Frage zum Systemzustand
Lextor
12. Aug. 2020
Habe seit gestern Abend diesen Zustand.
Vermutlich ist eine HDD dabei sich zu verabschieden?
Im Speichermanager werden die HDDs aber als "OK" deklariert.
Das ist los bei mir:
smartctl 6.5 (build date Sep 26 2022) [x86_64-linux-4.4.302+] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
Smartctl open device: /dev/sata1 [SAT] failed: Permission denied
=== START OF INFORMATION SECTION ===
Model Family: Seagate IronWolf
Device Model: ST4000VN008-2DR166
Serial Number: ZDH8RV33
LU WWN Device Id: 5 000c50 0c6278faa
Firmware Version: SC60
User Capacity: 4,000,787,030,016 bytes [4.00 TB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Rotation Rate: 5980 rpm
Form Factor: 3.5 inches
Device is: In smartctl database [for details use: -P show]
ATA Version is: ACS-3 T13/2161-D revision 5
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Sat Jun 1 09:09:05 2024 CEST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
SMART Attributes Data Structure revision number: 10
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000f 100 064 044 Pre-fail Always - 60402
3 Spin_Up_Time 0x0003 093 093 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 137
5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 092 060 045 Pre-fail Always - 1445828000
9 Power_On_Hours 0x0032 063 063 000 Old_age Always - 32789 (186 136 0)
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 135
184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0
189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0022 070 066 040 Old_age Always - 30 (Min/Max 30/31)
191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 85
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 203
194 Temperature_Celsius 0x0022 030 040 000 Old_age Always - 30 (0 21 0 0 0)
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 32779h+40m+48.678s
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 313419328336
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 39245879225
Device Model: ST4000VN006-3CW104
Serial Number: ZW600ZAE
LU WWN Device Id: 5 000c50 0e4eb1b9b
Rotation Rate: 5400 rpm
Device is: Not in smartctl database [for details use: -P showall]
Local Time is: Sat Jun 1 09:10:07 2024 CEST
1 Raw_Read_Error_Rate 0x000f 079 064 006 Pre-fail Always - 74377625
3 Spin_Up_Time 0x0003 095 095 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 79
7 Seek_Error_Rate 0x000f 081 060 045 Pre-fail Always - 130981271
9 Power_On_Hours 0x0032 084 084 000 Old_age Always - 14299
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 65
183 Runtime_Bad_Block 0x0032 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0022 066 060 040 Old_age Always - 34 (Min/Max 33/35)
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 7
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 79
194 Temperature_Celsius 0x0022 034 040 000 Old_age Always - 34 (0 25 0 0 0)
195 Hardware_ECC_Recovered 0x001a 079 064 000 Old_age Always - 74377625
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 8822 (108 135 0)
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 17330581483
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 56803733681
Serial Number: ZGY78W5W
LU WWN Device Id: 5 000c50 0c62890ac
Local Time is: Sat Jun 1 09:10:16 2024 CEST
1 Raw_Read_Error_Rate 0x000f 084 064 044 Pre-fail Always - 237891689
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 166
7 Seek_Error_Rate 0x000f 093 060 045 Pre-fail Always - 2072259905
9 Power_On_Hours 0x0032 063 063 000 Old_age Always - 33051 (135 233 0)
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 164
190 Airflow_Temperature_Cel 0x0022 071 060 040 Old_age Always - 29 (Min/Max 28/30)
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 87
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 230
194 Temperature_Celsius 0x0022 029 040 000 Old_age Always - 29 (0 19 0 0 0)
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 33041h+04m+03.507s
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 315308201232
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 195829915806
Und die Smartwerte der 3 Hdds.
Kann Jemand sagen, was ich jetzt am besten machen kann?
Das System selber und alle Dienste funktionieren ohne Probleme...
Die Vorgeschlagene Prüfung habe ich bereits durchgeführt, aber es ändert sich nichts.
Vielen Dank...
Mach mal nen RAM-Test mit dem Assistant.
Die SMART-Werte der Platten sehen für mich gut aus.
Du hast einen SSD-Cache verbaut, oder? Vielleicht liegt auch da der Fehler, insofern würde ich den mal rausschmeißen und erneut testen. Der Cache bringt eh in den allerwenigsten Fällen etwas.
