09:04:28 hotplugd: ##### ACTION:remove
Dec 16 09:04:28 hotplugd: DEVICE:/proc/bus/usb/001/009
Dec 16 09:04:28 hotplugd: DEVPATH:1-1.2:1.0
Dec 16 09:04:28 hotplugd: SUBSYSTEM:usb
Dec 16 09:04:28 hotplugd: INTERFACE:8/6/80
Dec 16 09:04:28 hotplugd: ##### ACTION:remove
Dec 16 09:04:48 hotplugd: ##### ACTION:add
Dec 16 09:04:48 hotplugd: DEVICE:/proc/bus/usb/001/010
Dec 16 09:04:48 hotplugd: DEVPATH:1-1.2
Dec 16 09:04:48 hotplugd: SUBSYSTEM:usb
Dec 16 09:04:48 hotplugd: DEVPATH:1-1.2:1.0
Dec 16 09:04:48 hotplugd: INTERFACE:8/6/80
Dec 16 09:04:51 kernel: [993035.590000] sd 12:0:0:0: [sdq] Assuming drive cache: write through
Dec 16 09:04:51 kernel: [993035.620000] sd 12:0:0:0: [sdq] Assuming drive cache: write through
Dec 16 09:04:51 kernel: [993035.650000] sd 12:0:0:0: [sdq] Assuming drive cache: write through
Dec 16 09:04:53 hotplugd: ##### ACTION:add
Dec 16 09:04:53 hotplugd: DEVNAME:sdq
Dec 16 09:04:53 hotplugd: DEVICE:/proc/bus/usb/001/010
Dec 16 09:04:53 hotplugd: DEVGUID:FF2000DF000000000000005FD21FFD0
Dec 16 09:04:53 hotplugd: DEVPATH:sdq
Dec 16 09:04:53 hotplugd: SUBSYSTEM:block
Dec 16 09:04:53 hotplugd: PHYSDEVPATH:/devices/platform/orion-ehci.0/usb1/1-1/1-1.2/1-1.2:1.0/host12/target12:0:0/12:0:0:0
Dec 16 09:04:53 hotplugd: hotplugd.c:835 ##### complete device hotplug!!
Dec 16 09:04:53 hotplugd: hotplugd.c (1434) ==== USB disk [sdq] plugged in ====
Dec 16 09:04:53 hotplugd: hotplugd.c:1435 goto USB disk, szDeviceName=sdq
Dec 16 09:04:53 kernel: [993037.360000] EXT3-fs: sdq1: couldn't mount because of unsupported optional features (240).
Dec 16 09:04:54 root: upgrade db not done, bail out
Dec 16 09:04:55 root: upgrade db not done, bail out
Dec 16 09:05:08 kernel: [993052.010000] ecryptfs_parse_options: eCryptfs: unrecognized option [passwd=xxxxxxxxxxxx]
Dec 16 09:05:08 synolocalbkp: backup_record.c:148 SLIBCFileSetSection() BACKUP komplett_v1 failed, synoerr=[0x2000]
Dec 16 09:05:08 synolocalbkp: backup_record.c:179 record_updat_waiting() failed.
