Hast du die Option trotzdem mal aktiviert und geschaut was passiert? Und sind eventuell Umlaute im Pfad und/oder Dateinamen enthalten?In den fraglichen Ordnernamen sind keine Sonderzeichen enthalten.
PAPERLESS_FILENAME_FORMAT: "{created_year} / {correspondent} / {title}". Da sind Leerzeichen enthalten. Ich Paperless-NGX habe ich Testweise einen Speicherpfad angelegt und dies Leerzeichen in der Definition gelöscht.Hast du auch AFP auf der Syno aktiviert?Greife ich von afp zu
Apply database migrations...
Traceback (most recent call last):
File "/usr/local/lib/python3.9/site-packages/django/db/backends/base/base.py", line 282, in ensure_connection
self.connect()
File "/usr/local/lib/python3.9/site-packages/django/utils/asyncio.py", line 26, in inner
return func(*args, **kwargs)
File "/usr/local/lib/python3.9/site-packages/django/db/backends/base/base.py", line 263, in connect
self.connection = self.get_new_connection(conn_params)
File "/usr/local/lib/python3.9/site-packages/django/db/backends/postgresql/base.py", line 215, in get_new_connection
connection = Database.connect(**conn_params)
File "/usr/local/lib/python3.9/site-packages/psycopg2/__init__.py", line 122, in connect
conn = _connect(dsn, connection_factory=connection_factory, **kwasync)
psycopg2.OperationalError: could not translate host name "db" to address: Name or service not known
The above exception was the direct cause of the following exception:
File "/usr/src/paperless/src/manage.py", line 10, in <module>
execute_from_command_line(sys.argv)
File "/usr/local/lib/python3.9/site-packages/django/core/management/__init__.py", line 446, in execute_from_command_line
utility.execute()
File "/usr/local/lib/python3.9/site-packages/django/core/management/__init__.py", line 440, in execute
self.fetch_command(subcommand).run_from_argv(self.argv)
File "/usr/local/lib/python3.9/site-packages/django/core/management/base.py", line 402, in run_from_argv
self.execute(*args, **cmd_options)
File "/usr/local/lib/python3.9/site-packages/django/core/management/base.py", line 448, in execute
output = self.handle(*args, **options)
File "/usr/local/lib/python3.9/site-packages/django/core/management/base.py", line 96, in wrapped
res = handle_func(*args, **kwargs)
File "/usr/local/lib/python3.9/site-packages/django/core/management/commands/migrate.py", line 114, in handle
executor = MigrationExecutor(connection, self.migration_progress_callback)
File "/usr/local/lib/python3.9/site-packages/django/db/migrations/executor.py", line 18, in __init__
self.loader = MigrationLoader(self.connection)
File "/usr/local/lib/python3.9/site-packages/django/db/migrations/loader.py", line 58, in __init__
self.build_graph()
File "/usr/local/lib/python3.9/site-packages/django/db/migrations/loader.py", line 235, in build_graph
self.applied_migrations = recorder.applied_migrations()
File "/usr/local/lib/python3.9/site-packages/django/db/migrations/recorder.py", line 81, in applied_migrations
if self.has_table():
File "/usr/local/lib/python3.9/site-packages/django/db/migrations/recorder.py", line 57, in has_table
with self.connection.cursor() as cursor:
File "/usr/local/lib/python3.9/site-packages/django/db/backends/base/base.py", line 323, in cursor
return self._cursor()
File "/usr/local/lib/python3.9/site-packages/django/db/backends/base/base.py", line 299, in _cursor
self.ensure_connection()
self.connect()
File "/usr/local/lib/python3.9/site-packages/django/db/utils.py", line 91, in __exit__
raise dj_exc_value.with_traceback(traceback) from exc_value
self.connect()
django.db.utils.OperationalError: could not translate host name "db" to address: Name or service not known
[2023-08-25 09:00:00,432] [ERROR] [paperless_mail] Error while retrieving mailbox paperless: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate (_ssl.c:1129)
