Backup via autorun
bernd_
29. Apr. 2014
Ich denke dass der Backup Job auf meiner DS nur läuft aber nichts sichert, zumindest nicht dahin wo er sollte,
auf die externe Festplatte welche via USB angeschlossen ist...
autorun script finished, 1,6 T left on /volumeUSB1/usbshare
Systemereignis completed Data backup on DiskStation
jedoch so wie ich das sehe wird nichts gesichert, checked via winscp:
Tips?
autorun log:
2015-12-08 00:31:28: autorun installed
2015-12-08 00:31:29: autorun activated
2016-01-12 13:59:45: device 'sds1' - event received from udev DEVNAME=/dev/sds1 ACTION=add ID_PART_ENTRY_UUID=f7103169-503d-42dc-bcaa-bc323497f149 USEC_INITIALIZED=5543484762 SEQNUM=1489 ID_PART_ENTRY_SIZE=7814031809 MAJOR=65 ID_FS_UUID_ENC=554d75f0-cd11-4309-99b1-46918407b0c4 ID_FS_LABEL_ENC=1.42.6-5644 SYNO_DEV_DISKPORTTYPE=USB ID_FS_UUID=554d75f0-cd11-4309-99b1-46918407b0c4 DEVPATH=/devices/pci0002:04/0002:04:00.0/0002:05:00.0/usb2/2-3/2-3:1.0/host18/target18:0:0/18:0:0:0/block/sds/sds1 ID_PART_ENTRY_SCHEME=gpt ID_FS_LABEL=1.42.6-5644 ID_PART_ENTRY_TYPE=0fc63daf-8483-4772-8e79-3d69d8477de4 ID_FS_VERSION=1.0 SUBSYSTEM=block PHYSDEVPATH=/devices/pci0002:04/0002:04:00.0/0002:05:00.0/usb2/2-3/2-3:1.0/host18/target18:0:0/18:0:0:0 MINOR=33 ID_FS_TYPE=ext4 SYNO_PLATFORM=qoriq PHYSDEVDRIVER=sd ID_PART_ENTRY_OFFSET=256 ID_PART_ENTRY_DISK=65:32 PWD=/ PHYSDEVBUS=scsi ID_PART_ENTRY_NUMBER=1 DEVTYPE=partition ID_FS_USAGE=filesystem SYNO_KERNEL_VERSION=2.6
2016-01-12 13:59:45: device 'sds1' - inserted, trying to find mount point
2016-01-12 13:59:49: device 'sds1' - mount point '/volumeUSB1/usbshare' found
2016-01-12 13:59:49: device 'sds1' - script '/volumeUSB1/usbshare/autorun' found, executing
2016-01-12 14:00:00: device '/volumeUSB1/usbshare' - local backup '1' started
2016-01-12 16:45:36: device '/volumeUSB1/usbshare' - local backup '1' finished
2016-01-12 16:45:36: device 'sds1' - script '/volumeUSB1/usbshare/autorun' finished (1.6T left on device), starting unmount
2016-01-12 16:45:42: device 'sds1' - unmounted and ejected
Eigentlich stößt autorun nur das Backup an, was es laut log scheinbar ja tut. Auch lief das Backup 1:45 Stunde, da sollte ja schon was rüberkopiert worden sein. Wieso schaust du dir das Backup eigentlich mit WinSCP an?
Tommes
eben das verstehe ich ja nicht, tommes, ich hätte ja auch erwartet dass daten kopiert werden in der zeit...
ich kann natürlich auch im datei explorer schauen, siehe attach..
oder mache ich etwas falsch und sehe die daten nur nicht?
nö, die sind nicht da o.O
Zeig mal den Detailansicht des Backupziels.
.. sollte da unten eine "ID" stehen?
Da sollte was stehen, ja :confused:
Was passiert, wenn du den backupjob manuell anstößt?
Sonst schreib mal den Synology-Support an (Hauptmenü->Support), ohne Zugriff auf deine Kiste ist das sonst ein reines Ratespiel
Bei mir steht dort auch keine ID und die Sicherung funktioniert über autorun.
Dort steht wohl nur eine ID, wenn das Sicherungsziel erreichbar/verbunden ist?
Im Screenshot von WinSCP steht unten rechts "1 hidden".
Vielleicht ist dein Ordner nur nicht sichtbar?
Prüf den Ordner doch mal per File Station Oberfläche.
dsm file station
-->> Siehe #3 in diesem Thread... da ist ein Screenshot von der File Station Oberfläche.