Dec 16 09:23:52 synolocalbkp: localbkp_copy_file.c:99 Failed to open file [/volumeUSB1/usbshare/LocalBackup/backup_bertas/Opera/profile/icons/https%3A%2F%2Fsecure.xxxxxxxxxxxxx.de%2F(S(w0vfy4d50xceubqcm3jsvvsi))%2xxxxxxxxxxx%2Fdefault.aspx%3Fdata=http
Dec 16 09:23:52 synolocalbkp: localbkp_copy_file.c:99 Failed to open file [/volumeUSB1/usbshare/LocalBackup/backup_bertas/Opera/profile/icons/http%3A%2F%2Flb.xxxxxxxxxxxxxxx.de%2Flib%2Fimages%2Ficons%2Ffavicon.ico;jsessionid=D5F509174234F7BE2C6B1D973F
Dec 16 09:23:53 synolocalbkp: localbkp_copy_file.c:99 Failed to open file [/volumeUSB1/usbshare/LocalBackup/backup_bertas/Opera/profile/icons/http%3A%2F%2Fupload.xxxxxxxxx.org%2Fxxxxxxxxx%2Fen%2Fthumb%2F9%2F9e%2FWildflowers_at_California_Poppy_Reserve
Dec 16 09:23:53 synolocalbkp: localbkp_copy_file.c:99 Failed to open file [/volumeUSB1/usbshare/LocalBackup/backup_bertas/Opera/profile/icons/http%3A%2F%2Fwww.xxxxxxxxxxxxxxxx.de%2Fcae%2Fservlet%2Fcontentblob%2F525966%2Fnormal%2F40142%2Ffavicon.ico;js
Dec 16 09:23:54 synolocalbkp: localbkp_copy_file.c:99 Failed to open file [/volumeUSB1/usbshare/LocalBackup/backup_bertas/Opera/profile/icons/https%3A%2F%2Fxxxxxxxxxxxxxxxxxxxxxx.de%2Fproxy%2Fflight%2Fproxy.php%3Fqq=aHR0cHM6Ly93ZWJtZWRpYS55cHNpbG9uLm5
Dec 16 09:23:54 synolocalbkp: localbkp_copy_file.c:99 Failed to open file [/volumeUSB1/usbshare/LocalBackup/backup_bertas/Opera/profile/icons/http%3A%2F%2Fwww.xxxxxxxxxxxxxxxxxx.de%2Finhalte%2Fde%2Fxxxxxxxx%2Fxxxxx%2Fxxxxxx%202%2Fxxxxxxxxxx%20-%201x1%
Dec 16 09:23:54 synolocalbkp: localbkp_copy_file.c:99 Failed to open file [/volumeUSB1/usbshare/LocalBackup/backup_bertas/Opera/profile/icons/http%3A%2F%2Fimages.xxxxxxxxxxxx.com%2Fis%2Fimage%2FCWI%2F40000%2F47907n.jpg%3Fop_sharpen=1&layer=1&src=CWI%2
Dec 16 09:23:55 synolocalbkp: localbkp_copy_file.c:99 Failed to open file [/volumeUSB1/usbshare/LocalBackup/backup_bertas/Opera/profile/icons/http%3A%2F%2Fwww.xxxxxxxxxxxxxxx.de%2FWebRoot%2FStore20%2FShops%2F62025192%2F498F%2FF1FA%2F593E%2F6D9A%2FF32D
Dec 16 09:23:55 synolocalbkp: localbkp_copy_file.c:99 Failed to open file [/volumeUSB1/usbshare/LocalBackup/backup_bertas/Opera/profile/icons/file%3A%2F%2Flocalhost%2Fc%3A%2FDokumente%20und%20Einstellungen%2Fxxxxxx%2FEigene%20Dateien%2Fxxxxxx%2Fxxxxx%
Dec 16 09:23:56 synolocalbkp: localbkp_copy_file.c:99 Failed to open file [/volumeUSB1/usbshare/LocalBackup/backup_bertas/Opera/profile/icons/https%3A%2F%2Fsecure.xxxxxxxxxxxxx.de%2F(S(mesi4vfqhdywane0wsicur3y))%2xxxxxxxxxxx%2Fdefault.aspx%3Fdata=http
Dec 16 09:23:57 synolocalbkp: backup_record.c:230 SLIBCFileRemoveSection() BACKUP komplett_v1 failed.
Dec 16 09:23:57 synolocalbkp: backup_record.c:258 record_updat_waiting() failed.
