- 30. Juni 2015
- BeitrÀge
- 3.538
sudo -i
ls /var/packages/Synospeedtest/target/bin/armv71
/var/packages/Synospeedtest/target/bin/armv71/speedtest --version
sudo -i
/var/packages/Synospeedtest/target/bin/aarch64/speedtest --version
/var/packages/Synospeedtest/target/bin/armel/speedtest --version
/var/packages/Synospeedtest/target/bin/armhf/speedtest --version
/var/packages/Synospeedtest/target/bin/i386/speedtest --version
/var/packages/Synospeedtest/target/bin/x86_64/speedtest --version
[root@CAESAR] ~ > ls /var/packages/Synospeedtest/target/bin/armv71
speedtest speedtest.5 speedtest.md
[root@CAESAR] ~ > /var/packages/Synospeedtest/target/bin/armv71/speedtest --version
Speedtest by Ookla 1.2.0.84 (ea6b6773cf) Linux/arm-linux-musleabihf 3.10.108 arm/armv7l
The official command line client for testing the speed and performance
of your internet connection.
[root@CAESAR] ~ >
[root@CAESAR] ~ > /var/packages/Synospeedtest/target/bin/armel/speedtest --version
Speedtest by Ookla 1.2.0.84 (ea6b6773cf) Linux/arm-linux-musleabi 3.10.108 arm/armv7l
[root@CAESAR] ~ > /var/packages/Synospeedtest/target/bin/armhf/speedtest --version
[root@CAESAR] ~ >
[root@KLEOPATRA] ~ > ls /var/packages/Synospeedtest/target/bin/armv71
[root@KLEOPATRA] ~ > /var/packages/Synospeedtest/target/bin/armv71/speedtest --version
[root@KLEOPATRA] ~ > /var/packages/Synospeedtest/target/bin/armel/speedtest --version
[root@KLEOPATRA] ~ > /var/packages/Synospeedtest/target/bin/armhf/speedtest --version
sudo -i
/var/packages/Synospeedtest/target/bin/armhf/speedtest -L
/var/packages/Synospeedtest/target/bin/armel/speedtest -L
sudo cat /var/packages/Synospeedtest/var/install.log | tail -15
sudo cat /var/packages/Synospeedtest/var/last_speedtest_stderr.log
sudo cat /var/packages/Synospeedtest/var/servers.list
sudo cat /var/packages/Synospeedtest/var/api.log | tail -20
[root@CAESAR] ~ > cat /var/packages/Synospeedtest/var/install.log | tail -15
[2026-03-17 08:17:47] Set execute permissions for api.cgi
[2026-03-17 08:17:47] Post-installation completed successfully
[2026-03-17 08:52:25] Post-installation starting for package: Synospeedtest
[2026-03-17 08:52:25] VAR_DIR created or already exists: /var/packages/Synospeedtest/var
[2026-03-17 08:52:25] Created web interface symlink
[2026-03-17 08:52:25] Created armv71 symlink to armhf
[2026-03-17 08:52:25] Created armv7 symlink to armhf
[2026-03-17 08:52:25] Created armv5tel symlink to armel
[2026-03-17 08:52:25] Created armv5 symlink to armel
[2026-03-17 08:52:25] Created i686 symlink to i386
[2026-03-17 08:52:25] Created result directory: /usr/syno/synoman/webman/3rdparty/Synospeedtest/result
[2026-03-17 08:52:25] Set execute permissions for api.cgi
[2026-03-17 08:52:25] Post-installation completed successfully
[root@CAESAR] ~ > cat /var/packages/Synospeedtest/var/last_speedtest_stderr.log
[root@CAESAR] ~ > cat /var/packages/Synospeedtest/var/servers.list
[root@CAESAR] ~ > cat /var/packages/Synospeedtest/var/api.log | tail -20
[2026-03-16 15:44:51] Request: ACTION=run, OPTION=[]
[2026-03-16 15:44:52] [ERROR] Speed Test failed
[2026-03-17 08:18:04] Request: ACTION=servers, OPTION=[]
[2026-03-17 08:18:04] Request: ACTION=info, OPTION=[]
[2026-03-17 08:18:04] [DEBUG] Fetching server list
[2026-03-17 08:18:04] [DEBUG] Getting system information
[2026-03-17 08:18:05] [ERROR] servers.sh completed but servers.list is empty
[2026-03-17 08:18:05] Request: ACTION=getservers, OPTION=[]
[2026-03-17 08:18:12] Request: ACTION=run, OPTION=[]
[2026-03-17 08:18:16] [ERROR] Speed Test failed
[2026-03-17 08:52:34] Request: ACTION=servers, OPTION=[]
[2026-03-17 08:52:34] Request: ACTION=info, OPTION=[]
[2026-03-17 08:52:34] [DEBUG] Fetching server list
[2026-03-17 08:52:34] [DEBUG] Getting system information
[2026-03-17 08:52:35] [ERROR] servers.sh completed but servers.list is empty
[2026-03-17 08:52:35] Request: ACTION=getservers, OPTION=[]
[2026-03-17 08:52:37] Request: ACTION=run, OPTION=[]
[2026-03-17 08:52:40] [ERROR] Speed Test failed
[2026-03-17 08:52:59] Request: ACTION=run, OPTION=[]
[2026-03-17 08:53:03] [ERROR] Speed Test failed
[root@CAESAR] ~ >
[root@KLEOPATRA] ~ > cat /var/packages/Synospeedtest/var/install.log | tail -15
[2026-03-17 08:18:41] Set execute permissions for api.cgi
