- Mitglied seit
- 05. Mrz 2013
- Punkte für Reaktionen
- 582
Das Active Backup Update ist zurück, um einen Build hochgezählt, ich kann aber bei den Release Notes keinen Unterschied finden:
https://www.synology.com/de-de/releaseNote/ActiveBackup?model=DS918+#7_x_series
Version: 2.6.2-13081 (DSM 7.1) / 2.6.2-23081 (DSM 7.2)
(2023-10-31)
Fixed Issues (General Issues)
Fixed an issue where scheduled reports were not sent when there were more than one recipient.
Fixed Issues (Mac)
Fixed an issue where the protected device statistics might not display correctly in manually generated or scheduled backup reports.
Fixed Issues (Virtual Machines)
Fixed an issue where the recovery wizard might fail to restore a selected virtual machine if its operating system was not on the Hyper-V supported list.
Fixed an issue where editing virtual machine backup tasks might fail if the virtual machine was deleted from the hypervisor.
Fixed an issue where virtual machine backup tasks might fail if the virtual machine was excluded from the auto-discovery task.
Adjusted the Hyper-V failover cluster connection mechanism to prevent virtual machine backup failures on specific nodes in the cluster.
Fixed an issue where migrating modified data from the virtual machine to Hyper-V might fail when instantly restoring the virtual machine to VMM with storage space encryption and compression enabled.
Anmerkungen:
This version is released in a staged rollout.
