Time Backup Fehler !!
wolewo
24. Mrz 2009
habe mein Backup jetzt mit Time-Backup konfiguriert. Leider bricht das Backup immer ab. Aus dem Protokoll werde ich nicht schlau.
Hier mal ein Auszug aus der Logdatei. Vielleicht kann mir ja jemand weiterhelfen.
{WARN}{1375177409}{Daniel}{Task [Daniel] has failed to backup shared folder [music] due to [error occurred while copying files].}
{WARN}{1375177409}{Daniel}{Task [Daniel] has completed creating version [20130730-0747] partially.}
{INFO}{1375200008}{Daniel}{Task [Daniel] is creating backup version [20130730-1800].}
{WARN}{1375212794}{Daniel}{Task [Daniel] has failed to backup shared folder [music] due to [error occurred while copying files].}
{WARN}{1375212794}{Daniel}{Task [Daniel] has completed creating version [20130730-1800] partially.}
{INFO}{1375286403}{Daniel}{Task [Daniel] is creating backup version [20130731-1800].}
{WARN}{1375299142}{Daniel}{Task [Daniel] has failed to backup shared folder [music] due to [error occurred while copying files].}
{WARN}{1375299142}{Daniel}{Task [Daniel] has completed creating version [20130731-1800] partially.}
{INFO}{1375299142}{Daniel}{Version [20130730-1800] in task [Daniel] has been deleted by Smart Recycle.}
{INFO}{1375372809}{Daniel}{Task [Daniel] is creating backup version [20130801-1800].}
Trolli
12. Jul 2007
Schau mal über Telnet/SSH in der /var/log/messages nach, ob Du dort weitere Hinweise auf das genaue Problem findest.
wolewo
24. Mrz 2009
Das wäre so die Einträge um diese Zeit herum. Was mich erstaunt viele Error Einträge. Aber da verstehe ich nur Bahnhof.
Aug 13 16:55:17 kernel: [44690.605019] EXT4-fs error (device dm-1): ext4_lookup:1196: inode #19583: comm rsync: deleted inode referenced: 7989
Aug 13 18:00:03 timebkp: [21877]BK_ERR:try to create SSH tunnel
Aug 13 18:00:28 verbkp.cgi: CGI_ERR:SYNONetBkpRsyncExecute() error, code = [23]
Aug 13 18:00:29 kernel: [48602.043835] got iSCSI disk[0]
Aug 13 18:00:29 iscsid: connection3:0 is operational now
Aug 13 18:00:38 [INFO]: /tmp/timebkptmpexec-C7eJD8[23601]: suspending snapshot origin [/dev/mapper/vol1-origin] ...
Aug 13 18:00:38 [INFO]: /tmp/timebkptmpexec-C7eJD8[23601]: creating snapshot [/dev/md2] -> [vol1-snap1] ...
Aug 13 18:00:38 [INFO]: /tmp/timebkptmpexec-C7eJD8[23601]: resuming snapshot origin [/dev/mapper/vol1-origin] ...
Aug 13 18:00:55 [INFO]: /tmp/timebkptmpexec-P7VQMF[26183]: removeing snapshot [vol1-snap1]
Aug 13 18:00:55 [INFO]: /tmp/timebkptmpexec-P7VQMF[26183]: iscsi target [iqn.2000-01.com.synology:timebkp-target-DiskStation_001132075032-vol1-snap1'] logout
Aug 13 18:00:56 [INFO]: /tmp/timebkptmpexec-P7VQMF[26183]: removing iscsi target [iqn.2000-01.com.synology:timebkp-target-DiskStation_001132075032-vol1-snap1]
Aug 13 18:01:05 logout.cgi: login.c (936) SynoCgiLoginRemoveUser failed.
Aug 13 18:33:01 verbkp.cgi: backup_restore_progress.c:55 SLIBCFileGetSection() failed.
Aug 13 20:28:46 verbkp.cgi: [17046]BK_ERR:rsync return with error, return code = 23
Aug 13 20:29:27 kernel: [57540.552774] EXT4-fs error (device dm-1): ext4_lookup:1196: inode #14680068: comm rsync: deleted inode referenced: 7991
Aug 13 20:29:27 kernel: [57540.570116] EXT4-fs error (device dm-1): ext4_lookup:1196: inode #14680068: comm rsync: deleted inode referenced: 7990
Aug 14 00:50:32 verbkp.cgi: backup_restore_progress.c:55 SLIBCFileGetSection() failed.
Aug 14 01:13:38 verbkp.cgi: backup_restore_progress.c:55 SLIBCFileGetSection() failed.
Aug 14 01:19:58 verbkp.cgi: [17046]BK_ERR:rsync return with error, return code = 23
Trolli
12. Jul 2007
Für mich sieht das so aus, als hättest Du da Fehler auf dem Dateisystem. Ich würde diese Fehlermeldungen mal an den Support von Synology schicken.
Wenn Du Dich gut auskennst, kannst Du natürlich auch versuchen, das Volume mit fsck.ext4 selbst zu reparieren...
goetz
Super-Moderator
Teammitglied
18. Mrz 2009
EXT4-fs error
ist gar nicht gut, Filesystemfehler.
Mach mal einen erweiterten SMART-Test der betroffenen Platte.
wolewo
24. Mrz 2009
Mal eine dumme Frage.
Betrifft das die Festplatte wo das Backup drauf soll ? Oder betrifft das die Platte von der ich das Backup machen möchte?
