Basic Backup GUI Version: 0.8-100
Basic Backup Job Configuration : 0.8-000
Basic Backup rsync script Version: 0.8-000
DiskStation Manager Version: 7.1.1-42962 Update 6
2023-12-10 17:21:13 - Der Datensicherungsauftrag wird gestartet...
Die Auftragskonfiguration wird eingelesen [ Test.config ]
Es wird ein Pull-Backup durchgefuehrt. Verbindung wird geprueft...
Der Remote Server ist online. Versuche eine Verbindung herzustellen.
Die SSH-Verbindung zum Remote Server wurde erfolgreich hergestellt.
OpenSSH_8.2p1, OpenSSL 1.1.1t 7 Feb 2023
debug2: resolve_canonicalize: hostname 192.168.178.86 is address
debug1: Authenticator provider $SSH_SK_PROVIDER did not resolve; disabling
debug2: ssh_connect_direct
debug1: Connecting to 192.168.178.86 [192.168.178.86] port 22.
debug1: Connection established.
debug1: identity file /root/.ssh/id_rsa type 0
debug1: identity file /root/.ssh/id_rsa-cert type -1
debug1: Local version string SSH-2.0-OpenSSH_8.2
debug1: Remote protocol version 2.0, remote software version OpenSSH_8.2
debug1: match: OpenSSH_8.2 pat OpenSSH* compat 0x04000000
debug2: fd 3 setting O_NONBLOCK
debug1: Authenticating to 192.168.178.86:22 as 'RR-admin'
debug3: hostkeys_foreach: reading file "/root/.ssh/known_hosts"
debug3: record_hostkey: found key type ECDSA in file /root/.ssh/known_hosts:1
debug3: load_hostkeys: loaded 1 keys from 192.168.178.86
debug3: order_hostkeyalgs: have matching best-preference key type
ecdsa-sha2-nistp256-cert-v01@openssh.com, using HostkeyAlgorithms verbatim
debug3: send packet: type 20
debug1: SSH2_MSG_KEXINIT sent
debug3: receive packet: type 20
debug1: SSH2_MSG_KEXINIT received
debug2: local client KEXINIT proposal
debug2: KEX algorithms: curve25519-sha256,
curve25519-sha256@libssh.org,ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group-exchange-sha256,diffie-hellman-group16-sha512,diffie-hellman-group18-sha512,diffie-hellman-group14-sha256,ext-info-c
debug2: host key algorithms:
ecdsa-sha2-nistp384-cert-v01@openssh.com,
ecdsa-sha2-nistp521-cert-v01@openssh.com,
sk-ecdsa-sha2-nistp256-cert-v01@openssh.com,
ssh-ed25519-cert-v01@openssh.com,
sk-ssh-ed25519-cert-v01@openssh.com,
rsa-sha2-512-cert-v01@openssh.com,
rsa-sha2-256-cert-v01@openssh.com,
ssh-rsa-cert-v01@openssh.com,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521,
sk-ecdsa-sha2-nistp256@openssh.com,ssh-ed25519,
sk-ssh-ed25519@openssh.com,rsa-sha2-512,rsa-sha2-256,ssh-rsa
debug2: ciphers ctos:
chacha20-poly1305@openssh.com,aes128-ctr,aes192-ctr,aes256-ctr,
aes128-gcm@openssh.com,
aes256-gcm@openssh.com
debug2: ciphers stoc:
debug2: MACs ctos:
umac-64-etm@openssh.com,
umac-128-etm@openssh.com,
hmac-sha2-256-etm@openssh.com,
hmac-sha2-512-etm@openssh.com,
hmac-sha1-etm@openssh.com,
umac-64@openssh.com,
umac-128@openssh.com,hmac-sha2-256,hmac-sha2-512,hmac-sha1
debug2: MACs stoc:
debug2: compression ctos: none,
zlib@openssh.com,zlib
debug2: compression stoc: none,
debug2: languages ctos:
debug2: languages stoc:
