Ich hoffe du meintest das :
admin@Kannebecker:/$ /volume1/@appstore/Java7/j2sdk-image/jre/bin/java -Djava.awt.headless=true -jar JDownloader.jar
Error: Unable to access jarfile JDownloader.jar
admin@Kannebecker:/$ sudo /volume1/@appstore/Java7/j2sdk-image/jre/bin/java -Djava.awt.headless=true -jar JDownloader.jar
Wenn ich den Pfad ändere --> sudo /volume1/@appstore/Java7/j2sdk-image/jre/bin/java -Djava.awt.headless=true -jar /volume1/@appstore/JDownloader/JDownloader.jar
läuft jede Menge ab ... bis das kommt:
Update Progress: 79.468%
Update Message: Download Updates...
Downloadspeed: 2.59 MB/s, Time left: 00s
|---------------------------Headless Information-------------------------------
| Restart Required
| JDownloader Updated and restarted itself.
| The process restarted itself and runs now in the background: 24290@Kannebecker
| If you do not want JD to restart itself, use the -norestart switch.
