smartctl -A -d ata /dev/sata1
Der Aufgabenplaner hat eine geplante Aufgabe abgeschlossen.
Aufgabe: SMART Laufwerk 1
Start: Mon, 29 Jan 2024 10:26:58 +0100
Ende: Mon, 29 Jan 2024 10:26:58 +0100
Aktueller Status: 0 (Normal)
Standardausgabe/Fehler:
smartctl 6.5 (build date Sep 26 2022) [x86_64-linux-4.4.302+] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
SMART Attributes Data Structure revision number: 10
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Error_Rate 0x000f 083 064 044 Pre-fail Always - 187292525
3 Spin_Up_Time 0x0003 091 089 000 Pre-fail Always - 0
4 Start/Stop_Count 0x0032 100 100 020 Old_age Always - 86
5 Retired_Sectors_Count 0x0033 100 100 010 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 089 060 045 Pre-fail Always - 730733426
9 Power_On_Hours 0x0032 077 077 000 Old_age Always - 20907
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Drive_Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 82
18 Read_Error_Rate_Self-Test 0x000b 100 100 050 Pre-fail Always - 0
187 Reported_Uncorrectables 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout_Count 0x0032 100 100 000 Old_age Always - 0
190 Airflow_Temperature 0x0022 065 056 040 Old_age Always - 35 (Min/Max 29/39)
192 Emergency_Retract_Counnt 0x0032 100 100 000 Old_age Always - 8
193 Load/Unload_Count 0x0032 100 100 000 Old_age Always - 931
194 Temperature 0x0022 035 044 000 Old_age Always - 35 (0 24 0 0 0)
197 Pending-Sparing_Count 0x0012 100 100 000 Old_age Always - 0
198 Uncorrectable_Sectors_Count 0x0010 100 100 000 Old_age Offline - 0
199 Ultra_DMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
240 Head_Flight_Hours 0x0000 100 253 000 Old_age Offline - 231301168779668
241 Lifetime_Writes_From_Host 0x0000 100 253 000 Old_age Offline - 73311144788
242 Lifetime_Reads_From_host 0x0000 100 253 000 Old_age Offline - 255860577330
1 Raw_Error_Rate 0x000f 077 064 044 Pre-fail Always - 52522049 (-> 77)
3 Spin_Up_Time 0x0003 091 091 000 Pre-fail Always - 0
4 Start/Stop_Count 0x0032 100 100 020 Old_age Always - 34
7 Seek_Error_Rate 0x000f 072 060 045 Pre-fail Always - 16674519
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 809
12 Drive_Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 34
190 Airflow_Temperature 0x0022 065 061 040 Old_age Always - 35 (Min/Max 27/37)
192 Emergency_Retract_Counnt 0x0032 100 100 000 Old_age Always - 6
193 Load/Unload_Count 0x0032 100 100 000 Old_age Always - 62
194 Temperature 0x0022 035 040 000 Old_age Always - 35 (0 19 0 0 0)
195 ECC_On_the_Fly_Count 0x001a 077 064 000 Old_age Always - 52522049
240 Head_Flight_Hours 0x0000 100 253 000 Old_age Offline - 5016521802537
241 Lifetime_Writes_From_Host 0x0000 100 253 000 Old_age Offline - 3214535791
242 Lifetime_Reads_From_host 0x0000 100 253 000 Old_age Offline - 256108020
1 Raw_Error_Rate 0x000f 079 064 044 Pre-fail Always - 72743991 (-> 79)
7 Seek_Error_Rate 0x000f 072 060 045 Pre-fail Always - 17427232
190 Airflow_Temperature 0x0022 069 062 040 Old_age Always - 31 (Min/Max 26/33)
194 Temperature 0x0022 031 040 000 Old_age Always - 31 (0 18 0 0 0)
195 ECC_On_the_Fly_Count 0x001a 079 064 000 Old_age Always - 72743991
240 Head_Flight_Hours 0x0000 100 253 000 Old_age Offline - 184675003794217
241 Lifetime_Writes_From_Host 0x0000 100 253 000 Old_age Offline - 3213333935
242 Lifetime_Reads_From_host 0x0000 100 253 000 Old_age Offline - 3700241545
Deine Umrechnung liefert aber nur den normalisierten Wert (Value-Spalte), den du auch ohne die Umrechnung bekommst.Anbei meine SMART-Werte (Raw-Error wegen Seagate umgerechnet in Klammern)
Vorher könntest du eine HDD am PC auslesen:
https://kb.synology.com/de-de/DSM/tutorial/How_can_I_recover_data_from_my_DiskStation_using_a_PC
