DSM 6.x und darunter Dsm 6.2.2-24922
maulsim
24. Mai 2016
DSM 6.2.2 ist heute (28.03.2019) erschienen
Important Note
  1. The update is expected to be available for all regions within the next few weeks, although the time of release in each region may vary slightly.
  2. This update will restart your Synology NAS.
  3. sMedio DTCP Move will not be supported on DSM 6.2.2.
  4. If MariaDB 5 is not installed and the built-in MySQL port is selected for a firewall rule, users will have to enable the option again.
What's New in DSM 6.2.2
  1. Added the new Smart Update function and adjusted the update mechanism of DSM.
  2. IHM now supports 14TB IronWolf and IronWolf Pro drives.
  3. Added firmware update function of SAS controller on certain SAS models.
  4. Added knowledge base article recommendations in the Support Center to help users with easy troubleshooting.
  5. Domain users can now change their passwords upon DSM login when their passwords expire.
  6. Added support for Integrated Windows Authentication.
  7. Added support for Google LDAP services.
  8. Added the new Low-Capacity Write function, which resumes LUNs from read-only status temporarily when a volume is running out of space.
  9. Users can now select which advanced features to enable during iSCSI LUN creation.
  10. Adjusted the warning mechanism in iSCSI Manager for insufficient volume space.
  11. Users can now set up trigger time for snapshot retention policies in iSCSI Manager.
  12. Users can now configure date and time formats in their personal account settings.
  13. Supports SSD compatibility check on XS and FS series models.
  14. Adjusted the notification mechanism for bad sectors.
  15. Improved the calculating accuracy of SSD cache hit rate.
  16. Users can now get a Let's Encrypt certificate automatically upon adding a new Synology DDNS.
  17. Changed notification badges from numbers to red dots and modified display rules.
Fixed Issues
  1. Fixed an issue where usage history may not show in Resource Monitor on certain models.
  2. Fixed an issue where files cannot be re-uploaded after being deleted on macOS 10.13.
  3. Fixed an issue where encrypted Excel files cannot be opened in Microsoft Office 2016 simultaneously on multiple macOS devices.
  4. Shortened the time needed when domain or LDAP users log in to DSM via AFP.
  5. Improved the stability of mounting exFAT external devices (exFAT package required).
  6. Improved the stability of NFS protocol connection.
  7. Improved the stability of Snapshot Replication when moving a large number of directories.
  8. Enhanced the stability of Btrfs file system under certain high I/O loading conditions.
  9. Improved Spectre and Meltdown protection, which may affect system performance.
  10. Fixed multiple security vulnerabilities regarding Linux kernel (CVE-2017-13168, CVE-2018-19824, CVE-2017-15649, CVE-2018-14634, CVE-2018-17182, CVE-2018-10853).
  11. Fixed multiple security vulnerabilities regarding OpenSSL (CVE-2018-0732, CVE-2018-0737, CVE-2019-1559, CVE-2018-0734, CVE-2018-5407).
  12. Fixed multiple security vulnerabilities regarding Spectre & Meltdown (Synology-SA-18:01).
  13. Fixed multiple security vulnerabilities regarding OpenSSH (CVE-2019-6109, CVE-2019-6110, CVE-2019-6111, CVE-2018-20685).
  14. Fixed a security vulnerability regarding SQLite (Synology-SA-18:61).
  15. Fixed multiple security vulnerabilities regarding Samba (Synology-SA-18:47, Synology-SA-18:60).
  16. Minor bug fixes.
blinddark
03. Jan 2013
blinddark
03. Jan 2013
Die Installation auf meiner DS918+ lief erfolgreich durch und auf den ersten Blick läuft alles inkl. Plex und der Nextcloud Installation.
AndiHeitzer
30. Jun 2015
Auf allen Kisten erfolgreich aufgebracht.
OAUTH war vorher bei mir drauf, aber gestoppt.
Nach dem Upgrade war der OAUTH wieder gestartet. Mal sehen, ich habe den wieder gestoppt.
3615
17. Aug 2016
Write Cache auf IronWolfs 10TB nach wie vor deaktiviert :mad:
WOL mit Intel X550-T2 nach wie vor nicht aktivierbar.
ruedi66
25. Apr 2018
Das Cache Problem liegt am Kernel, das ist nicht so einfach gefixt im alten 3.10er Kernel
Archi_74
07. Feb 2012
Die Cache-Problematik ist leider immer noch ein großes Ärgernis! Ich hoffe immer noch auf Besserung!
OAuth wurde auf allen meinen Synos mit dem Update automatisch installiert. Wurde von mir gleich wieder runtergeschmissen.
3615
17. Aug 2016
In Anbetracht der Tatsache, dass Linux Kernelversion 4.2.10 aktuell ist ...
DanFu
13. Mrz 2016
DS215j & DS718+ läuft ohne Probleme
weyon
17. Apr 2017
Bei Ironwolf 12Tb ist Cache jetzt aktiviert. Bei den 10 tb hat Synology ja gesagt das bei diesen Cache noch nicht aktiviert werden kann, trotz 6.2.2.
Iarn
16. Jun 2012
Was ist an Kernel 4.2.10 aktuell? Evtl meinst Du 4.20?
Aktuell sind 4.19 für LTS und 5.0 ohne LTS.
