've made some progress while manually editing the package source's package index.
It's been quite a while since I worked on CPHub. It was actually quite rare for me to release a beta, so I don't remember much about it. But I think setting `beta=yes` was enough for it to be displayed as a beta version in the package center.
Quote: https://help.synology.com/developer-guide/synology_package/INFO_optional_fields.html
Field Name: beta​
  • Description:If this package is considered the beta version, the beta information will be shown in Package Center.
  • Value:"yes"/"no"
  • Default Value:"no"
  • Example:None
  • DSM Requirement:6.0
Did CPHub include DSM 7 packages?
Yes
Did both stable and beta package versions show at the same time in the Community section for DSM 7?
As far as I remember, yes.
I think you had to explicitly mark a package as a beta when submitting it, or the "beta=yes" tag was evaluated during upload. In any case, CPHub treated beta packages separately.
In my case, it's like this:
DS 1
Installed: synOCR 1.5.2 (release) ➜ Update to synOCR 1.5.99.3 BETA is available (It shouldn't be that way)
DS 2
Installed: synOCR 1.5.99.2 BETA ➜ No update is offered (even though 1.5.99.3 is available on GitHub) / Latest version online: 1.5.2
The mapping doesn't seem to be correct here.
DS 1
That would be because at 2 AM UTC the GitHub workflow replaced the manual edit I made to index.json so the beta and stable versions were shown as separate packages (until you installed the beta version then it got messy).
DS 2
This should be fixed shortly. I just need to test it a bit.
Showing both beta and stable versions of the same package became to messy, so I've updated the Cloudflare worker.js (in a test package repository) to:
  1. Show just the beta version if "show beta packages" is enabled in packager center's settings.
  2. Show just the stable version if "show beta packages" is disabled in packager center's settings.
  3. Because both versions now show (one at a time) in package center with the same package name the Update button will appear when the stable version is already installed and the beta version is in the community tab (when "show beta packages" is enabled in packager center's settings).
I have not found out how to clear package center's cache, without having to reboot. Because package center shows a stale package list (until you reboot) I made a test package repository so any temporary changes I make won't negatively affect what people see from the main package repository.
Ideally your beta/pre-release version should have " beta" in the displayname so people know it's a beta version. Otherwise they don't get to see package center's [BETA] tag until after it is installed.
displayname="synOCR beta"
displayname_enu="synOCR beta"
displayname_ger="synOCR beta"
Idealerweise sollte Ihre Beta-/Vorabversion „Beta“ im Anhang bleiben, damit die Leute wissen, dass es sich um eine Betaversion handelt handelt. Andernfalls können sie das [BETA]-Tag des Paketzentrums erst sehen, nachdem es installiert wurde.
However, the problem remains that users cannot switch from the beta to the release version without reconfiguring their app, since they are separate versions.
They aren't separate packages if
package="synOCR"
is the same in both beta and stable versions.
It's just the displayname that appears in package center that needs to show it's a beta/pre-release package (because package center only shows the [BETA] after it's been installed.
Change the package source to
https://spkrepo-test.007daver.workers.dev/
and test that version.
Sorry, my mistake. I didn't read it carefully. 🙈
I've now updated the INFO in the current beta accordingly.
Reaktionen: DaveR
You need build the spk file again. My package source reads the INFO file from inside the spk file.
I had actually rebuilt it from scratch for this purpose, but apparently used the wrong checkout. Shame on me.
Version 1.5.99.4 is now available.
Reaktionen: DaveR
That's fixed it.
root@DS925plus:~# curl -fsSL --globoff --range 0-3145727 "https://github.com/geimist/synOCR/releases/download/v1.5.99.4-beta/synOCR_DSM7_v1.5.99.4.spk" | tar -xOf - "INFO" 2>/dev/null | grep -E '^(package|displayname)'
package="synOCR"
package_icon="PACKAGE_ICON.PNG"
Package Center takes 20 minutes to update it's cache, so you won't see the change in package center right away.
If you have changed to the test server you can change back to the main server.
https://spkrepo.007daver.workers.dev/
I'm happy with how it looks and behaves now.
spk download count changes from last week.
Task Scheduler has completed a scheduled task.
Task: Spk Downloads
Start time: Mon, 04 May 2026 00:00:01 +1000
Stop time: Mon, 04 May 2026 00:00:14 +1000
Current status: 0 (Normal)
Standard output/error:
--------  Download Count  2026-05-04  --------
OoklaSpeedtest       247      increased by 67
OpenSpeedTest        266      increased by 65
LibreSpeedTest       76
TranscodeDrivers     243      increased by 107
Synosmartinfo        2276     increased by 196
AutoPilot            783      increased by 26
LogAnalysis          1566     increased by 37
autorun              284      increased by 27
synOCR               362      increased by 120
AirConnect           24411    increased by 219
homebridge           316925   increased by 280
medusa               0
Reaktionen: geimist und Skyhigh
I can only see the following information in the logs:
  • Synology model.
  • CPU arch.
  • DSM version.
  • Language.
  • Timezone.
  • If they have beta packages enabled.
Apparently I can set it up to log IP addresses if the DNS server the request came from isn't 1.1.1.1
I can see that there has been 5,150 requests in the last 7 days. 1,520 of those were from Germany.
