docker restart container NAME_DES_CONTAINERS
/usr/syno/bin/synowebapi --exec api=SYNO.Docker.Container method=restart version=1 name="NAME_DES_CONTAINERS"
Traceback (most recent call last):
File "/opt/local/bin/rsscrawler", line 7, in <module>
from rsscrawler.RSScrawler import main
File "/opt/local/lib/python3.7/site-packages/rsscrawler/RSScrawler.py", line 46, in <module>
from rsscrawler import common
File "/opt/local/lib/python3.7/site-packages/rsscrawler/common.py", line 16, in <module>
from rsscrawler import myjdapi
File "/opt/local/lib/python3.7/site-packages/rsscrawler/myjdapi.py", line 42, in <module>
from Crypto.Cipher import AES
File "/opt/local/lib/python3.7/site-packages/Crypto/Cipher/__init__.py", line 27, in <module>
from Crypto.Cipher._mode_ecb import _create_ecb_cipher
File "/opt/local/lib/python3.7/site-packages/Crypto/Cipher/_mode_ecb.py", line 47, in <module>
File "/opt/local/lib/python3.7/site-packages/Crypto/Util/_raw_api.py", line 299, in load_pycryptodome_raw_lib
raise OSError("Cannot load native module '%s': %s" % (name, ", ".join(attempts)))
OSError: Cannot load native module 'Crypto.Cipher._raw_ecb': Trying '_raw_ecb.cpython-37m.so': /opt/local/lib/python3.7/site-packages/Crypto/Util/../Cipher/_raw_ecb.cpython-37m.so: cannot open shared object file: No such file or directory, Trying '_raw_ecb.abi3.so': /opt/local/lib/python3.7/site-packages/Crypto/Util/../Cipher/_raw_ecb.abi3.so: cannot open shared object file: No such file or directory, Trying '_raw_ecb.so': /opt/local/lib/python3.7/site-packages/Crypto/Util/../Cipher/_raw_ecb.so: cannot open shared object file: No such file or directory
Package Version
altgraph 0.16.1
beautifulsoup4 4.6.3
bs4 0.0.1
certifi 2018.11.29
cfscrape 1.9.5
chardet 3.0.4
Click 7.0
docopt 0.6.2
feedparser 5.2.1
Flask 1.0.2
future 0.17.1
fuzzywuzzy 0.17.0
gevent 1.3.7
greenlet 0.4.15
idna 2.7
itsdangerous 1.1.0
Jinja2 2.10
lxml 4.2.5
macholib 1.11
MarkupSafe 1.1.0
pefile 2018.8.8
pip 18.1
pycryptodome 3.7.2
PyInstaller 3.4
PySocks 1.6.8
python-dateutil 2.7.5
requests 2.20.1
rsscrawler 5.3.3
setuptools 40.6.2
six 1.11.0
urllib3 1.24.1
Werkzeug 0.14.1
wheel 0.32.3
Warum Kommandozeile ?
Machs doch über die Docker GUI im DSM, dann gehts out of the Box!
Collecting pycryptodome
Using cached https://files.pythonhosted.org/pack...2e49d4073daae952247/pycryptodome-3.8.1.tar.gz
Building wheels for collected packages: pycryptodome
Building wheel for pycryptodome (setup.py) ... error
ERROR: Complete output from command /bin/python -u -c 'import setuptools, tokenize;__file__='"'"'/tmp/pip-install-VhcOhA/pycryptodome/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' bdist_wheel -d /tmp/pip-wheel-cRjjCK --python-tag cp27:
ERROR: Testing support for clang
Target does not support clang
Testing support for gcc
Target does not support gcc
Testing support for stdint.h header
Target does not support stdint.h header
Testing support for 128-bit integer
Target does not support 128-bit integer
Testing support for intrin.h header
Target does not support intrin.h header
Testing support for cpuid.h header
Target does not support cpuid.h header
Testing support for posix_memalign
Target does not support posix_memalign
Testing support for memalign
Target does not support memalign
Warning: compiler does not support AESNI instructions
Warning: compiler does not support CLMUL instructions
running bdist_wheel
running build
running build_py
creating build/lib.linux-aarch64-2.7
creating build/lib.linux-aarch64-2.7/Crypto
copying lib/Crypto/__init__.py -> build/lib.linux-aarch64-2.7/Crypto
creating build/lib.linux-aarch64-2.7/Crypto/Cipher
copying lib/Crypto/Cipher/DES3.py -> build/lib.linux-aarch64-2.7/Crypto/Cipher
copying lib/Crypto/Cipher/__init__.py -> build/lib.linux-aarch64-2.7/Crypto/Cipher
copying lib/Crypto/Cipher/PKCS1_OAEP.py -> build/lib.linux-aarch64-2.7/Crypto/Cipher
