- 30. März 2022
The Insyde is empty on both of mine as well. But the EFI folder contains:
SynoBootLoader.conf and SynoBootLoader.efi are different on both my Synology NAS that use efi.
Your missing SynoBootLoader.conf would probably look like this:
Someone with a DS918+ (or DS1019+ or DS718+) could give you a copy of their synoboot1
They'd need to change "MYSHAREDFOLDER" to a shared folder on their DS918+.
EFI/boot/SynoBootLoader.conf
EFI/boot/SynoBootLoader.efi
Insyde/
syno_serial --pci=0,24,2 --speed=115200 --uppci=0,24,0 --upspeed=115200
terminal_input serial
terminal_output serial
set default='1'
set timeout='3'
set fallback='0'
menuentry "SYNOLOGY_1" {
search --fs-uuid --no-floppy --set=root 10EE-589C
linux /zImage root=/dev/md0 intel_iommu=igfx_off netif_num=2 HddEnableDynamicPower=1 syno_hw_version=DS918+ vender_format_version=2 synoboot1
initrd /rd.gz
menuentry "SYNOLOGY_2" {
search --fs-uuid --no-floppy --set=root 45E5B07D-4783-4867-A369-F99C0CD1E610
cksum /grub_cksum.syno
turns /turns -s
linux /zImage root=/dev/md0 intel_iommu=igfx_off netif_num=2 HddEnableDynamicPower=1 syno_hw_version=DS918+ vender_format_version=2 synoboot2
initrd /rd.gz
sudo dd if=/dev/synoboot1 of=/volume1/MYSHAREDFOLDER/synoboot1.imgThey'd need to change "MYSHAREDFOLDER" to a shared folder on their DS918+.
