Dit werkte bij mij:
First off, you must log in as an adminstrator.
Note: If prompted for your administrator password after a command, enter it and then press the Return or Enter key.
Go to Applications > Utilities and then open Terminal. Enter the following command, and press the Return or Enter key:
sudo mkdir -p /Library/Internet\ Plug-Ins/disabled
sudo mv /Library/Internet\ Plug-Ins/JavaAppletPlugin.plugin /Library/Internet\ Plug-Ins/disabled
sudo ln -sf /System/Library/Java/Support/Deploy.bundle/Contents/Resources/JavaPlugin2_NPAPI.plugin /Library/Internet\ Plug-Ins/JavaAppletPlugin.plugin
So nun läuft es bei mir. Ich habe die Java 7.11 deinstalliert und die Version Java for OS X 2012-006 wieder neu installiert. Dann bin ich wie folgt vorgegangen und siehe da, es läuft perfekt:
For Mac Safari:
Make sure your Mac OS X is updated to version 10.6 or onward and Safari is updated to version 5.1 or onward.
Go to Apple menu > Software Update and check for any possible Java updates to make sure your Java applet is up-to-date.
Note:
For users without Java for OS X 2012-006 upgrade patch, please go to Applications > Utilities, and then open Java Preferences to do the following:
On the list of Java applications, make sure the version of Java SE is 1.6.0_26 or onward (excluding 1.7.x).
Please make sure 64-bit version of Java SE is on top of the application list (above 32-bit).
If you are using Mac OS X 10.7 or onward, tick Enable applet plug-in and Web Start applications.
If you encountered compatibility issues with Java applet version, the cause may be the Java for OS X 2012-006 upgrade.
Please visit Apple Support, and rollback your Java applet version to 1.6.
Or, you can execute the following commands:
Gruß, Wellenreiter 48
Bei mir geht es nun auch nicht mehr, Apple hat Java "ausgesperrt". http://www.mactechnews.de/news/arti...-in-Browser-mithilfe-von-XProtect-154978.html
sudo nano /System/Library/CoreServices/CoreTypes.bundle/Contents/Resources/XProtect.meta.plist2.
<string>1.6.0_37-b06-434</string>