debug2: first_kex_follows 0
debug2: reserved 0
debug2: peer server KEXINIT proposal
curve25519-sha256@libssh.org,diffie-hellman-group-exchange-sha256,diffie-hellman-group14-sha256,diffie-hellman-group16-sha512,diffie-hellman-group18-sha512,ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521
debug2: host key algorithms: rsa-sha2-512,rsa-sha2-256,ssh-rsa,ecdsa-sha2-nistp256,ssh-ed25519
debug2: ciphers ctos: aes128-ctr,
aes128-gcm@openssh.com,aes192-ctr,aes256-ctr,
aes256-gcm@openssh.com,
debug2: ciphers stoc: aes128-ctr,
debug2: MACs ctos: hmac-sha1,
hmac-sha1-etm@openssh.com,hmac-sha2-256,
hmac-sha2-256-etm@openssh.com,hmac-sha2-512,
umac-64@openssh.com
debug2: MACs stoc: hmac-sha1,
umac-64@openssh.com
zlib@openssh.com
zlib@openssh.com
debug2: reserved 0
debug1: kex: algorithm: curve25519-sha256
debug1: kex: host key algorithm: ecdsa-sha2-nistp256
debug1: kex: server->client cipher:
chacha20-poly1305@openssh.com MAC: compression: none
debug1: kex: client->server cipher:
debug3: send packet: type 30
debug1: expecting SSH2_MSG_KEX_ECDH_REPLY
debug3: receive packet: type 31
debug1: Server host key: ecdsa-sha2-nistp256 SHA256:+6mqQf/tbnMfdGaCLsI2lNji0WQYBq63H2j4f8NzwDQ
debug1: Host '192.168.178.86' is known and matches the ECDSA host key.
debug1: Found key in /root/.ssh/known_hosts:1
debug3: send packet: type 21
debug2: set_newkeys: mode 1
debug1: rekey out after 134217728 blocks
debug1: SSH2_MSG_NEWKEYS sent
debug1: expecting SSH2_MSG_NEWKEYS
debug3: receive packet: type 21
debug1: SSH2_MSG_NEWKEYS received
debug2: set_newkeys: mode 0
debug1: rekey in after 134217728 blocks
debug1: Will attempt key: /root/.ssh/id_rsa RSA SHA256:z7pVEbPvTyHSWAMnsNDLYqlYF+dBCOUMbfCpMBM1Wao explicit
debug2: pubkey_prepare: done
debug3: send packet: type 5
debug3: receive packet: type 7
debug1: SSH2_MSG_EXT_INFO received
debug1: kex_input_ext_info: server-sig-algs=
debug3: receive packet: type 6
debug2: service_accept: ssh-userauth
debug1: SSH2_MSG_SERVICE_ACCEPT received
debug3: send packet: type 50
debug3: receive packet: type 51
debug1: Authentications that can continue: publickey,password
debug3: start over, passed a different list publickey,password
debug3: preferred publickey,keyboard-interactive,password
debug3: authmethod_lookup publickey
debug3: remaining preferred: keyboard-interactive,password
debug3: authmethod_is_enabled publickey
debug1: Next authentication method: publickey
debug1: Offering public key: /root/.ssh/id_rsa RSA SHA256:z7pVEbPvTyHSWAMnsNDLYqlYF+dBCOUMbfCpMBM1Wao explicit
debug2: we sent a publickey packet, wait for reply
debug3: receive packet: type 60
debug1: Server accepts key: /root/.ssh/id_rsa RSA SHA256:z7pVEbPvTyHSWAMnsNDLYqlYF+dBCOUMbfCpMBM1Wao explicit
debug3: sign_and_send_pubkey: RSA SHA256:z7pVEbPvTyHSWAMnsNDLYqlYF+dBCOUMbfCpMBM1Wao
debug3: sign_and_send_pubkey: signing using rsa-sha2-512 SHA256:z7pVEbPvTyHSWAMnsNDLYqlYF+dBCOUMbfCpMBM1Wao
debug3: receive packet: type 52
debug1: Authentication succeeded (publickey).
