DSM 7.2 DSM 7.2.1-69057 ist verfügbar
Adama
05. März 2013
Moin, es gibt eine neue DSM Version: 7.2.1-69057
Hier die Release Notes:
(2023-09-26)
Important Note
    After installing this update, you will not be able to downgrade to a previous DSM version.
    This update will restart your Synology NAS.
    For the models below, you can only download the upgrade patch from Synology Download Center because you won't receive notifications for this update on your DSM.
        FS Series: FS3017, FS2017, FS1018
        XS Series: RS18016xs+, RS4017xs+, RS3617xs+, RS3617xs, RS3617RPxs, RS18017xs+, DS3617xs, DS3617xsII, DS3018xs
        Plus Series: RS2416RP+, RS2416+, DS916+, DS716+II, DS716+, DS216+II, DS216+, DS1817+, DS1517+, RS2818RP+, RS2418RP+, RS2418+, RS818RP+, RS818+, DS1618+, DS918+, DS718+, DS218+, RS1219+
        Value Series: DS416, DS416play, DS216, DS216play, DS116, RS816, DS1817, DS1517, RS217, DS418play
        J Series: DS416slim, DS416j, DS216j, DS418j, DS218j, DS419slim, DS119j
What’s New
    NFS clients can now access information on shared folder quotas.
    Storage Manager has been modularized into a package to provide better system maintenance and update flexibility.
    Supports password setting by new users via links provided in emails.
Fixed Issues
    Fixed an issue where Synology Account could not be signed out.
    Fixed a security vulnerability regarding Ghostscript (CVE-2023-36664).
    Fixed a security vulnerability regarding Sudo (CVE-2023-22809).
    Fixed a security vulnerability regarding OpenSSL (CVE-2023-1255).
    Fixed a security vulnerability regarding Zlib (CVE-2023-37434).
Anmerkungen:
    This version is released in a staged rollout.
https://www.synology.com/de-de/releaseNote/DSM?model=DS918+#7_2
Auf meiner DS716+II (die aktuell nicht produktiv genutzt wird) installiert.
Keine Probleme oder Auffälligkeiten.
Frage:
For the models below, you can only download the upgrade patch from Synology Download Center because you won't receive notifications for this update on your DSM. FS Series: FS3017, FS2017, FS1018 XS Series: RS18016xs+, RS4017xs+, RS3617xs+, RS3617xs, RS3617RPxs, RS18017xs+, DS3617xs, DS3617xsII, DS3018xs Plus Series: RS2416RP+, RS2416+, DS916+, DS716+II, DS716+, DS216+II, DS216+, DS1817+, DS1517+, RS2818RP+, RS2418RP+, RS2418+, RS818RP+, RS818+, DS1618+, DS918+, DS718+, DS218+, RS1219+ Value Series: DS416, DS416play, DS216, DS216play, DS116, RS816, DS1817, DS1517, RS217, DS418play J Series: DS416slim, DS416j, DS216j, DS418j, DS218j, DS419slim, DS119j
Warum benachrichtigt Synology denn nicht alle direkt im DSM, dass ein neues Firmware verfügbar ist, das Funktionen verbessert und Sicherheitslücken schließt? Warum bekommen diese Info die "älteren" Modelle denn nicht im DSM?
Reaktionen: *kw*
Da geht es hauptsächlich um Geräte, die auch das Update auf Version 7 nicht anzeigten. Und das hat einen einfachen Hintergrund: Die Performance und empfohlene Leistungsdaten für DSM 7 (1GB RAM)
Hab's grad mal auf der DS1522+ installiert. Bislang keine Probleme. Der Speicher-Manager ist jetzt ein eigenes Paket, aber jetzt kommt der Hammer :mad::
Version: 1.0.0-0017​
(2023-09-26)
Important Notes
  1. S.M.A.R.T. attributes are no longer recorded or displayed.
  2. ...
Ist auch so.
