- 30. Mai 2019
I tested this Rekommandation from Sp1derman
i deinstalled Ubuntu - reinstalled Ubuntu 24.04
try to use my usual Username of Windows for the Ubuntu and get a Failure Message in the CMD
My Username Starts with a Big Letter and only smal / lower Letters are accepted as first Letter.
so i inserted the Username starting with a smal Letter and the Pass is accepted without any failures
I do not want a adtional User in Windows - so I Changed in Windows my first Letter of my User to smal / lower and reboot
Started all
reinstall script and Libraries
and it works
to confirm and due to other Apps on system i renamed my User back to the original Format with first High Letter / reboot
And its not working any more
Tried to install a additional user with my Username just with a low first Letter - and Windows fails and says User exist already ..... but exist with a high first Letter - so for windows there is no real Difference
I can confirm too that all Trouble is based on Usernames and Logins
Would be great if that can be solves
Suggestion -
1. fix of Username Bug
2 Automatic Insert of Password
3. selection of destination Folder - (source File not deleted)
Started all
and it works
Suggestion -
If "Extract to same folder as pat/spk file" is not ticked it does not move the extracted files to the selected folder.
