Über die Synocommunity wird TvHeadEnd angeboten.
Kann ich mir jetzt einen beliebigen DVB-C/T/S/was-auch-immer Stick holen und der funktioniert dann? oder muss ich mich an die kompabiblitätsliste von Synolgoy halten? Habe übrigens (noch) eine DS211j
Tvheadend is a TV streaming server for Linux supporting DVB-S, DVB-S2, DVB-C, DVB-T, ATSC, IPTV and Analog video (V4L) as input sources. It also comes with a powerful and easy to use web interface both used for configuration and day-to-day operations, such as searching the EPG and scheduling recordings. Even so, the most notable feature of Tvheadend is how easy it is to set up: Install it, navigate to the web user interface, drill into the TV adapters tab, select your current location and Tvheadend will start scanning channels and present them to you in just a few minutes
, vermute eher das HarryPotter da etwas anderes meinte?