Reaktionen: Iarn
OK, macht Sinn, wenn alte NAS mit DSM6.x dann nur Infos für neue DSM 6.x mit Sicherheitsupdates bekommen.
Aber wenn ein System schon DSM 7.x hat, dann sollte auch die passenden Firmwareupdates angeboten bekommen auf der Oberfläche. Wenigstens ein Hinweis, dass man es manuell installieren kann.
Ist auch so.
Das geht ja gar nicht! Wie komme ich denn jetzt an die Details?
Das ist KrassWürde mich interessieren was Synology damit verfolgt? :unsure:
Keine Ahnung, was die geritten hat.
Mit z.B.
smartctl --all --device ata /dev/sata1
auf der Konsole geht's noch. Nur für NVME ("smartctl --all --device nvme /dev/nvme0n1"?) bekomm ich's momentan nicht hin.
Versuch mal den Befehl "nvme"...
Da gibt es doch bestimmt bald einen findigen Foren-User, der eine GUI dafür als Paket erstellt, oder?! :)
Das oder ähnliches funktioniert bei mir leider nicht.
Wenn ich über
smartctl --all --device scsi /dev/sdb
ODER
smartctl --all /dev/sdb
gehe, bekomme ich folgendes
=== START OF INFORMATION SECTION ===
Vendor:               WDC
Product:              WD30EFRX-68EUZN0
Revision:             0A82
User Capacity:        3,000,592,982,016 bytes [3.00 TB]
Logical block size:   512 bytes
Physical block size:  4096 bytes
LU is fully provisioned
Rotation Rate:        5400 rpm
Logical Unit id:      XXX
Serial number:        XXX
Device type:          disk
Local Time is:        Tue Sep 26 12:18:50 2023 CEST
SMART support is:     Unavailable - device lacks SMART capability.
Current Drive Temperature:     0 C
Drive Trip Temperature:        0 C
Error Counter logging not supported
[GLTSD (Global Logging Target Save Disable) set. Enable Save with '-S on']
Device does not support Self Test logging
"Nicht verfügbar- Gerät ist nicht SMART-fähig." :unsure:
Ja, das kam bei mir auch zuerst. Deine Platten heißen halt sda, adb usw., nicht sata1, sata2 ... wie bei mir. Das "--device ..." ist wichtig.
-d TYPE, --device=TYPE
Specify device type to one of: ata, scsi, nvme[,NSID], sat[,auto][,N][+TYPE], usbcypress[,X], usbjmicron[,p][,x][,N], usbsunplus, marvell, areca,N/E, 3ware,N, hpt,L/M/N, megaraid,N, aacraid,H,L,ID, cciss,N, auto, test
Probier's mal auch mit ata oder sat
Danke für den Tipp, mit smartctl --all --device=ata /dev/sdb hat es geklappt. In deinem Post #8 fehlt das Gleichheitszeichen. Ich hatte einfach nur den Befehl kopiert ohne ihn nochmal zu überprüfen. Das war der Fehler ...
Es geht kürzer. ;-)
sata1:
smartctl -a -d ata /dev/sata1
(weitere LW sind dann sata2, sata3, usw.)
sda:
smartctl -a -d ata /dev/sda
(weitere LW sind dann sdb, sdc, usw.)
nvme:
nvme --smart-log /dev/nvme0
(nvme0 oder nvme1)
lsblk (Aufstellung anzeigen):
lsblk
(Baumformat)
lsblk -l
(Listformat)
Kann #8 leider nicht mehr bearbeiten. Hast aber Recht, lt. Hilfe heißt es entweder "-d ata" oder "--device=ata". Bei gings aber auch ohne =.
@peterhoffmann, ich verwende lieber die längeren Optionen, die sind meist sprechender.
Naja. Beim Öl-Stand am Auto regt sich auch keiner auf das dieser nicht genau angezeigt wird.
Lampe an > Wenig Öl
Lampe aus > Genug Öl
Welch toller Vergleich 👏
