DS118 2,5GBe Adapter
Devil6666
26. Sep. 2019
Hi Leute! Unterstützt die DS118 einen usb 2,5GBe Adapter? Wenn ja wo bekomme ich den Treiber her?
Danke schon mal!
Bitte.
Und beachte diese Anweisung:
How to install​
Preparation​
Enable SSH and login your NAS.
Installation​
  1. Go to "Package Center"
  2. Press "Manual Install"
  3. Chose a driver package downloaded from the release page.
  4. [DSM7] The installation will fail the first time. After that, run the following command from the SSH terminal:
    • sudo install -m 4755 -o root -D /var/packages/r8152/target/r8152/spk_su /opt/sbin/spk_su
  5. [DSM7] Retry installation.
    • You don't need above DSM7 specific steps at the next time.
  6. Reboot your NAS.
    • This procedure is not usually necessary, but many have reported that a reboot was necessary, so please reboot just in case.
https://www.synology.com/en-us/knowledgebase/SRM/help/SRM/PkgManApp/install_buy
Warning: Do not use Safari for this operation.