Authenticated to 192.168.178.86 ([192.168.178.86]:22).
debug2: fd 4 setting O_NONBLOCK
debug2: fd 5 setting O_NONBLOCK
debug3: fd 6 is O_NONBLOCK
debug1: channel 0: new [client-session]
debug3: ssh_session2_open: channel_new: 0
debug2: channel 0: send open
debug3: send packet: type 90
debug1: Requesting
no-more-sessions@openssh.com
debug3: send packet: type 80
debug1: Entering interactive session.
debug1: pledge: network
debug3: receive packet: type 80
debug1: client_input_global_request: rtype
hostkeys-00@openssh.com want_reply 0
debug3: receive packet: type 4
debug1: Remote: /var/services/homes/RR-admin/.ssh/authorized_keys:1: key options: agent-forwarding port-forwarding pty user-rc x11-forwarding
debug3: receive packet: type 91
debug2: channel_input_open_confirmation: channel 0: callback start
debug2: fd 3 setting TCP_NODELAY
debug3: ssh_packet_set_tos: set IP_TOS 0x08
debug2: client_session2_setup: id 0
debug1: Sending command: logout
debug2: channel 0: request exec confirm 1
debug3: send packet: type 98
debug2: channel_input_open_confirmation: channel 0: callback done
debug2: channel 0: open confirm rwindow 0 rmax 32768
debug2: channel 0: rcvd adjust 2097152
debug3: receive packet: type 99
debug2: channel_input_status_confirm: type 99 id 0
debug2: exec request accepted on channel 0
debug2: channel 0: read<=0 rfd 4 len 0
debug2: channel 0: read failed
debug2: channel 0: chan_shutdown_read (i0 o0 sock -1 wfd 4 efd 6 [write])
debug2: channel 0: input open -> drain
debug2: channel 0: ibuf empty
debug2: channel 0: send eof
debug3: send packet: type 96
debug2: channel 0: input drain -> closed
debug2: channel 0: rcvd ext data 48
sh: line 0: logout: not login shell: use `exit'
debug2: channel 0: written 48 to efd 6
debug3: receive packet: type 98
debug1: client_input_channel_req: channel 0 rtype exit-status reply 0
debug3: receive packet: type 96
debug2: channel 0: rcvd eof
debug2: channel 0: output open -> drain
debug2: channel 0: obuf empty
debug2: channel 0: chan_shutdown_write (i3 o1 sock -1 wfd 5 efd 6 [write])
debug2: channel 0: output drain -> closed
debug3: receive packet: type 97
debug2: channel 0: rcvd close
debug3: channel 0: will not send data after close
debug2: channel 0: almost dead
debug2: channel 0: gc: notify user
debug2: channel 0: gc: user detached
debug2: channel 0: send close
debug3: send packet: type 97
debug2: channel 0: is dead
debug2: channel 0: garbage collecting
debug1: channel 0: free: client-session, nchannels 1
debug3: channel 0: status: The following connections are open:
#0 client-session (t4 r0 i3/0 o3/0 e[write]/0 fd -1/-1/6 sock -1 cc -1)
debug3: send packet: type 1
debug1: fd 0 clearing O_NONBLOCK
debug3: fd 1 is not O_NONBLOCK
debug1: fd 2 clearing O_NONBLOCK
Transferred: sent 3616, received 3324 bytes, in 0.1 seconds
Bytes per second: sent 71872.9, received 66069.0
debug1: Exit status 1
Der Remote Server ist einsatzbereit. Der Datensicherungsauftrag wird vorbereitet.
Das Datensicherungsziel wurde lokalisiert.
Start der rsync-Datensicherung...
2023-12-10 17:21:15 - Schreibe rsync-Protokoll fuer den Quellordner...
