ecoDMS erfahrungsaustausch?
Chief Brody
16. Jul 2021
also vorneweg: bei mir gehen die Exporte bisher alle.
Sagt denn das Server-Log etwas dazu?
Evtl. hilft es dieses mal auf DEBUG zu setzen und den "Fehler" zu provozieren.
jukus100
11. Nov 2021
[TABLE] [TR] [TD]"de.ecodms.plugin.security.storage.endpoint.PostgresqlEndpointImpl | run | 2022-12-14 17:05:24,964 | WARN| [EcoSecurityPlugin:PostgresqlEndpointImpl] addLicenceID: 0 rows inserted." [/TD] [TD]stdout[/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]17:05:27[/TD] [TD]ERROR: "java.lang.NullPointerException\n" [/TD] [TD]stdout[/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]17:05:27[/TD] [TD]ERROR: "\tat de.ecodms.plugin.EcoDMSPreviewPlugin.lockFile(EcoDMSPreviewPlugin.java:870)" [/TD] [TD]stdout[/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]17:05:27[/TD] [TD]ERROR: "\n" [/TD] [TD]stdout[/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]17:05:27[/TD] [TD]ERROR: "\tat de.ecodms.plugin.EcoDMSPreviewPlugin.handleClientRequest(EcoDMSPreviewPlugin.java:170)" [/TD] [TD]stdout[/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]17:05:27[/TD] [TD]ERROR: "\n" [/TD] [TD]stdout[/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]17:05:27[/TD] [TD]ERROR: "\tat de.ecodms.plugin.EcoDMSPreviewPlugin.newMessage(EcoDMSPreviewPlugin.java:134)" [/TD] [TD]stdout[/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]17:05:27[/TD] [TD]ERROR: "\n" [/TD] [TD]stdout[/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]17:05:27[/TD] [TD]ERROR: "\tat de.ecodms.ecoActiveMQConsumer.EcoActiveMQConsumer.onMessage(EcoActiveMQConsumer.java:392)" [/TD] [TD]stdout[/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]17:05:27[/TD] [TD]ERROR: "\n" [/TD] [TD]stdout[/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]17:05:27[/TD] [TD]ERROR: "\tat org.apache.activemq.ActiveMQMessageConsumer.dispatch(ActiveMQMessageConsumer.java:1433)" [/TD] [TD]stdout[/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]17:05:27[/TD] [TD]ERROR: "\n" [/TD] [TD]stdout[/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]17:05:27[/TD] [TD]ERROR: "\tat org.apache.activemq.ActiveMQSessionExecutor.dispatch(ActiveMQSessionExecutor.java:131)\n\tat org.apache.activemq.ActiveMQSessionExecutor.iterate(ActiveMQSessionExecutor.java:202)\n\tat org.apache.activemq.thread.PooledTaskRunner.runTask(PooledTaskRunner.java:133)" [/TD] [TD]stdout[/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]17:05:27[/TD] [TD]ERROR: "\n" [/TD] [TD]stdout[/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]17:05:27[/TD] [TD]ERROR: "\tat org.apache.activemq.thread.PooledTaskRunner$1.run(PooledTaskRunner.java:48)\n\tat java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)\n\tat java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)\n\tat java.lang.Thread.run(Thread.java:750)\n" [/TD] [TD]stdout[/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]17:06:01[/TD] [TD]"de.ecodms.plugin.EcoDMSExporterPlugin | createNewExport | 2022-12-14 17:06:01,243 | WARN| Fehler beim Senden der Antwortnachricht."[/TD] [/TR] [/TABLE]
Diese Fehlermeldung erhalte im im Docker
Chr!s
22. Dez 2021
Hallo zusammen habe vorhin gesehen dass es ein EcoDMS Bugfix update gibt. Insbesondre nachfolgender Punkt interessiert mich seh, konnte aber noch nicht updaten und testen:
  • „Webaccess is permitted only with a valid license.“ Anpassung der Behandlung der Sitzungen
Hat evtl. Schon jemand die Version am laufen und erste Erfahrungen mit dem Webzugang? Oder weiss was geändert wurde? Die Lizenzzählung ist ja nicht gerade zuverlässig und führt nicht nur bei mir zu Frust.
Chief Brody
16. Jul 2021
Hi, bei mir läuft das Update und ich habe nichts zu meckern.
Was genau lief denn bei dir bei der Lizenzzählung nicht zuverlässig. Laut Changelog gab es hier ja nur bei AD Benutzern ein Problem...
Reaktionen: AllinOne
Chief Brody
16. Jul 2021
Was genau exportierst du?
Hast du einen Filter oder Ähnliches?
Hast du mal im Verzeichnis Exports auf dem Server geguckt (workdir, glaube ich), ob sich da was tut?
jukus100
11. Nov 2021
Dokumente exportieren.
Hab schon alles probiert. Von allen Dokumenten bis hin zu einem einzigen.
Da tut sich absolut nichts.
