Sep 30 02:14:19 Medianas kernel: [ 22.426707] usb 1-1: device descriptor read/64, error -71
Sep 30 02:14:19 Medianas kernel: [ 22.776707] usb 1-1: device descriptor read/64, error -71
Sep 30 02:14:19 Medianas kernel: [ 23.286664] usb 1-1: device descriptor read/64, error -71
Sep 30 02:14:19 Medianas kernel: [ 23.636658] usb 1-1: device descriptor read/64, error -71
Sep 30 02:14:19 Medianas kernel: [ 24.386662] usb 1-1: device not accepting address 4, error -71
Sep 30 02:14:19 Medianas kernel: [ 25.016640] usb 1-1: device not accepting address 5, error -71
Sep 30 02:14:19 Medianas kernel: [ 25.022521] hub 1-0:1.0: unable to enumerate USB device on port 1
Sep 30 02:14:19 Medianas kernel: [ 26.438963] EXT3-fs (sda1): error: couldn't mount because of unsupported optional features (240)
Sep 30 02:15:33 Medianas s42_synocheckgrp: SYNOICheckLocalGrp(317): replace szBuf=[administrators:x:101:admin,aswege] with szOutBuf=[administrators:x:101:aswege,admin]!
Sep 30 02:15:33 Medianas s42_synocheckgrp: SYNOICheckLocalGrp(363): Fix Local group files.
Sep 30 02:15:34 Medianas synoplatform: system_max_align_get.c:56 failed to popen [/usr/bin/pg_controldata --dump-alignment], errno=File exists
Sep 30 02:15:36 Medianas kernel: [ 105.988308] init: syno-auth-check main process (1781) killed by TERM signal
Sep 30 02:15:42 Medianas kernel: [ 112.270740] mvCesaInit: channels=1, session=640, queue=64
Sep 30 02:15:43 Medianas kernel: [ 113.196880] encryptfs using the OCF package.
Sep 30 02:15:44 Medianas kernel: [ 114.449798] 2015-9-30 0:15:44 UTC
Sep 30 02:15:44 Medianas kernel: [ 114.457488] Brand: Synology
Sep 30 02:15:44 Medianas kernel: [ 114.460319] Model: DS-115j
Sep 30 02:15:44 Medianas kernel: [ 114.463055] This is default settings: set group disks wakeup number to 1, spinup time deno 1
Sep 30 02:15:44 Medianas synonetseqadj: conf_maxlanport_get.c:22 Failed to SLIBCFileGetKeyValue(/etc.defaults/synoinfo.conf,maxlanport)
Sep 30 02:15:45 Medianas interface-catcher: eth0 (dhcp) is added
Sep 30 02:15:45 Medianas interface-catcher: lo (inet 127.0.0.1 netmask 255.0.0.0 ) is added
Sep 30 02:15:45 Medianas kernel: [ 116.014655] pool #0: pkt_size=1536, buf_size=1632 - 2048 of 2048 buffers added
Sep 30 02:15:46 Medianas dhcp-client: started on eth0
Sep 30 02:15:47 Medianas kernel: [ 118.356517] init: dhcp-client (eth0) main process (3564) killed by TERM signal
Sep 30 02:15:48 Medianas dhcp-client: stopped on eth0
Sep 30 02:15:48 Medianas dhcp-client: started on eth0