➜ /volume1/0_Test
opening connection using: ssh -p 22 -i "~/.ssh/id_rsa" -l RR-admin 192.168.178.86 rsync --server --sender -vvvlogDtpre.iLsfxC . /volume1/0_Test (14 args)
receiving incremental file list
[sender] add_rule(-s @eaDir/***)
[sender] add_rule(-s @Logfiles/***)
[sender] add_rule(-s #recycle/***)
[sender] add_rule(-s #snapshot/***)
[sender] add_rule(-s .DS_Store/***)
server_sender starting pid=28874
[sender] make_file(0_Test,*,0)
send_file_list done
[sender] pushing local filters for /volume1/0_Test/
[sender] hiding directory 0_Test/@eaDir because of pattern @eaDir/***
[sender] make_file(0_Test/Ordner 1,*,2)
[sender] make_file(0_Test/Ordner 2,*,2)
send_files starting
[sender] pushing local filters for /volume1/0_Test/Ordner 1/
[sender] make_file(0_Test/Ordner 1/Video 1.mkv,*,2)
[sender] pushing local filters for /volume1/0_Test/Ordner 2/
[sender] make_file(0_Test/Ordner 2/Video 2.mkv,*,2)
[sender] make_file(0_Test/Ordner 2/Video 3.mkv,*,2)
recv_file_name(0_Test)
received 1 names
recv_file_list done
recv_file_name(0_Test/Ordner 1)
recv_file_name(0_Test/Ordner 2)
received 2 names
recv_file_list done
get_local_name count=3 /volume1/0_Test/0_Test/
generator starting pid=6437
recv_files(1) starting
delta-transmission enabled
[receiver] receiving flist for dir 1
recv_generator(0_Test,1)
recv_file_name(0_Test/Ordner 1/Video 1.mkv)
received 1 names
recv_file_list done
[receiver] receiving flist for dir 2
recv_file_name(0_Test/Ordner 2/Video 2.mkv)
recv_generator(0_Test,2)
recv_file_name(0_Test/Ordner 2/Video 3.mkv)
received 2 names
recv_file_list done
set modtime of 0_Test to (1702224646) Sun Dec 10 17:10:46 2023
delete_in_dir(0_Test)
[generator] pushing local filters for /volume1/0_Test/0_Test/0_Test/
recv_generator(0_Test/Ordner 1,3)
recv_generator(0_Test/Ordner 2,4)
[generator] receiving flist for dir 1
received 1 names
recv_file_list done
recv_generator(0_Test/Ordner 1,5)
set uid of 0_Test/Ordner 1 from 0 to 1024
set gid of 0_Test/Ordner 1 from 0 to 100
set modtime of 0_Test/Ordner 1 to (1702224678) Sun Dec 10 17:11:18 2023
send_files(2, /volume1/0_Test)
recv_files(0_Test)
delete_in_dir(0_Test/Ordner 1)
[generator] pushing local filters for /volume1/0_Test/0_Test/0_Test/Ordner 1/
0_Test/
recv_generator(0_Test/Ordner 1/Video 1.mkv,6)
[generator] receiving flist for dir 2
received 2 names
recv_file_list done
recv_generator(0_Test/Ordner 2,7)
set uid of 0_Test/Ordner 2 from 0 to 1024
set gid of 0_Test/Ordner 2 from 0 to 100
set modtime of 0_Test/Ordner 2 to (1702224705) Sun Dec 10 17:11:45 2023
delete_in_dir(0_Test/Ordner 2)
[generator] pushing local filters for /volume1/0_Test/0_Test/0_Test/Ordner 2/
recv_generator(0_Test/Ordner 2/Video 2.mkv,8)
recv_generator(0_Test/Ordner 2/Video 3.mkv,9)
generate_files phase=1
send_files(5, /volume1/0_Test/Ordner 1)
send_files(6, /volume1/0_Test/Ordner 1/Video 1.mkv)
send_files mapped /volume1/0_Test/Ordner 1/Video 1.mkv of size 488058719
calling match_sums /volume1/0_Test/Ordner 1/Video 1.mkv
recv_files(0_Test/Ordner 1)
0_Test/Ordner 1/
recv_files(0_Test/Ordner 1/Video 1.mkv)
sending file_sum
false_alarms=0 hash_hits=0 matches=0
sender finished /volume1/0_Test/Ordner 1/Video 1.mkv
send_files(7, /volume1/0_Test/Ordner 2)
