Ja genau; ich habe die k4s 0.8.4 nochmals gelöscht und neu hochgeladen, damit dies mit dem neusten Community Package per Version kompatibel ist (sonst wird das nicht vom Docker Hub geladen).Achtung, ein neues Dockerimage ist hochgeladen und ein anderes SPK ist auch unterwegs.
kopano-postfix (c) TosoBoso: script and postconf wrapper for postfix integration with kopano4s
Usage: kopano-postfix plus config, edit, relay, tls, stop, (re)start, reset, loglines, logsum, map, queue, queuemsgs, show, requeue, release, resend, delete, flush, sync-/stats-/reset-/export-/import-/baseline-spamdb, train-spam/ham, test-smtp/amavis/spam/smail, help
config shows the current setting incl health check (postconf -n && postfix check)
edit plus argument changes main.cf entry (e.g. edit 'mynetworks = 127.0.0.0/8')
relay plus server, user, password arguments creates a relay server entry; off disables it
tls plus on / off enable or disables opportunistic encryption via transport layer security
stop, (re)start to change and let new settings being effective; use it after your set of changes via edit
resets gets back to original configuration from install for main.cf and master.cf
loglines plus number shows no of rows (default 5) to mail.log, .err, .warn, .info files
logsumm calls utility pflogsumm with default paramaters for daily summary; call logsumm --help for details.
map plus file-name runs postmap on it; reset goes back to initial configuration at install
queue shows the status of active (*), hold (!) defer queues and queuemsgs the messages inside
show, requeue, release, resend, delete manipulates respective mailqueue-ids whil flush is for all
sync-/stats-/reset-/export-/import-/baseline-spamdb performs actions on spamassassin bayesian database.
train-spam/ham trains sa-bayesian-db with input to respective amavis directory. Run sync-spamdb afterwards.
test-smtp plus recipient as argument (default: posmaster) runs a telnet test session to the smpt-server.
test-amvis runs a telnet test session to the lmtp-amvis server on 10024 and reinject smtpd-service on 10025.
test-spam runs a telnet test session with spam string in body that should be marked by spamassassin.
test-smail recipient as argument (default: posmaster) runs sendmail for testing postfix incl. recipient msg.
help obviously shows this dialog
