joplin-vieweb
update-freak
19. Feb. 2018
Hi zusammen,
versuche gerade joplin-vieweb zum Laufen zu bringen um meine Joplin Notzien auch online zu bearbeiten.
Nutze folgenden Stack in Portainer (https://github.com/joplin-vieweb/joplin-vieweb?tab=readme-ov-file).
YAML:
version: '3.4'
x-common-variables: &common-variables
   ORIGINS: "'http://localhost', 'http://192.168.178.27'"
   JOPLIN_LOGIN_REQUIRED: True
services:
  django-joplin-vieweb:
    image: gri38/django-joplin-vieweb:latest
    depends_on:
      - joplin-terminal-xapi
    environment:
       <<: *common-variables
    restart: always
    ports:
      - 1043:8000
    volumes:
      - /volume1/docker/joplin-vieweb/joplin:/root/.config/joplin:ro
      - /volume1/docker/joplin-vieweb/joplin-vieweb:/root/.config/joplin-vieweb
  joplin-terminal-xapi:
    image: gri38/joplin-terminal-xapi:latest
    restart: always
    volumes:
      - /volume1/docker/joplin-viewweb/joplin:/root/.config/joplin
Bekomme:
failed to deploy a stack: 1 error(s) decoding: * error decoding 'volumes[0]': invalid spec: /volume1/docker/joplin-vieweb/joplin:/root/.config/joplin:ro - /volume1/docker/joplin-vieweb/joplin-vieweb:/root/.config/joplin-vieweb: too many colons
Hast du die Ordner angelegt unter volume1/Docker
