DSM 5.1 Beta (4977) - Erfahrungen, Probleme, Bugs
geimist
Add-on Developer
04. Jan. 2012
Hier alle Erfahrungen, Probleme, Bugs MIT der DSM 5.1 Beta
Aus den Release Notes:
Einschränkungen:
Weather in DSM login page, Time Backup, and CIFS Scale-Out Cluster will neither be available nor supported in DSM 5.1
Known Issues:
  • Cloud Sync might fail to perform initial sync with a Box.com account containing over 100,000 files.
  • Due to Box.com API limitation, Cloud Sync is unable to track the files in a folder when it is copied? or shared with another Box.com account? .? However, file changes that take place afterwards will be properly synced.?
  • Cloud Sync does not support folders that share the same name in Box.com.
  • The current backup of SFR only supports single files smaller than 2GB. When a backup task contains files larger than 2GB, the backup result will report failure even though the other files smaller than 2GB are successfully backed up. Details can be found in the backup log.
  • Packages could fail to install if the version is not the latest (Beta package is considered the latest version if it is available) due to the newly implemented Trust Level feature. If you see an error message showing that “This package does not contain a digital signature” when installing a package, you may temporarily lower the security level in Settings of Package Center to resolve this.
  • Due to the change that Python is now built-in, packages use Python as the framework might not work normally. Reinstallation of the package could resolve this issue.
  • Downgrading Audio Station package from DSM 5.1 beta version to former versions might result in browsing issues with personal libraries.
  • DS cloud will stop syncing after upgrading to DSM 5.1 beta.
Zumindest die Installation auf einer DS212+ hat funktioniert.
Update ging schmerzfrei über die Bühne (DS213j 2x 3GB WD-Reds). Habe das Gefühl es läuft alles etwas flotter.
Negativ Punkte:
- Firewall Regeln wurden alle gelöscht (alles neu machen...seufz...)
- Camera an der Haustür wird nicht mehr erkannt
- noch! keine Android Apps verfügbar
Positiv Punkte:
- DSM läuft (gefühlt) schneller, Programme öffnen schneller
- Sicherheitsberater
mal sehen was die Tage so bringen, bisher eigentlich recht positiv das Update
DS212+ (ARM):
DiskStation> uname -a
Linux DiskStation 2.6.32.12 #4977 Sat Sep 20 02:15:37 CST 2014 armv5tel GNU/Linux synology_88f6282_212+
Leider immer noch kein Kernel Upgrade. :(
Aber dafür wurde endlich OpenSSH upgegraded. :)
Bei mir funktioniert der "Directory Server" nicht mehr.
Will ich den LDAP-Server wieder aktivieren kommt die Meldung "Fehler bei Verbindung mit LDAP-Server. Prüfen Sie die Serveradresse und Ihre Netzwerkeinstellungen.
In dem Bereich wurde aber keine Änderung durchgeführt....
Gruß Jörg
Wie ist den die neue Video Station hat die sich schon jemand angeschaut. Soll ja ein neuen style und Funktionen haben.
Hi zusammen,
bei mir lief das Update auch problemlos auf meiner DS 713+.
Beim Sicherheitscheck wurde jedoch eine Bedrohung angezeigt. Die Systemdateien seien geändert
worden. Hatte von DSM 5.0 Update5 (also aktuell) upgedatet. Kann es sein dass der Systemcheck
irrtümlich die Systemdateien verdächtigt?
Wäre jemand so freundlich und würde den Sicherheitschek mal machen?
Danke und viele Grüße
Peter
Schon 9 feature requests eingereicht, u.a. Kernel Upgrade (2.6.32 ist bald out of support)
@peter2014: bei mir gibts nur Probleme bei Konto, Netzwerk, Einstellungen. Ist aber alles nicht so heftig, was da angezeigt wird bei mir.
Hi zusammen,
Peter
Hat ich auch beim 1. Durchlauf aber dann hab ich Antivirus Essential upgedatet und durchlaufen lassen, danach war die Warnung im Sicherheitsberater weg.
Eventuell hilft dir das ja
Wahnsinn, raymond, richtig klasse. Vielen Dank dafür!
Danke Euch, ann probiere ich das auch mal mit "Antivirus Essential"
Grüßle
Gibt es die beta schon auf einem Testserver von Synology? Mich interessiert vor allem, ob sich etwas für Screen Reader Nutzer getan hat.
