Hab mich genau an die Anleitung von Seite 37 gehalten. Vorhergehende Versionen haben auch tadellos funktioniert.
Eben gerade nochmal probiert:
- deinstalliert
- neustart
- manuelle Installation der SPK
Ergebnis: Gleiche Fehlermeldung wie Sunshine1907
Exception Object
[message:protected] => Could not connect to host (http://127.0.0.1:18083/)
[string:Exception:private] =>
[code:protected] => 64
[file:protected] => /volume1/web/phpvirtualbox/endpoints/api.php
[line:protected] => 134
[trace:Exception:private] => Array
[previous:Exception:private] =>
root@Diskstation:/var/packages/virtualbox/scripts# ./start-stop-status start
Starting VirtualBox kernel modules ...done.
Starting VirtualBox web service/opt/VirtualBox/VBoxManage: /lib/libstdc++.so.6: no version information available (required by /opt/VirtualBox/VBoxManage)
/opt/VirtualBox/VBoxManage: /lib/libstdc++.so.6: no version information availabl e (required by /opt/VirtualBox/VBoxManage)
/opt/VirtualBox/VBoxManage: /lib/libstdc++.so.6: no version information availabl e (required by /opt/VirtualBox/VBoxDDU.so)
/opt/VirtualBox/VBoxManage: /lib/libstdc++.so.6: no version information availabl e (required by /opt/VirtualBox/VBoxRT.so)
/opt/VirtualBox/VBoxManage: /lib/libstdc++.so.6: no version information availabl e (required by /opt/VirtualBox/VBoxXPCOM.so)
VBoxManage: error: Failed to create the VirtualBox object!
VBoxManage: error: Code NS_ERROR_ABORT (0x80004004) - Operation aborted (extende d info not available)
VBoxManage: error: Most likely, the VirtualBox COM server is not running or fail ed to start.
...fail!
Error 0 setting webservice authentication library to null
...fail!
VBoxManage: error: Code NS_ERROR_ABORT (0x80004004) - Operation aborted (extended info not available)
VBoxManage: error: Most likely, the VirtualBox COM server is not running or failed to start.
eventuell mal den Benutzer admin aktivieren? Ich hatte dies vor kurzem auch mit dem neuen Paket. Habe darauf hin alle Einstellungen in der Web Station auf Standard gesetzt (nginx, PHP 5.6, SOAP dekativiert etc.) sodass der Webserver neu gestartet wurde. Danach sicherheitshalber nochmal die DS neu gestartet. Anschließend alles wieder auf "VB-Einstellungen" gebügelt (Apache 2.2 Server, PHP 5.6, SOAP-Extension an, etc.) und wieder neu gestartet. Danach gings. Versuch ansonsten auch mal die Firewall auszuschalten. Die hab meine Virtual Box auch bereits diverse Male blockiert, bis ich den richtigen Port freigeschaltet hatte.
Egal was man umstellt, die Fehlermeldung bleibt die Gleiche "Could not connect to host (http://127.0.0.1:18083/)"
Schade...
Ich wollte gerade ein Update fahren was mit automatisch angeboten wurde: das Paket verlangt jetzt FEST den Pfad /volume1/VirtualBoxVMs. Sonst bricht das Update ab.
Wieso? Bisher lief es bei mir mit /volume1/vm super.
DU redest von Installation, ICH von Update.Man muss ein existierendes Verzeichnis angeben. Ich habe bei der Installation die Angabe von /volume1/VirtualBoxVMs in /volume1/VirtualBox VMs geändert.
Das ist nicht ganz richtig:Hallo Homersnr1, soweit ich weiß läuft mit dieser Version win10 nicht, zumindest lässt es sich nicht instalieren.
