Business Neue Version 3.0.0-24631 veröffentlicht...
Adama
05. März 2013
Moin, es gibt eine neue Version von ABfB: 3.0.0-24631
Hier die Release Notes:
Version: 3.0.0-24631
(2025-04-07)
Compatibility and Installation
    Active Backup for Business 3.0.0 and above requires DSM 7.2 or above.
    Active Backup for Business 3.0.0 and above requires installing Container Manager.
    The following models are not supported in Active Backup for Business 3.0.0 or above:
    DS214play
    DS216play
    DS415play
    DS416play
    DS418play
Important Note
    Daily backups previously scheduled to run every hour will change to hourly backups.
    To back up a custom volume on Mac, you only need to specify the volume name instead of the entire path. However, if your device has multiple volumes with the same name, all of them will be backed up. Backups configured before the update will continue using the full path unless modified.
    Active Backup for Business tasks will no longer appear in the Task Scheduler in DSM.
What's new
    Added support for centralized management via ActiveProtect appliances. [Learn about package features, requirements, and limitations here].(https://sy.to/abfbcentralizedmanagement)
    Updated OpenSSL to version 3.0.0 to enhance connection security. This update applies to personal computers, physical servers, file servers, and virtual machines.
    Added support for throttling failure notifications when the server reaches its storage limit or encounters hypervisor connection issues, preventing excessive notifications.
Fixed Issues (General Issues)
    Fixed an issue where reaching the storage limit might cause backups to freeze and prevent the status from updating.
Fixed Issues (Physical Server)
    Fixed an issue where the system might fail to boot after an instant restore to VMware when the disk was not 4K-aligned.
Fixed Issues (Virtual Machines)
    Fixed an issue where backing up VMware to encrypted or compressed storage might cause a boot failure during instant restores.
    Fixed an issue where Hyper-V backups might fail if the snapshot contains inaccessible virtual disks not directly related to the backup task
    Fixed an issue where restoring multiple virtual machines to different ESXi hosts within the same vCenter might fail.
    Fixed an issue where restores might fail if the selected vSwitch name conflicted with another on the same Hyper-V host.
Anmerkungen:
    This version is released in a staged rollout.
https://www.synology.com/de-de/releaseNote/ActiveBackup?model=DS918+&os=DSM&version=7_x_series
Ich hab - natürlich - schon upgedatet, wieder mal keine Selbstbeherrschung gehabt... ;)
Grundsätzlich läuft alles. Wer sich fragt, warum brauche ich jetzt den Container Manager dazu, siehe folgendes:
Und edit sagt, schau mal ins Menü:
Spassige Nebenerscheinung: Watchtower fällt natürlich bei all den Containern auf die Schnauze.
Als Beispiel:
Unable to update container "/apm-centralized-service": Error response from daemon: error parsing HTTP 403 response body: invalid character 'F' looking for beginning of value: "Forbidden". Proceeding to next.
Was kann man tun? All den Containern, die upgedatet werden sollen und die ich bearbeiten kann, hab ich folgendes Label mitgegeben:
    labels:
      - "com.centurylinklabs.watchtower.enable=true"
Dem Watchtower-Container gibt man folgende Environment-Variable mit:
      - "WATCHTOWER_LABEL_ENABLE=true"
Das hat Watchtower dann so interpretiert:
Watchtower 1.7.1
Using notifications: smtp
Only checking containers using enable label
Scheduling first run: 2025-04-07 16:00:00 +0200 CEST
Note that the first check will be performed in 1 hour, 46 minutes, 7 seconds
Damit sollte dann hoffentlich alles wieder richtig laufen. Schauen wir mal...
Reaktionen: Benie und maxblank
Das mit Docker wäre da auch meine erste Frage gewesen. Danke für die Erfahrungen
@plang.pl Wo ich noch nicht ganz sicher bin, sind die beiden Container, bei denen ich mich nur informieren lasse (MariaDB & PiHole). Da hab ich ja das Label
com.centurylinklabs.watchtower.monitor-only: "true"
vergeben.
Ich bin nicht sicher, ob die das andere Label zusätzlich brauchen. Ich hab es erstmal gelassen, wie es ist und werde es überwachen.
@Monacum Ja, hab ich in die yaml gepackt, hier als größerer Auschnitt:
    container_name: BookStack
    labels:
    environment:
Reaktionen: Monacum
Hab ich jetzt auch mal gemacht und werde das beobachten. Danke dir für den Tip!
Reaktionen: Adama
@Benie Das hatte ich zuerst überlegt, allerdings gefiel mir dann die Version mit dem Label besser....
Das passt schon alles, dachte mir nur das kennen vermutlich die wenigsten und da es hier dazu passt stell ich es mal hier mit ein.
Ich habe mich auch wegen dem neuen Pi-Hole damit beschäftigt und da empfehlen die Entwickler auch gleich Pighile von Watchtower auszuschließen.
Das war auch schon bei der Vorversion so, das hab ich mit dem Label aus Post #5 gelöst. Da meldet Watchtower dann nur, dass was neues da ist...
Jiop, das ist auch der beste Weg so habe ich vorallem immer selbst in der Hand und muß nach dem Aufwache nicht feststellen daß ein fehlerhaftes Update einen meiner Container zerlegt hat.
Reaktionen: Adama
Ich brauche (und will auch) kein "Centralized Management". Weiß jemand, wie ich den ganzen Container Mist wieder losbekomme? Verbraucht nur Platz und stört bei der Übersicht im Container-Manager. Ich will dort nur die Container sehen, die ich eplizit angelegt habe.
Reaktionen: Kaktus1911
Da das gestern erst veröffentlich wurde, weiß das vermutlich nur Synology. Ich finde das von der Übersichtlichkeit aber auch schlecht gelöst.
Kann man höchstens bei der alten Version bleiben. Ich finde das mit den Containern ehrlich gesagt auch unschön. So ne Lösung hat Synology das erste Mal mit dem Document Viewer eingeführt.
Also bei den Containern, die sich updaten sollen, funktionieren meine Einstellungen schon mal problemlos. Die Syno-Container beachtet er nicht mehr.
Jetzt muss ich nur mal drauf achten, wenn MariaDB oder PiHole ein Update haben, ob das dann gemeldet wird.
Hat jemand (außer mir) schon das Boot-Medium "Synology Restore Media Creator-3.0.0-4081(4631)" getestet?
Bei mir (Windows 11 - 64 bit, installiertes ADK + PE) konnte ich bis zur Version 2.7.1 immer problemlos Stick und ISO erstellen. Mit 3.0.0 keine Chance mehr! Die Message "....das ADK ist nicht vollständig installiert, es fehlen Dateien...." kommt, sobald PE die Uhrzeit vom System holen will. So nützt mir die Version 3.0 absolut gar nichts. Ohne Boot-Stick! Wer jetzt denkt, "dann nehme ich doch den 2.7er Stick, wird enttäuscht werden. Funktioniert mit installiertem Active Backup 3.0 nicht zusammen!
