- 30. Dez. 2012
mount -t ecryptfs /dev/vg9/volume_9 /volume2/backup/volume_9
Passphrase:
Select cipher:
1) aes: blocksize = 16; min keysize = 16; max keysize = 32
2) blowfish: blocksize = 8; min keysize = 16; max keysize = 56
3) des3_ede: blocksize = 8; min keysize = 24; max keysize = 24
4) twofish: blocksize = 16; min keysize = 16; max keysize = 32
5) cast6: blocksize = 16; min keysize = 16; max keysize = 32
6) cast5: blocksize = 8; min keysize = 5; max keysize = 16
Selection [aes]:
Select key bytes:
1) 16
2) 32
3) 24
Selection [16]: 32
Enable plaintext passthrough (y/n) [n]:
Enable filename encryption (y/n) [n]: y
Attempting to mount with the following options:
ecryptfs_unlink_sigs
ecryptfs_fnek_sig=3efc4c83599befa8
ecryptfs_key_bytes=32
ecryptfs_cipher=aes
ecryptfs_sig=3efc4c83599befa8
WARNING: Based on the contents of [/root/.ecryptfs/sig-cache.txt],
it looks like you have never mounted with this key
before. This could mean that you have typed your
passphrase wrong.
Would you like to proceed with the mount (yes/no)? : yes
Would you like to append sig [3efc4c83599befa8] to
in order to avoid this warning in the future (yes/no)? : no
Not adding sig to user sig cache file; continuing with mount.
mount: /volume2/backup/volume_9: mount(2) system call failed: Not a directory.
Error mounting eCryptfs: [-1] Operation not permitted
Check your system logs; visit <http://ecryptfs.org/support.html>
ll /volume2/backup/volume_9/
total 0
drwx------ 1 root root 0 Aug 14 09:50 .
drwx------ 1 root root 16 Aug 14 09:35 ..
na die hat 8 Bays und alle voll heheh steht bei mir auf dem Dachboden wo es nicht unbedingt super sauber ist...Bei meiner DS920+ RAID1 2 x 1T B M.2: NVME SSD Speicherpool seit 3 Jahren ohne Probleme.
Smart Log for NVME device:nvme0n1 namespace-id:ffffffff
critical_warning : 0
temperature : 36 C
available_spare : 100%
available_spare_threshold : 10%
percentage_used : 4%
data_units_read : 6,270,715
data_units_written : 86,208,213
host_read_commands : 33,855,747
host_write_commands : 2,618,874,593
controller_busy_time : 6,766
power_cycles : 5
power_on_hours : 4,384
unsafe_shutdowns : 2
media_errors : 0
num_err_log_entries : 0
Warning Temperature Time : 0
Critical Composite Temperature Time : 0
Temperature Sensor 1 : 36 C
Temperature Sensor 2 : 40 C
Temperature Sensor 3 : 0 C
Temperature Sensor 4 : 0 C
Temperature Sensor 5 : 0 C
Temperature Sensor 6 : 0 C
Temperature Sensor 7 : 0 C
Temperature Sensor 8 : 0 C
