I have check it with Outlook 2013 and it's working fine.
Hi do you know if Outlook can work with ActiveSync after this update to Z-Push_2.2.4 ? In release note for 2.2.2 ver there is information ZP-604 is this mean that should work ? and I assume also in 2.2.4 as it is next version
Changes since Z-Push 2.2.1
General
[ZP-451] - Mobile sending a folder type receives wrong ping information.
[ZP-544] - Not compatible with Cyanogenmod 11.
[ZP-558] - Enhance error message for folder resync.
[ZP-563] - z-push-admin ignores -u when -d is given.
[ZP-572] - Increase default SYNC_CONTACTS_MAXPICTURESIZE.
[ZP-604] - Allow OL connections via ActiveSync.
[ZP-606] - Warnings in appointment sync.
[ZP-608] - Write binary logs.
[ZP-611] - Set folder display name to "unknown" if the name is not available.
[ZP-623] - Resync folder if ICS exports <Remove> requests for more than 1000 items of a folder.
[ZP-631] - Disable checking of notifications validity in Ping.