Chr!s
22. Dez 2021
Hi also z.B. wird immer wieder die Lizenz blockiert gerade wenn man mobil bzw. per Webzugriff in EcoDMS drin ist und sich nicht korrekt ausloggt. Ist für unseren Anwendungsfall häufig so gerade wenn man unterbrochen wird. z.B. wenn man während der Nutzung einen Anruf bekommt und dran geht. Springt man wieder in den Browser muss man sich wieder einloggen aber erhält dann den Fehler dass die Lizenz gerade benutzt wird bzw. nicht mehr frei ist. Ähnlich wenn man lokal arbeitet und vergisst sich abzumelden. Geht der Rechner in den Ruhezustand bleibt die Lizenz trotzdem blockiert. Wünschen würde ich mir eine Lösung dass man automatisch überall ausgelaugt wird wenn man sich mit dem gleichen Benutzer neu anmeldet.
Reaktionen: Holli_NOM
myssv
27. Okt 2019
Auf welchem System arbeitet denn ecoDMS bei Dir? Hast Du mal geprüft, ob Du da überhaupt Schreibrechte in dem Exportordner hast?
Bei mir auf einer Synology ist es dieser Ordner
jukus100
11. Nov 2021
Hab die Berechtigungen noch einmal neu gesetzt, Jtzt wird zwar ein Ordner angelegt, allerdings bleibt dieser leer und die Fehlermeldung gleich.
myssv
27. Okt 2019
Dann wären jetzt ein paar detaillierte Infos hilfreich. Wo hast Du welche Änderungen neu gesetzt und welche Ordner wurden danach angelegt?
Ich denke es ist ein grundsätzliches Rechteproblem bei Dir und kein Problem von ecoDMS!
Reaktionen: servilianus
jukus100
11. Nov 2021
Das sind die Rechte im exports ordner. GLeiche Rechte gilt auch für workdir und ecodmsdata
Diese Ordner wurden angelegt. Sind jedoch leer.
myssv
27. Okt 2019
Laut Handbuch braucht das Programm den kompletten Zugriff auf den kompletten ecoDMS Ordner und nicht nur auf den Export Ordner.
servilianus
26. Dez 2017
Ausserdem wäre zu prüfen, ob derjenige, der sich in ecoDMS angemeldet hat, und den Export durchführen will, innerhalb ecoDMS das entsprechende Recht hat (Rolle Export)
jukus100
11. Nov 2021
Also ich habe die Berechtigungen in Ecodms gecheckt. Da ich mit dem Admin Account arbeite, sollten ja schon alle Rechte vorhanden sein. MIr ist aber kein spezielles Export Recht aufgefallen, was ich hätte hinzufügen könnte.
Berechtigungen sind jetzt komplett für EcoDMS und den Ordner ecodmsData gesetzt mit "everyone".
Alles bleibt beim alten. Im Exportordner wird ein Ordner angelegt, dieser bleibt allerdings leer.
myssv
27. Okt 2019
Wenn Du erst im Nachhinein die Rechte korrekt vergeben hast, dann würde ich eine komplette Neuinstallation vorschlagen.
Mache eine Datensicherung und sicher die Daten weg. Im Anschluss alles löschen und dann nach Anleitung komplett neu installieren. Anschließend die Daten zurück sichern.
servilianus
26. Dez 2017
Oder: Ich würde mir bei den ecoDMS-Jungs ein Mini-Support-Ticket buchen. Kostet glaube ich 25 Euro für eine Viertelstunde Support. Die schalten sich per Teamviewer auf, schauen sich das an und stellen entsprechend um. Die sind sehr engagiert und man bekommt noch am gleichen Tag einen Support-Termin. Haben mir auch schon so weiterhelfen können.
jukus100
11. Nov 2021
So, ch hab ecoDMS jetzt mal geschrieben. Mal gucken, wann die antworten.
Nach mehrfachem NEustart des Containers hat übrigens ein Export geklappt. Dachte kurzzeitig, dass es nun funktioniert. Pustekuchen. Jetzt bleibt es immer bei "Daten packen" stehen...
Er legt ein paar Daten im Export Ordner an (im KB Bereich) und das wars.
Also an Schreibrechten kann es dann doch nicht wirklich liegen.
myssv
27. Okt 2019
Das "packen" kann durchaus einige Minuten dauern. Bei mir sind es so ca. 30 Minuten.
Aber da muss wirklich ein Techniker ran. Grundsätzlich funktioniert die Funktion.
Reaktionen: jukus100
jukus100
11. Nov 2021
Ok, ich habe es jetzt anders gelöst. Mir war nicht bewusst, dass ich die Dokumente per Drag and Drop aus dem Client ziehen konnte. Das hat jetzt zumindest für sämtliche PDF Dateien funktioniert.
servilianus
26. Dez 2017
oder im Client-Archiv: Listenansicht - 1. pdf markieren - letzte pdf markieren (dann werden alle dazwischen blau / markiert) - dann im Menü oben links auf Download... alle markierten werden im einem Rutsch heruntergeladen.
