- 17. Apr. 2013
kann bitt ejemand noch einen Gegencheck machen?
Keine Ahnung was da nicht gut sein soll, heute wurde die RS vorgefunden piepend, die Platte 1 hat sich aus dem Speicherpool verabschiedet, aber ich sehe da keinen Grund dazu. Jetzt ist alles am repair
Note es sind 'original' Syno Platten drin
smartctl 6.5 (build date Sep 26 2022) [x86_64-linux-4.4.302+] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: HAT3300
Device Model: Synology HAT3300-8T
Serial Number: ZPV01BPY
LU WWN Device Id: 5 000c50 0e6db5d93
Firmware Version: PL01
User Capacity: 8,001,563,222,016 bytes [8.00 TB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Rotation Rate: 5400 rpm
Form Factor: 3.5 inches
Device is: In smartctl database [for details use: -P show]
ATA Version is: ACS-3 T13/2161-D revision 5
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Mon Dec 9 11:39:21 2024 CET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 0) seconds.
capabilities: (0x73) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
No Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 1) minutes.
Extended self-test routine
recommended polling time: ( 897) minutes.
Conveyance self-test routine
recommended polling time: ( 2) minutes.
SCT capabilities: (0x70bd) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 10
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Error_Rate 0x000f 100 064 006 Pre-fail Always - 0
3 Spin_Up_Time 0x0003 092 091 000 Pre-fail Always - 0
4 Start/Stop_Count 0x0032 100 100 020 Old_age Always - 16
5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 079 060 045 Pre-fail Always - 73321583
9 Power_On_Hours 0x0032 088 088 000 Old_age Always - 11211
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Drive_Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 15
183 PHY_Counter_Events 0x0032 100 100 000 Old_age Always - 0
184 Reported_IOEDC_Errors 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrectables 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeouts 0x0032 100 100 000 Old_age Always - 0
189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0
190 Airflow_Temperature 0x0022 056 053 040 Old_age Always - 44 (Min/Max 42/44)
191 Shock_Count 0x0032 100 100 000 Old_age Always - 0
192 Emergency_Retract_Count 0x0032 100 100 000 Old_age Always - 435
193 Load/Unload_Count 0x0032 100 100 000 Old_age Always - 483
194 Temperature 0x0022 044 047 000 Old_age Always - 44 (0 28 0 0 0)
195 ECC_On_the_Fly_Count 0x001a 100 064 000 Old_age Always - 0
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Uncorrectable_Sectors_Count 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
240 Head_Flight_Hours 0x0000 100 253 000 Old_age Offline - 120959163968445
241 Lifetime_Writes_From_host 0x0000 100 253 000 Old_age Offline - 8803191934
242 Lifetime_Reads_From_Host 0x0000 100 253 000 Old_age Offline - 207783658030
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
No self-tests have been logged. [To run self-tests, use: smartctl -t]
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
Serial Number: ZPV01BQB
LU WWN Device Id: 5 000c50 0e6db5f17
was never started.
been run.
command.
power-saving mode.
recommended polling time: ( 899) minutes.
1 Raw_Error_Rate 0x000f 082 064 006 Pre-fail Always - 160724566
4 Start/Stop_Count 0x0032 100 100 020 Old_age Always - 15
7 Seek_Error_Rate 0x000f 079 060 045 Pre-fail Always - 73556817
190 Airflow_Temperature 0x0022 059 055 040 Old_age Always - 41 (Min/Max 40/41)
192 Emergency_Retract_Count 0x0032 100 100 000 Old_age Always - 433
193 Load/Unload_Count 0x0032 100 100 000 Old_age Always - 485
194 Temperature 0x0022 041 045 000 Old_age Always - 41 (0 28 0 0 0)
195 ECC_On_the_Fly_Count 0x001a 082 064 000 Old_age Always - 160724566
240 Head_Flight_Hours 0x0000 100 253 000 Old_age Offline - 145247204027325
241 Lifetime_Writes_From_host 0x0000 100 253 000 Old_age Offline - 24436596928
242 Lifetime_Reads_From_Host 0x0000 100 253 000 Old_age Offline - 179285569776
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Serial Number: ZPV01E70
LU WWN Device Id: 5 000c50 0e6cfa16d
Local Time is: Mon Dec 9 11:39:22 2024 CET
was never started.
been run.
command.
power-saving mode.
1 Raw_Error_Rate 0x000f 079 064 006 Pre-fail Always - 76823779
4 Start/Stop_Count 0x0032 100 100 020 Old_age Always - 17
7 Seek_Error_Rate 0x000f 079 060 045 Pre-fail Always - 73473429
12 Drive_Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 16
190 Airflow_Temperature 0x0022 060 056 040 Old_age Always - 40 (Min/Max 35/40)
192 Emergency_Retract_Count 0x0032 100 100 000 Old_age Always - 438
193 Load/Unload_Count 0x0032 100 100 000 Old_age Always - 484
194 Temperature 0x0022 040 044 000 Old_age Always - 40 (0 28 0 0 0)
195 ECC_On_the_Fly_Count 0x001a 079 064 000 Old_age Always - 76823779
240 Head_Flight_Hours 0x0000 100 253 000 Old_age Offline - 111286897617853
241 Lifetime_Writes_From_host 0x0000 100 253 000 Old_age Offline - 9005255022
242 Lifetime_Reads_From_Host 0x0000 100 253 000 Old_age Offline - 181933685696
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Serial Number: ZPV01BPT
LU WWN Device Id: 5 000c50 0e6db5571
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s)
was never started.
been run.
command.
power-saving mode.
recommended polling time: ( 905) minutes.
1 Raw_Error_Rate 0x000f 071 064 006 Pre-fail Always - 13055901
7 Seek_Error_Rate 0x000f 079 060 045 Pre-fail Always - 73345553
190 Airflow_Temperature 0x0022 057 054 040 Old_age Always - 43 (Min/Max 42/43)
194 Temperature 0x0022 043 046 000 Old_age Always - 43 (0 28 0 0 0)
195 ECC_On_the_Fly_Count 0x001a 071 064 000 Old_age Always - 13055901
240 Head_Flight_Hours 0x0000 100 253 000 Old_age Offline - 189055870446525
241 Lifetime_Writes_From_host 0x0000 100 253 000 Old_age Offline - 8818386492
242 Lifetime_Reads_From_Host 0x0000 100 253 000 Old_age Offline - 203519421140
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Ich dachte immer, die Synology-Disks seien umgelabelte Toshibas.
