Does speedtest-cli output in Deutsch when you run it?
Hello
Thanks for the update.
I'm using the DS423+.
Unfortunately, the error still occurs after the update.
I'll test your commands via SSH this afternoon when I get home.
Just so you know, I live in Switzerland, if that's relevant to the package.
Thanks.
Version 1.08
Error: Speedtest failed
and could not load server list
Edit:
root@DS920plus:~# cat /var/packages/Synospeedtest/var/servers.list
cat: /var/packages/Synospeedtest/var/servers.list: No such file or directory
I just installed it on my DS925+ and am getting the same error. It seems like when I was developing the package on my DS1821+ I created a file, or set permissions on a file or folder to get it working... and this step is missing on a new installation. I'll figure it out, but it's time for dinner here so it'll have to wait until tomorrow.
Here's something for you to look forward to for tomorrow.
I know what the problem is:
root@DS925plus:~# cat /var/packages/Synospeedtest/var/last_speedtest_stderr.log
We trust you have received the usual lecture from the local System
Administrator. It usually boils down to these three things:
    #1) Respect the privacy of others.
    #2) Think before you type.
    #3) With great power comes great responsibility.
sudo: a terminal is required to read the password; either use the -S option to read from standard input or configure an askpass helper
sudo: a password is required
/var/packages/Synospeedtest/var/api.log contains the same thing (but without line break so less readable).
Now I just have to remember how I solved it on my DS1821+, and add that solution in the package.
I'm using V1.0.8 and have a little Problem ;)
At Console i ran the script 'servers.sh' but this doesn't help :(
Any hints?
Ok, the speedtest command won't run without sudo and DSM 7 does not allow packages to have elevated privileges.
So the solution is after installing the package the first time run the following via SSH:
sudo -i
echo "Synospeedtest ALL=(ALL) NOPASSWD: ALL" > /etc/sudoers.d/Synospeedtest
chmod 0440 /etc/sudoers.d/Synospeedtest
or in Task Scheduler create a "User defined script" task set to run as root containing:
Run the schedule task then delete the scheduled task.
@DaveR
Hi
It still doesn't seem to be working with the task in Task Scheduler.
I'll test the SSH method later and let you know.
Just installed V1.0.8 on my DS1522+ too and get the same error.
In the install.log there is a message:
[2026-03-13 11:19:45] Sudoers file created and permissions set: /etc/sudoers.d/speedtest
but under /etc/sudoers.d there is no "speedtest". May this cause this error?
Edit: I've seen #31 to late.
1.0.9 doesn't work :confused:
No Serverlist in DropDown present ...
On Console, it works ...
Did you run the following via SSH?
sudo -i
Yes, of course :)
Some is courios ...
Only root should have access?
Got it
sudo -i
instead of "Synosmartinfo"
Edit: I saw this line in install.log
[2026-03-13 11:51:05] Sudoers file created and permissions set: /etc/sudoers.d/Synospeedtest
but the file didn't exist
o_O
I think, there is a typo in Dave's Script ...
Synospeedtest <=> Synosmartinfo !!!
