- 30. Dez. 2012
root@DS1522:~# lsusb
|__usb1 1d6b:0002:0404 09 2.00 480MBit/s 0mA 1IF (Linux 4.4.302+ xhci-hcd xHCI Host Controller 0000:0b:00.3) hub
|__1-1 f400:f400:0100 00 2.00 480MBit/s 200mA 1IF (Synology DiskStation 6500276C36346E12)
|__usb2 1d6b:0003:0404 09 3.00 5000MBit/s 0mA 1IF (Linux 4.4.302+ xhci-hcd xHCI Host Controller 0000:0b:00.3) hub
root@DS415:~# lsusb
|__usb1 1d6b:0002:0310 09 2.00 480MBit/s 0mA 1IF (ehci_hcd 0000:00:16.0) hub
|__1-1 8087:07db:0002 09 2.00 480MBit/s 0mA 1IF ( ffffffd1ffffffb2ffffffdbffffffad) hub
|__1-1.1 f400:f400:0100 00 2.00 480MBit/s 200mA 1IF (Synology DiskStation 6500510F8BB76D46)
|__usb2 1d6b:0002:0310 09 2.00 480MBit/s 0mA 1IF (Linux 3.10.108 etxhci_hcd-170202 Etron xHCI Host Controller 0000:04:00.0) hub
|__usb3 1d6b:0003:0310 09 3.00 5000MBit/s 0mA 1IF (Linux 3.10.108 etxhci_hcd-170202 Etron xHCI Host Controller 0000:04:00.0) hub
|__3-1 0bda:8156:3000 00 3.20 5000MBit/s 512mA 1IF (Realtek USB 10/100/1G/2.5G LAN 000000001)
heißt das, nur einer der Ports ist USB3?
Kannst du mal das absetzen per SSH:
Code:ethtool eth2
admin@DS918:/$ ethtool eth2
Settings for eth2:
Supported ports: [ MII ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Full
2500baseX/Full
Supported pause frame use: No
Supports auto-negotiation: Yes
Supported FEC modes: Not reported
Advertised link modes: 10baseT/Half 10baseT/Full
1000baseT/Full
Advertised pause frame use: Symmetric Receive-only
Advertised auto-negotiation: Yes
Advertised FEC modes: Not reported
Link partner advertised link modes: 100baseT/Half 100baseT/Full
1000baseT/Full
Link partner advertised pause frame use: No
Link partner advertised auto-negotiation: Yes
Link partner advertised FEC modes: Not reported
Speed: 1000Mb/s
Duplex: Full
Port: MII
PHYAD: 3
Transceiver: internal
Auto-negotiation: on
Cannot get wake-on-lan settings: Operation not permitted
Current message level: 0x00007fff (32767)
drv probe link timer ifdown ifup rx_err tx_err tx_queued intr tx_done rx_status pktdata hw wol
Link detected: yes
Mir wäre auch nicht bekannt, dass meine DS415+ 3 USB-Ports hat
Nein, wurde nicht ignoriert. Ich habe hinten und vorn schon getestet. Immer das gleiche Ergebnis.Meine Empfehlung mit dem Testen der übrigen beiden USB-Ports wurde ignoriert.
root@DS1522:~# ethtool eth4
Settings for eth4:
Supported ports: [ TP ]
Supported link modes: 100baseT/Full
1000baseT/Full
10000baseT/Full
2500baseT/Full
5000baseT/Full
Supported pause frame use: Symmetric Receive-only
Advertised link modes: 100baseT/Full
1000baseT/Full
10000baseT/Full
2500baseT/Full
5000baseT/Full
Advertised pause frame use: No
Speed: 10000Mb/s
Duplex: Full
Port: Twisted Pair
PHYAD: 0
MDI-X: Unknown
Supports Wake-on: pg
Wake-on: g
Current message level: 0x00000005 (5)
drv link
Link detected: yes
Wo muss ich das einstellen?Kannst du evtl. mal den Switch-Port fest auf 2,5 oder 5GBit stellen?