[2026-03-17 08:18:41] Post-installation completed successfully
[2026-03-17 08:52:22] Post-installation starting for package: Synospeedtest
[2026-03-17 08:52:22] VAR_DIR created or already exists: /var/packages/Synospeedtest/var
[2026-03-17 08:52:22] Created web interface symlink
[2026-03-17 08:52:23] Created armv71 symlink to armhf
[2026-03-17 08:52:23] Created armv7 symlink to armhf
[2026-03-17 08:52:23] Created armv5tel symlink to armel
[2026-03-17 08:52:23] Created armv5 symlink to armel
[2026-03-17 08:52:23] Created i686 symlink to i386
[2026-03-17 08:52:23] Created result directory: /usr/syno/synoman/webman/3rdparty/Synospeedtest/result
[2026-03-17 08:52:23] Set execute permissions for api.cgi
[2026-03-17 08:52:23] Post-installation completed successfully
[root@KLEOPATRA] ~ > cat /var/packages/Synospeedtest/var/last_speedtest_stderr.log
[root@KLEOPATRA] ~ > cat /var/packages/Synospeedtest/var/servers.list
[root@KLEOPATRA] ~ > cat /var/packages/Synospeedtest/var/api.log | tail -20
[2026-03-16 15:44:29] Request: ACTION=run, OPTION=[]
[2026-03-16 15:44:31] [ERROR] Speed Test failed
[2026-03-17 08:18:58] Request: ACTION=info, OPTION=[]
[2026-03-17 08:18:58] Request: ACTION=servers, OPTION=[]
[2026-03-17 08:18:58] [DEBUG] Fetching server list
[2026-03-17 08:18:58] [DEBUG] Getting system information
[2026-03-17 08:18:59] [ERROR] servers.sh completed but servers.list is empty
[2026-03-17 08:18:59] Request: ACTION=getservers, OPTION=[]
[2026-03-17 08:19:03] Request: ACTION=run, OPTION=[]
[2026-03-17 08:19:06] [ERROR] Speed Test failed
[2026-03-17 08:52:46] Request: ACTION=servers, OPTION=[]
[2026-03-17 08:52:46] Request: ACTION=info, OPTION=[]
[2026-03-17 08:52:46] [DEBUG] Getting system information
[2026-03-17 08:52:46] [DEBUG] Fetching server list
[2026-03-17 08:52:47] [ERROR] servers.sh completed but servers.list is empty
[2026-03-17 08:52:47] Request: ACTION=getservers, OPTION=[]
[2026-03-17 08:52:51] Request: ACTION=run, OPTION=[]
[2026-03-17 08:52:54] [ERROR] Speed Test failed
[2026-03-17 08:53:02] Request: ACTION=run, OPTION=[]
[2026-03-17 08:53:05] [ERROR] Speed Test failed
cat /var/packages/Synospeedtest/var/api.log | tail -n 15
cat /var/packages/Synospeedtest/var/last_servers_stderr.log
DS215+If it fails again can you show
[root@CAESAR] ~ > cat /var/packages/Synospeedtest/var/api.log | tail -n 15
[2026-03-17 20:48:32] Request: ACTION=servers, OPTION=[]
[2026-03-17 20:48:32] Request: ACTION=init, OPTION=[]
[2026-03-17 20:48:32] ----------------------------------------
[2026-03-17 20:48:32] [DEBUG] Fetching server list
[2026-03-17 20:48:32] [DEBUG] Getting system information
[2026-03-17 20:48:32] Web UI opened/refreshed
[2026-03-17 20:48:32] [DEBUG] speedtest exit code: 127
[2026-03-17 20:48:32] [DEBUG] raw output (all 1 lines):
[2026-03-17 20:48:32] [DEBUG] raw:
[2026-03-17 20:48:32] [DEBUG] stderr: timeout: failed to run command '/var/packages/Synospeedtest/target/bin/armv7l/speedtest': No such file or directory
[2026-03-17 20:48:32] [ERROR] 'speedtest --servers' failed with exit code 127
[2026-03-17 20:48:34] Request: ACTION=getservers, OPTION=[]
[2026-03-17 20:48:48] Request: ACTION=run, OPTION=[]
[2026-03-17 20:48:55] [ERROR] Speed Test failed:
[2026-03-17 20:48:55] [ERROR] "Unknown error or no error output"
[root@CAESAR] ~ > cat /var/packages/Synospeedtest/var/last_servers_stderr.log
[root@CAESAR] ~ >
[root@KLEOPATRA] ~ > cat /var/packages/Synospeedtest/var/api.log | tail -n 15
[root@KLEOPATRA] ~ > cat /var/packages/Synospeedtest/var/last_servers_stderr.log
cat: /var/packages/Synospeedtest/var/last_servers_stderr.log: No such file or directory
Ich muĂ Euch beiden jetzt mal ein Lob aussprechen,
Interesting. That looks like an L instead of one in armv71. If it is then that has been the issue all along...'/var/packages/Synospeedtest/target/bin/armv7l/speedtest': No such file or directory
Yep, I had a fix in api.cgi on my Synology but it was not in the git repo so when pushedThe Serverlist-DropDown-Menu on both Machines is empty again![]()
uname -m
DS215+ armv7l
DS415+ x86_64
DS916+ x86_64
DS116 armv7l
DS118 aarch64
Wenn du das Forum hilfreich findest oder uns unterstĂŒtzen möchtest, dann gib uns doch einfach einen Kaffee aus.
