DS215j HDD geht seit Update nicht mehr in Hibernate
Dragonminds
05. Juli 2011
Hallo community,
ich habe 2 Stück DS215J, die ich beide am 14.09. auf Version 6.2.2-24922 Update 3 gebracht habe. Ausserdem haben ich gleich noch ein paar Pakete aktualisiert. Leider waren das an dem Tag einige.
Info System 2019-09-26 21:35:01 admin Package [Hyper Backup Vault] has been successfully updated.
Info System 2019-09-26 21:32:00 admin Package [Hyper Backup] has been successfully updated.
Info System 2019-09-14 19:33:37 admin Package [Speicher-Analysator] has been successfully updated.
Info System 2019-09-14 19:32:39 admin Package [PDF Viewer] has been successfully updated.
Info System 2019-09-14 19:31:44 admin Package [Protokoll-Center] has been successfully updated.
Info System 2019-09-14 19:31:22 admin Package [Perl] has been successfully updated.
Info System 2019-09-14 19:30:17 admin Package [Audio Station] has been successfully updated.
Info System 2019-09-14 19:28:17 admin Package [Hyper Backup Vault] has been successfully updated.
Info System 2019-09-14 19:26:58 admin Package [MariaDB 10] has been successfully updated.
Info System 2019-09-14 19:24:10 admin Package [PHP 5.6] has been successfully updated.
Info System 2019-09-14 19:23:10 admin Package [Note Station] has been successfully updated.
Info System 2019-09-14 19:20:02 admin Package [Photo Station] has been successfully updated.
Info System 2019-09-14 19:17:33 admin Package [Text-Editor] has been successfully updated.
Info System 2019-09-14 19:16:19 admin Package [Web Station] has been successfully updated.
Info System 2019-09-14 19:15:35 admin Package [Hyper Backup] has been successfully updated.
Info System 2019-09-14 18:38:43 admin Package [Surveillance Station] has been successfully updated.
Info System 2019-09-14 16:53:59 admin Package [Synology Chat Server] has been successfully updated.
Info System 2019-09-14 16:50:55 admin The app privilege on app [SYNO.SDS.Chat.Application] for group [SynologyGuests] was set to [allow] from [all IPs].
Info System 2019-09-14 16:39:20 admin Package [Synology Office] has been successfully repaired.
Info System 2019-09-14 16:30:35 admin Package [Synology Drive Server] has been successfully updated.
Beide haben 'Synology Drive' (2.0.0-11050) installiert.
A) mit aktiven Clients (Windows & Android).
B) ohne Clients - diese DS müsste überwiegend im Standby sein.
Nach einigen Tagen ist mir aufgefallen, dass beide DS nicht mehr in den Standby gingen. Also habe ich angefangen nach der Ursache zu suchen.
Im Protokollcenter ist die letzte Hibernate Meldung auch vom 14.09.2019 - quasi das letzte Mal, dass das Aufwachen der HDD protokolliert wurde. Das ist jetzt schon ~2 Wochen her. Normalerweise schlafen die beiden Boxen bei mir 2/3 des Tages. Im Hibernation.log sehe ich, dass etwa alle 21 Sekunden der Idle mode unterbrochen wird. Zu finden waren solche Einträge:
[119552.956748] jbd2/md2-8(4484): WRITE block 7801716160 on md2 (8 sectors)
[119554.809773] cloud-workerd(12781): dirtied inode 23921637 (job-db.sqlite-shm) on md2
Also dachte ich, dass dies wahrscheinlich mit 'Synology Drive' zu tun hat.
  1. Netzwerkkabel abgezogen -> Kein Hibernate
  2. Synolgogy Drive auf Android und Windows angehalten -> Kein Hibernate
  3. Synology Drive auf der DS angehalten -> Hibernate funktioniert
Hat jemand eine Idee woran das liegen kann? Auf der einen DS brauche ich das 'Synology Drive' nicht - da kann ich es ausgeschaltet lassen. Aber auf der anderen DS brauche ich es schon - ich möchte aber nicht die Festplatten den ganzen Tag laufen haben.
