- 05. März 2013
Der SMB-Service hat die Beta-Phase verlassen:
Und damit gibt es natürlich auch eine neue Version für den Directory-Server:
Version: 4.15.9-0631
(2023-04-13)
Compatibility & Installation
SMB Service 4.15.9 requires DSM 7.1.1 or above.
What's New
Updated Samba to version 4.15.9.
Added the SMB3 Multichannel function. This function allows users to take full advantage of the network bandwidth by using multiple connections between the client and server, providing increased throughput and network fault tolerance. You can enable this function at Control Panel > File Services > SMB > Advanced Settings > Others.
Fixed Issues
Fix an issue where users cannot access home directory.
Minor bug fixes.
Limitations
Please note that currently the SMB3 Multichannel function only supports x86 platforms. For models in x86 platforms, please refer to all models listed in this article.
Version: 4.15.9-0454
(2023-04-13)
Upgraded to be compatible with SMB Service 4.15.9-0631.
Backups of Synology Directory Server 4.15.9-0454 can only be restored to the same or later Synology Directory Server versions.