send_files(8, /volume1/0_Test/Ordner 2/Video 2.mkv)
send_files mapped /volume1/0_Test/Ordner 2/Video 2.mkv of size 751651389
calling match_sums /volume1/0_Test/Ordner 2/Video 2.mkv
got file_sum
set uid of 0_Test/Ordner 1/.Video 1.mkv.ixn7qw from 0 to 1024
set gid of 0_Test/Ordner 1/.Video 1.mkv.ixn7qw from 0 to 100
set modtime of 0_Test/Ordner 1/.Video 1.mkv.ixn7qw to (1645928238) Sun Feb 27 03:17:18 2022
renaming 0_Test/Ordner 1/.Video 1.mkv.ixn7qw to 0_Test/Ordner 1/Video 1.mkv
recv_files(0_Test/Ordner 2)
0_Test/Ordner 2/
recv_files(0_Test/Ordner 2/Video 2.mkv)
sending file_sum
sender finished /volume1/0_Test/Ordner 2/Video 2.mkv
send_files(9, /volume1/0_Test/Ordner 2/Video 3.mkv)
send_files mapped /volume1/0_Test/Ordner 2/Video 3.mkv of size 679411238
calling match_sums /volume1/0_Test/Ordner 2/Video 3.mkv
got file_sum
set uid of 0_Test/Ordner 2/.Video 2.mkv.yApq41 from 0 to 1024
set gid of 0_Test/Ordner 2/.Video 2.mkv.yApq41 from 0 to 100
set modtime of 0_Test/Ordner 2/.Video 2.mkv.yApq41 to (1653010368) Fri May 20 03:32:48 2022
renaming 0_Test/Ordner 2/.Video 2.mkv.yApq41 to 0_Test/Ordner 2/Video 2.mkv
recv_files(0_Test/Ordner 2/Video 3.mkv)
sending file_sum
sender finished /volume1/0_Test/Ordner 2/Video 3.mkv
got file_sum
set uid of 0_Test/Ordner 2/.Video 3.mkv.UkwRXi from 0 to 1024
set gid of 0_Test/Ordner 2/.Video 3.mkv.UkwRXi from 0 to 100
set modtime of 0_Test/Ordner 2/.Video 3.mkv.UkwRXi to (1653049447) Fri May 20 14:24:07 2022
renaming 0_Test/Ordner 2/.Video 3.mkv.UkwRXi to 0_Test/Ordner 2/Video 3.mkv
send_files phase=1
recv_files phase=1
generate_files phase=2
send_files phase=2
send files finished
total: matches=0 hash_hits=0 false_alarms=0 data=1919121346
recv_files phase=2
recv_files finished
generate_files phase=3
rsync[6442] (receiver) heap statistics:
arena: 831488 (bytes from sbrk)
ordblks: 2 (chunks not in use)
smblks: 2
hblks: 2 (chunks from mmap)
hblkhd: 401408 (bytes from mmap)
allmem: 1232896 (bytes from sbrk + mmap)
usmblks: 0
fsmblks: 128
uordblks: 700368 (bytes used)
fordblks: 131120 (bytes free)
keepcost: 127664 (bytes in releasable chunk)
generate_files finished
rsync[6437] (generator) heap statistics:
arena: 540672 (bytes from sbrk)
ordblks: 4 (chunks not in use)
smblks: 0
allmem: 942080 (bytes from sbrk + mmap)
usmblks: 0
fsmblks: 0
uordblks: 406288 (bytes used)
fordblks: 134384 (bytes free)
keepcost: 131792 (bytes in releasable chunk)
Number of files: 6 (reg: 3, dir: 3)
Number of created files: 6 (reg: 3, dir: 3)
Number of deleted files: 0
Number of regular files transferred: 3
Total file size: 1.92G bytes
Total transferred file size: 1.92G bytes
Literal data: 1.92G bytes
Matched data: 0 bytes
File list size: 1.02K
File list generation time: 0.001 seconds
File list transfer time: 0.000 seconds
Total bytes sent: 204
Total bytes received: 1.92G
sent 204 bytes received 1.92G bytes 36.56M bytes/sec
total size is 1.92G speedup is 1.00
client_run2 waiting on 6440
[generator] _exit_cleanup(code=0, file=main.c, line=2006): about to call exit(0)
Hinweis: Die Konfiguration des Basic Backup Auftrages wurde gesichert.
Hinweis: Der Remote Server wurde nicht heruntergefahren!
2023-12-10 17:22:07 - Der Datensicherungsauftrag Test ist nun abgeschlossen.
