ich kann nicht von der 1141 auf die 1149 Updaten - bekomme immer:
Apr 6 18:44:36 update.cgi: update.cpp:741 Clean /tmp/update.progress...
Apr 6 18:44:36 update.cgi: update.cpp:743 Clean /tmp/update.message...
Apr 6 18:44:36 update.cgi: update.cpp:236 We get / to upgrade.
Apr 6 18:44:58 update.cgi: update.cpp:741 Clean /tmp/update.progress...
Apr 6 18:44:58 update.cgi: update.cpp:743 Clean /tmp/update.message...
Apr 6 18:44:58 update.cgi: update.cpp:236 We get / to upgrade.
Apr 6 18:44:58 postfix/postfix-script[27337]: fatal: the Postfix mail system is not running
Apr 6 18:44:58 dovecot: Killed with signal 15
Apr 6 18:45:00 synoaudiod: synoaudiod.cpp:502 synoaudiod exit
Apr 6 18:45:10 scheduler: scheduler.c (1607) Got signal. Die gracefully.
Apr 6 18:45:10 scheduler: scheduler.c (1625) rTorrent is killed.
Apr 6 18:45:25 scemd: scemd.c:235 stop manutild.
Apr 6 18:45:45 update.cgi: UnpackFirmware: Clean //upd@te.pat...
Apr 6 18:45:45 update.cgi: update.cpp(655): Remove //upd@te...cmd=[/bin/rm -rf //upd@te > /dev/null 2>&1]
Apr 6 18:45:45 update.cgi: update.cpp(671): Create //upd@te...cmd=[/bin/mkdir -p //upd@te > /dev/null 2>&1]
Apr 6 18:45:45 update.cgi: update.cpp(627): Untar //upd@te.pat...cmd=[/bin/tar xpf "//upd@te.pat" -C //upd@te > /dev/null 2>&1]
Apr 6 18:45:46 update.cgi: update.cpp
630) : failed to system cmd=[/bin/tar xpf "//upd@te.pat" -C //upd@te > /dev/null 2>&1], r=256
Apr 6 18:45:46 update.cgi: update.cpp(655): Remove //upd@te...cmd=[/bin/rm -rf //upd@te > /dev/null 2>&1]
Apr 6 18:45:51 synorcd: hw_raytac.c (126) failed to open /dev/usb/hiddev5 (No such device).
Apr 6 18:45:53 scheduler: scheduler.c (1491) Failed to malloc(-118)
Apr 6 18:45:55 update.cgi: update.cpp:532 Update Errno = 13[Error No:13]
Die Datei habe ich schon 3 Mail neu runter geladen. :-(
Jemand eine Idee?
Gruß, Alex