copying lib/Crypto/Cipher/Blowfish.py -> build/lib.linux-aarch64-2.7/Crypto/Cipher
copying lib/Crypto/Cipher/_mode_openpgp.py -> build/lib.linux-aarch64-2.7/Crypto/Cipher
copying lib/Crypto/Cipher/CAST.py -> build/lib.linux-aarch64-2.7/Crypto/Cipher
copying lib/Crypto/Cipher/_mode_eax.py -> build/lib.linux-aarch64-2.7/Crypto/Cipher
copying lib/Crypto/Cipher/PKCS1_v1_5.py -> build/lib.linux-aarch64-2.7/Crypto/Cipher
copying lib/Crypto/Cipher/ARC2.py -> build/lib.linux-aarch64-2.7/Crypto/Cipher
copying lib/Crypto/Cipher/DES.py -> build/lib.linux-aarch64-2.7/Crypto/Cipher
copying lib/Crypto/Cipher/_mode_cbc.py -> build/lib.linux-aarch64-2.7/Crypto/Cipher
copying lib/Crypto/Cipher/_mode_ofb.py -> build/lib.linux-aarch64-2.7/Crypto/Cipher
copying lib/Crypto/Cipher/_mode_cfb.py -> build/lib.linux-aarch64-2.7/Crypto/Cipher
running build_ext
building 'Crypto.Hash._MD2' extension
creating build/temp.linux-aarch64-2.7
creating build/temp.linux-aarch64-2.7/src
/usr/local/aarch64-unknown-linux-gnueabi/bin/aarch64-unknown-linux-gnueabi-ccache-gcc -fno-strict-aliasing -DSYNOPLAT_F_ARMV8 -O2 -include /usr/syno/include/platformconfig.h -DSYNO_ENVIRONMENT -DBUILD_ARCH=64 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DSYNO_RUNNING_DSM_BUILD_SYSTEM -g -pipe -fstack-protector --param=ssp-buffer-size=4 -Wformat -Wformat-security -D_FORTIFY_SOURCE=2 -O2 -Wno-unused-result -DOPENSSL_NO_SSL3 -I/usr/local/aarch64-unknown-linux-gnueabi/aarch64-unknown-linux-gnueabi/sysroot//usr/lib/libffi-3.2.1/include -DNDEBUG -g -fwrapv -O3 -Wall -Wstrict-prototypes -fPIC -DPYCRYPTO_LITTLE_ENDIAN -DSYS_BITS=64 -DLTC_NO_ASM -Isrc/ -I/usr/include/python2.7 -c src/MD2.c -o build/temp.linux-aarch64-2.7/src/MD2.o
unable to execute '/usr/local/aarch64-unknown-linux-gnueabi/bin/aarch64-unknown-linux-gnueabi-ccache-gcc': No such file or directory
error: command '/usr/local/aarch64-unknown-linux-gnueabi/bin/aarch64-unknown-linux-gnueabi-ccache-gcc' failed with exit status 1
ERROR: Failed building wheel for pycryptodome
Running setup.py clean for pycryptodome
Failed to build pycryptodome
Installing collected packages: pycryptodome
Running setup.py install for pycryptodome ... error
ERROR: Complete output from command /bin/python -u -c 'import setuptools, tokenize;__file__='"'"'/tmp/pip-install-VhcOhA/pycryptodome/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-M2nqdB/install-record.txt --single-version-externally-managed --compile:
running install
running build
running build_py
copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/ecc_p256_public.pem -> build/lib.linux-aarch64-2.7/Crypto/SelfTest/PublicKey/test_vectors/ECC
copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/ecc_p521_private.pem -> build/lib.linux-aarch64-2.7/Crypto/SelfTest/PublicKey/test_vectors/ECC
copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/ecc_p256_private_p8_clear.der -> build/lib.linux-aarch64-2.7/Crypto/SelfTest/PublicKey/test_vectors/ECC
copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/ecc_p384_private.pem -> build/lib.linux-aarch64-2.7/Crypto/SelfTest/PublicKey/test_vectors/ECC
copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/ecc_p256_public_compressed.pem -> build/lib.linux-aarch64-2.7/Crypto/SelfTest/PublicKey/test_vectors/ECC
copying lib/Crypto/SelfTest/Signature/test_vectors/wycheproof/rsa_signature_2048_sha512_test.json -> build/lib.linux-aarch64-2.7/Crypto/SelfTest/Signature/test_vectors/wycheproof
copying lib/Crypto/SelfTest/Signature/test_vectors/wycheproof/rsa_signature_3072_sha512_test.json -> build/lib.linux-aarch64-2.7/Crypto/SelfTest/Signature/test_vectors/wycheproof
running build_ext
ERROR: Command "/bin/python -u -c 'import setuptools, tokenize;__file__='"'"'/tmp/pip-install-VhcOhA/pycryptodome/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-M2nqdB/install-record.txt --single-version-externally-managed --compile" failed with error code 1 in /tmp/pip-install-VhcOhA/pycryptodome/