Gut verglichen mit dem obsoleten, nicht mehr gepflegten 3.10 sind das alles neue Kernel.
3615
17. Aug 2016
Um genau zu sein meinte ich 4.20.08.
Wo und wann hat Synology es kommuniziert?
BigRonin
08. Mai 2015
Kann jemand sagen ob das ausschaltbar ist?
blinddark
03. Jan 2013
ja ich denke unter System und Sicherheit.
Kurt-oe1kyw
10. Mai 2015
DS 218+ und DS916+ durch manuelle Updates auf DSM 6.2.2-24922 aktualisiert. Die DSen wurden dabei automatisch heruntergefahren und neu gestartet.
Ein SMART Schnelltest wurde autom eingerichtet, wer dies nicht möchte, dann im Speichermanager > HDD/SSD den SMART Schnelltest wieder abschalten durch Haken entfernen oder Zeile markieren und gleich Löschen.
Die SMART Werte sind jetzt unter SMART Attribute zu finden! Runterscrollen und auf SMART Attribute klicken, leider lässt sich das Anzeigefenster derzeit nicht größer ziehen! Für einen vollständige Ansicht muss also in dem vorhandenen fixen Fenster gescrollt werden um alle Einträge in der Tabelle zu sehen!
Es gibt jetzt ein "intelligentes Updates", keine Ahnung ob die bisherigen "unintelligent" waren...... :)
Jedenfalls werden dadurch ab sofort nur mehr jene Updates angezeigt welches für dein Modell, bzw. deine installierten Programmpakete relevant sind.
Am Desktop bei den Benachrichtigungen ist bei uns jetzt nur mehr ein roter Kreis zu sehen, früher war da auch noch eine weise Zahl darin, da konnte man sofort sehen wieviel neue Benachrichtigungen hinzugekommen sind.
Bei uns ist jedenfalls derzeit nur der rote Punkt da, ohne Angabe wieviele Nachrichten neu sind.
Automatisch mit dem DSM Update wurden auch Updates bei uns durchgeführt bei folgenden Programmpaketen:
File Station, OAuth Service und Universal Search
Die Haken blieben diesmal unangetastet bei DSM > Hauptmenü > Systemsteuerung > Dateidienste > Register "Erweitert" ----> SSDP und WS-Discovery haben beide Haken behalten. In der Vergangenheit wurden bei manchen Updates die Haken entfernt.
Die Funktion "find.synology.com" wurde nun umbenannt und wird als "Netzwerkstandort mitteilen >> Web Assistant aktivieren angezeigt. Früher stand da "Wollen sie find.synology.com" aktivieren und der Haken wurde gesetzt.
Zu finden in DSM > Hauptmenü > Systemsteuerung > Info-Center > Register "Geräteanalyse" > unten den Haken setzen bei Nerzwerkstandort ermitteln auf "Web Assistant aktivieren".
Ansonsten läuft es bisher ohne Probleme bei uns.
AvrLogger läuft ebenfalls problemlos hier bei uns weiter nach dem DSM Update.
Bei der USV Anlage gibt es jetzt nur mehr die Option "Netzwerk-USV-Server aktivieren", wenn hier der Haken gesetzt wurde, dann kann eine an diese DS angeschlossene USV Anlage via USB die USV Meldungen auch an andere DSen im Netzwerk übertragen. Früher mussten hier die IP Nummern eingetragen werden, bis zu 5 Stück waren möglich.
Die Einstellung der "berechtigten" DS für den USV Betrieb gibt es nicht mehr, nur mehr generell den USV Server zu aktivierne, auf der Ziel DS hat sich hingegen nichts geändert. Wenn di Funktion "USV" aktiviert ist, muss hier auch die IP der Quell-DS (also jene wo die USV mit USB verbunden ist) eingetragen sein!
Hinweis:
Die .pat Dateien für das manuelle DSM Update für euer DS Modell bitte von hier auswählen > DSM 6.2.2_24922 <klick>
vbtobi
02. Nov 2015
Bei mir geht der Nut Client im iobroker nicht mehr. Dort heißt es nur "ACCESS-DENIED" wenn ich auf die USV-Daten des Servers zugreifen möchte.
meagain
29. Dez 2012
Zum Thema Linux Kernel. Bei mir meldet uname -r 4.4.59+
Das würde mich auch interessieren, denn mir wurde vom Synology Support mitgeteilt, dass das Problem mit dem nächsten 6.2 Release behoben sein sollte (OK Konjunktiv, aber die Antwort ist grade mal einen Monat alt...)
After checking with our back-end engineer, the reason we systematically turned off the write cache of this Seagate HDD model: ST10000VN0004-2GS11L is as below:
1. RAID1 resync speed would be affected is the Linux kernel version is 4.4.x
2. HDD's own behavior.
Our developers had acknowledged this issue and working on it so they turn off the write cache of this HDD. This issue is also informed to Seagate and should be fixed in the next released DSM version 6.2.
If you would like to enable it, please help to provide the remote access to us and we can manually enable it for you.
Ja, hier auch. Dennoch musste ich WS-Discovery vorübergehend deaktivieren damit die DS218j wieder unter andere Computer in der Netzwerkumgebung von Win7 auftauchte.
Diablos
17. Dez 2014
kann ich nicht bestätigen
