Hallo habe die anleitung gefunden....
open a new browser tab in firefox
1. enter the following: about:config
2. you will be prompted with a security warning, accept and move past it.
3. right click on the screen over one of the exsisting commands and goto "New" then select "Boolean"
4. enter the following: plugin.load_flash_only
5. accept/ok
6. set tag to "false"
7. accept/ok
8. press "shift+F2" to open command line
9. type "restart"
10. this will force firefox restart and when it comes back up you should be good to go!
Nur wie geht das wie komme ich da hin ?"3. right click on the screen over one of the exsisting commands and goto "New" then select "Boolean"
Danke freundlicher Gruß
5. accept/ok
7. accept/ok
9. type "restart"