Poor medusa is always going to show 0 because it's spk files are stored in the repo's file tree and not as an asset to a release so no GitHub download count logged.
Reaktionen: luddi und geimist
I've got some logging setup for country and Synology model. This is just from the last 9 hours.
-------- Countries (last 9 hours) --------
  DE     73
  US     29
  NL     15
  RU     12
  GB     12
  CH     10
  CZ     10
  FR     9
  HK     8
  CA     8
  IT     4
  KR     4
  DK     3
  ES     3
  SK     3
  HU     3
  RE     3
  AT     3
  AU     2
  SE     2
  PL     2
  T1     2
  NZ     2
  TW     1
  VN     1
  MK     1
  MX     1
  RO     1
  FI     1
  TH     1
-------- Models (last 9 hours) --------
  35     synology_geminilakenk_ds225+
  23     synology_geminilakenk_ds425+
  13     synology_v1000_1821+
  13     synology_geminilake_224+
  12     synology_geminilake_920+
  12     synology_r1000_1522+
  12     synology_r1000_923+
  11     synology_apollolake_218+
  11     synology_v1000nk_ds1525+
  10     synology_geminilake_220+
  9      synology_epyc7002_sa6400
  7      synology_apollolake_918+
  6      synology_v1000_1621+
  5      synology_rtd1619b_ds223
  5      synology_geminilake_423+
  5      synology_r1000_723+
  4      synology_v1000nk_ds1825+
  3      synology_geminilake_420+
  3      synology_denverton_dva3221
  2      synology_rtd1619b_ds423
  2      synology_apollolake_718+
  2      synology_ds1821+
  2      synology_rtd1296_ds418j
  2      synology_braswell_916+
  2      synology_avoton_415+
  2      synology_apollolake_1019+
  2      synology_rtd1296_ds218
  2      synology_v1000nk_ds925+
  2      synology_v1000_rs1221+
  1      synology_monaco_ds216play
  1      synology_geminilake_1520+
  1      synology_v1000_1823xs+
  1      synology_denverton_1819+
  1      synology_rtd1619b_ds223j
  1      synology_geminilake_720+
  1      synology_broadwellnk_rs4021xs+
  1      synology_avoton_1817+
  1      synology_apollolake_418play
  1      synology_avoton_1815+
Stats for the last 4 days.
  • 2560 requests for the package list.
  • For 60 different Synology models.
  • From 39 different countries. DE is still way out in front.
The Synology models are interesting.
  • The top 5 keep changing places each day. 3 days ago DS218+ was number 2.
  • The low number of Rack Stations is curious.
  • SA6400 as number 15 in the list is obviously from Xpe users.
-------- Models (last 4 days) --------
  314    geminilakenk_ds225+
  300    geminilake_920+
  246    geminilakenk_ds425+
  162    apollolake_218+
  156    geminilake_220+
  114    r1000_923+
  112    v1000_1621+
  106    v1000nk_ds1525+
  86     apollolake_918+
  73     r1000_1522+
  61     v1000nk_ds925+
  59     geminilake_224+
  59     v1000_1821+
  54     broadwellnk_3622xs+
  45     epyc7002_sa6400
  42     rtd1296_ds218play
  41     geminilake_423+
  39     rtd1619b_ds223
  37     r1000_723+
  25     kvmx64_virtualdsm
  25     apollolake_1019+
  24     v1000_rs1221+
  24     geminilake_720+
  23     denverton_dva3221
  23     apollolake_418play
  22     rtd1296_ds418
  21     v1000_1823xs+
  21     geminilake_420+
  19     braswell_916+
  17     v1000nk_ds1825+
  17     denverton_1819+
  16     rtd1296_ds418j
  15     rtd1296_ds218
  14     apollolake_718+
  12      avoton_1815+
  11     geminilake_1520+
  11     rtd1619b_ds423
  10     cedarview_412+
  8      avoton_415+
  8      avoton_1817+
  7      armada38x_ds116
  7      armada370_213j
  7      denverton_1618+
  7      v1000_rs2421+
  7      rtd1296_rs819
  6      v1000_rs1221rp+
  6      denverton_rs2418+
  6      monaco_ds216play
  5      geminilake_dva1622
  4      88f6281_212j
  4      armada38x_ds216
  4      broadwellnk_rs4021xs+
  3      cedarview_1812+
  3      broadwellnk_rs1619xs+
  3      ds1821+
  2      alpine4k_ds215+
  2      armada38x_ds218j
  2      rtd1619b_ds223j
  2      rtd1296_ds118
  1      v1000nk_ds1525
  60     Different Models
  2560   Total Requests
-------- Countries (last 4 days) --------
  DE     763
  US     293
  RU     188
  NL     156
  GB     150
  FR     100
  CH     83
  CA     72
  UA     62
  VN     55
  MD     49
  SE     44
  AT     43
  RE     36
  IT     36
  NZ     35
  HK     35
  KR     34
  CZ     32
  HR     32
  TH     30
  RO     25
  HU     24
  ES     24
  AU     24
  SK     23
  PL     21
  DK     18
  TW     16
  GR     9
  KZ     9
  MY     9
  MK     6
  AL     6
  T1     5
  ID     5
  BE     3
  MX     3
  FI     2
  39     Different Countries
  2560   Total Requests
Reaktionen: Nivea_de und geimist