Dec 16 09:24:06 hotplugd: ##### ACTION:remove
09:24:06 hotplugd: DEVNAME:sdq
Dec 16 09:24:06 hotplugd: DEVICE:/proc/bus/usb/001/010
Dec 16 09:24:06 hotplugd: DEVPATH:sdq
Dec 16 09:24:06 hotplugd: SUBSYSTEM:block
Dec 16 09:24:06 hotplugd: PHYSDEVPATH:/devices/platform/orion-ehci.0/usb1/1-1/1-1.2/1-1.2:1.0/host12/target12:0:0/12:0:0:0
Dec 16 09:24:06 hotplugd: hotplugd.c (1453) ==== USB disk [sdq] plugged out====
Dec 16 09:24:06 hotplugd: SYNOReadOneSectorFromDev(56): failed to open device [/dev/sdq] (errno = 6)
Dec 16 09:24:06 hotplugd: usbbkp_is_dev_bkp_disk.c:85 SYNOReadOneSectorFromDev failed. szDevPath=[sdq], errno=[0x0900]
Dec 16 09:24:06 hotplugd: volume_parts_info_get_by_dev.c:318 failed to get disk '/dev/sdq' size
Ich verstehe nicht, warum du nicht einfach 2 lokale Backups einrichtest und per Zeitplaner (im Backup) dann einstellst dass die alle 2 Tage laufen.
2012-12-19 15:46:05: device 'sdq' - inserted, trying to find mount point
2012-12-19 15:46:12: device 'sdq' - mount point '/volumeUSB1/usbshare' found
2012-12-19 15:46:12: device 'sdq' - script '/volumeUSB1/usbshare/autorun' found, executing
2012-12-19 15:46:12: device '/volumeUSB1/usbshare' - mounting the encrypted file system
2012-12-19 15:46:12: device '/volumeUSB1/usbshare' - local backup 'test_1' started
2012-12-19 15:46:22: device '/volumeUSB1/usbshare' - local backup 'test_1' finished
2012-12-19 15:46:22: device '/volumeUSB1/usbshare' - unmounting the encrypted file system
2012-12-19 15:46:22: device '/volumeUSB1/usbshare' - problem while unmounting the encrypted file system, aborting
2012-12-19 15:46:25: device 'sdq' - script '/volumeUSB1/usbshare/autorun' finished, no further actions
hab's noch nicht verstanden. Wenn du jede Woche eine Platte nutzen willst, sollte es doch klappen: Lokales Backup eben jeden Tag. Wenn die zweite Platte eh örtlich getrennt davon ist, wechselst du sie nach einer Woche und lässt - den gleichen (?!!) - Backupjob nun weiterlaufen.
Olaf
sh /volumeUSB1/usbshare/startebackup.sh 3
umount devusb ... keine ahnung, wie das heißen muss
if [ $1 -eq 3 ]; then
/var/packages/autorun/target/localbackup "backupHDD1Mittwoch" "/volumeUSB1/usbshare" "$1" 100
elif [ $1 -eq 5 ..... usw
fi
sh /volumeUSB1/usbshare/timebackupversion.sh
#auf der platte:
/usr/syno/bin/timebkp create_version --task=$TASK_NAME_HHD1
Die 4.1 ist nicht beschnitten, es werden nur einige Sachen anders gemacht / gespeichert. Und ich kann überall hin als root.
Installierte Packages findest Du unter /var/packages. Ansonsten kannst Du auch die spk's direkt auf Deinem Rechner öffen, ist nur ein tar.
autorun 1.0
- Verschlüsselung der Ordner- und Dateinamen optional - falls jemand Probleme mit der Pfadlänge hat
- Name der lokalen Backups werden (aufgrund der Änderungen in DSM 4.1) nicht mehr aus der Syno-Konfig geladen
- 10s Pause vor dem Start des lokalen Backups (siehe hier)
aha, ich dachte durch die .db Datei im Zielverzeichnis des Backups würden die Inhalte gesteuert. Da (nach meinem Denken) auf jeder USB dann eine solche Datei liegen würde hatte ich angenommen, ein Script reicht.
Den Cron Job sollte er doch auch mit dem cronjob editor Paket einrichten können - oder? Ich habe das nicht installiert, daher keine Ahnung, was das kann und wie komfortabel man damit arbeiten kann.
Olaf