Wie soll ich diesen Speicherpool 1 mit 3 identische HDDs verstehen, mit nur 3,6 TB Gesamtspeicher als RAID1?
Habe ich da nicht genau 3,6 TB ungenutztes Speicher?
Stimmt. 3 HDDs als RAID1 will man i.d.R. nicht haben. Ich würde das eher als RAID5/SHR1 einrichten, damit man 1 Platte Redundanz hat. Aktuell hat er ja 2 Platten Redundanz.
Ungenutzt ist da nix, die Platten sind halt alle "gespiegelt"
1. Kannst du die SMART Werte der NVMEs posten?
2. Backup vorhanden?
3. Nutzt du Docker, VMM (VMs)
4. Cache auflösen, bringt nix, ausser Fehler
5. Ich würde den Speicherpool neu anlegen mit RAID5 bzw. SHR1
6. Speichertest RAM über Synology Assistent ausführen
Smart Log for NVME device:nvme0n1 namespace-id:ffffffff
critical_warning : 0
temperature : 45 C
available_spare : 100%
available_spare_threshold : 10%
percentage_used : 41%
data_units_read : 68,577,931
data_units_written : 55,969,785
host_read_commands : 1,281,654,585
host_write_commands : 1,345,881,315
controller_busy_time : 6,557
power_cycles : 20
power_on_hours : 14,469
unsafe_shutdowns : 11
media_errors : 0
num_err_log_entries : 0
Warning Temperature Time : 0
Critical Composite Temperature Time : 0
Temperature Sensor 1 : 45 C
Temperature Sensor 2 : 46 C
Temperature Sensor 3 : 0 C
Temperature Sensor 4 : 0 C
Temperature Sensor 5 : 0 C
Temperature Sensor 6 : 0 C
Temperature Sensor 7 : 0 C
Temperature Sensor 8 : 0 C
_________________________________________________________________________________________________
Smart Log for NVME device:nvme1n1 namespace-id:ffffffff
temperature : 42 C
percentage_used : 39%
data_units_read : 83,074,016
data_units_written : 55,969,778
host_read_commands : 2,319,627,514
host_write_commands : 1,345,865,182
controller_busy_time : 9,443
power_cycles : 20
media_errors : 0
Temperature Sensor 1 : 42 C
Temperature Sensor 2 : 45 C
Die Werte der NVMEs
Ja, es ist ein Raid1 mit 3 Hdds...
Gruß....
Backup vorhanden, Im Docker keine VMs, aber Bitwarden, JelyFin und Sterling PDF,RAM Test noch nicht gemacht...Speicherpool neu anlegen heißt aber auch viel arbeit, da ich den alten erst löschen muss, oder?
Ja, da musst du den alten löschen und dann das Backup wieder einspielen. Warum hast du überhaupt aus 3 Platten ein RAID1 und kein RAID5/SHR?
Reaktionen: plang.pl
Stimmt. Wenn man ohnehin schon dabei ist, würd ich auch neu aufsetzen. Die größere Systempartition ist das bisschen Mehraufwand definitiv wert.
Ohje...das wird doch etwas Arbeit sein...aber gut...werd ich wohl dann mal machen müssen...übrigens...die NVME werden von der 920+ nicht als Volume zugelassen...die lassen nur welche von Synology als Volume zu...ich habe das Raid 1 mit 3 Hdds zwecks Sicherheitsgefühl...Aber...wenn ich wirklich nicht drum herrum komme...werde ich auch BTRFS verwenden und ein Raid 5 daraus machen...und dann eine 4. HDD als HotSpare einbinden...hat jemand ungefähr eine Vorstellung darüber wie lange sowas dauern wird...??? Neues Volume...Backup einspielen etc?
Lieber eine vernünftige Backup-Strategie als ein RAID1 aus 3 Platten.
Habe 3 Backups...eine USB Platte und noch eine weitere, die aber nur zum Zeitpunkt des Backups online ist. Zusätzlich habe ich ein Backup an einem anderem Ort. Der RPO liegt bei 120min.
Nun, wie lange das letzte Backup her ist, ist doch von Bedeutung...zumindest für mich.