Wie kann ich den hidden Folder sichtbar machenm, bin doch als root bei winscp schon angemeldet gewesen...:>))
-- ob man bei synology support bekommt, autorun ist ja kein offizielles dsm packet oder?
Darum ja die Frage nach dem manuellen anstoßen- wenn es da auch auftritt ist es kein autorun-problem.
@bird: die platte ist im screenshot ja angeschlossen ;)
Das sieht gut aus.
Hast du das Paket Antivirus auf der DS installiert?
Mich wunderte die Bezeichnung des Unterordners von usbshare1: @Quaratine
Edit: Das neue sieht schon viel besser aus
scheint also bei manuellem Backup zu klappen..
Was genau macht autorun? ich dachte das automatische mounten der Platte beim einstecken der usb externen Platte und dismounten nach Backup-Ende?
Da ich jetzt ja eine Mischung aus autorun und Manuell gemacht habe..:
Wie kann ich denn manuell "mounten" und "dismounten" in meinem Fall ? auf die DS via putty und mount:....? wie müsste da der Befehl in meinem Falle genau lauten?
Falls es also doch am automount Packet liegen sollte, woran genau könnte es dann liegen?
@winka, sehe ich auch so dass es besser ausschaut...:>)) *happy* mal soweit wengistens.
- JA habe ich, AV installirt und scan läuft auch regelmässig.. er hat auch mal was gefunden, all files safely handled oder in der Art war die Meldung.
jetzt läuft aber was ganz schief?
Kann mich nicht mehr an der DS anmelden, zu wenig Speicherplatz, nach Restart nochmal versuchen?
Er speichert also scheinbar lokal auch noch etwas der Sicherung ab?
Wie soll ich weiter vorgehen?
Restarten?
Dabei waren vor wenigen Tagen erst 70% der Hauptplatten belegt.
- via putty komme ich noch drauf
Zieh mal die USB-Platte ab, logge dich via putty ein und poste hier den output von ls -lah /
vermutlich stimmt da was mit deinem sicherungsziel nicht, hast du die platte an verschiedenen USB-Slots angesteckt? Oder immer am selben?
…und schmeiß das schlangenöl runter, die dinger helfen genau gar nix und machen nur probleme. Wenn du ein AV willst, nutze Brain2.exe
bin leider nicht vor Ort,
hier mal der df-h, das dürfte ja die Hauptplatte dann sein?
DiskStation> df -h
Filesystem Size Used Avail Use% Mounted on
/dev/root 2.4G 2.4G 0 100% /
/tmp 252M 1.4M 251M 1% /tmp
/run 252M 15M 237M 6% /run
/dev/shm 252M 0 252M 0% /dev/shm
/dev/vg1000/lv 3.6T 2.3T 1.4T 63% /volume1
DiskStation>
ohne entfernen der usb platte:
DiskStation> ls -lha
drwxrwxrwx 6 admin users 4.0K Jan 13 12:06 .
drwxr-xr-x 4 root root 4.0K Jan 16 09:14 ..
drwxrwxrwx 4 admin users 4.0K Jan 12 15:42 AAAA
drwxr-xr-x 34 root root 4.0K Jan 16 09:17 CI....(geändert)
drwxrwxrwx 31 admin users 8.0K Aug 19 19:46 Gags
drwxrwxrwx 4 admin users 4.0K Dec 24 22:03 Privat
DiskStation>
ist das jetzt die usb platte oder die hauptplatte?
- USB Slots.. kann ich nicht mit Sicherheit sagen...
Das ist die interne Platte, auf die das Backup geschrieben wurde, so dass die Systempartition vollgelaufen ist. Per du -h / wirst Du das Verzeichnis finden, das Du dann per rm -r /<Verzeichnisname> löschen kannst. Die USB-Platte ist nicht korrekt gemountet.
Hm, joa, deine Systempartition ist rappelvoll.
da müsstest du dich dann mal durch die Ordnerstruktur suchen und schauen welcher Ordner da so explodiert ist…
Es wird sehr wahrscheinlich der /volumeUSB1 Ordner sein.. Aber vorher die usb platte sbziehen :)
wenn ich auf die volume1 disk gehe, das sollte ja die orginalplatte sein.. dann kann ich zwar via cd in die verzeichnisse wechseln und sehe die ordnerstruktur dann auch, kann aber via cd nicht IN eines der Verzeichnisse wechseln?
Ich wollte nachschauen ob die Originaldateien noch vorhanden sind..:>)