Es ist hier bekannt und dokumentiert, dass Drive 2.x solche Funktionen unterbindet. Ob und wann eine Verbesserung zu erwarten ist, wissen auch wir nicht. Die meisten haben sich einfach damit abgefunden, sich vom Ruhezustand zu verabschieden, da es einfach mühselig ist, alles darauf abzustimmen, damit die HDDs schlafen gehen können.
Aber es gibt einen Workaround, wenn man auf Drive nicht verzichten möchte, aber trotzdem Ruhezustand will. "killall cloud-workerd", s. hier.
Vielen Dank für eure Antworten. :)
Mir war das noch nicht bekannt, dass Drive den Ruhezustand unterbindet. Ich überfliege zwar immer mal die Change-Logs, aber das habe ich wohl übersehen oder verdrängt. Traurig, dass Synology die Hibernate Funktion bei diesem Produkt nicht beherzigt hat. :(
Danke @benares für den tipp mit dem Kill-Befehl. Ich werde mich mal damit beschäftigen. Für irgendwas muss dieser Prozess allerdings gut/wichtig sein. Mal sehen.
Ich nehme an ihr habt diesen Thread im Synology Forum dazu schon gesehen. Falls nicht, dort wird erwähnt, welches Feature das Problem verursacht, und dass der Entwickler das möglicherweise irgendwann angeht.
Danke für den Hinweis! Hat es mit dem #4 erwähnten Workaround geklappt?
Ich habe die Aufgabe wie mit dem in #4 erwähnten Workaround angelegt und ausgeführt. Der Prozess ist schon mal weg. Jetzt wird es etwas dauern, bis die Family die DS nicht mehr strapaziert (#schulferien, #allezuhause). Ich werde berichten :)
@TeXniXo: Scheint zu funktionieren. Eben waren die HDD's das erste Mal wieder am schlafen.
Der Drive Client unter Windows10 macht auch noch seine Arbeit.
Auf dem Smartphone verwende ich den Cloud Station Client um meine Fotos auf mein 'home' in Richtung DS zu sichern. Auch das funktioniert noch. Der Drive Client auf dem Windows Rechner hat einen 2 Wege Sync - u.a. für die Fotos.
Bis jetzt kann ich kein Problem feststellen.:)
Ich weiß auch nicht, was der cloud-workerd genau macht, aber ich habe festgestellt, dass der den Ruhezustand durch den ständigen Zugriff auf seine Jobs-Datenbank verhindert. Ich habe das an Synology gemeldet. Die wollten schauen, ob sie das in künftigen Versionen von Drive besser machen können. Irgendwelche Einschränkungen, wenn der nicht läuft, habe ich bislang noch nicht feststellen können.
Man muss den Kill ja auch nicht gleich automatisieren wollen, wie manche das hier versuchen. Es reicht ja, wenn man es einmalig manuell tut, wenn man seine DS oder Drive eh nicht oft startet.
Hallo Zusammen,
es gibt eine neue Version von Synology Drive Server auf https://www.synology.com/de-de/releaseNote/SynologyDrive?model=DS214play. Ich habe eine DS214play und habe die neue Version installiert. Es klappt leider immer noch nicht. Wäre auch zu schön. Kann das jemand widerlegen?
Grüße
Lightning
UPDATE 20:19 Uhr: Sobald in der Client-Liste alle Verbindungen mit dem Synology Drive Server offline sind, fährt mein NAS in den Standby Modus. Die neue Version hat somit mein Hibernation Problem gelöst.
Habe heute auch manuell das Update auf Drive 2.0.1-11061 installiert, offiziell angeboten wird es scheinbar ja noch nicht.
Disk-Hibernation scheint damit wirklich zu klappen, auch ohne den cloud-workerd zu killen. Hat mein Gemaule bei Synology wohl doch gefruchtet - freut mich.
