DSM 6.x und darunter Dsm 5.2-5592
Cyborg70
18. Juni 2015
Hi zusammen,
meine DS 1813+ bietet mir ein Update auf 5.2-5592 an. In den Release Notes wird aber nur die 5.2-5565 Update 2 als letztes angezeigt. Auch habe ich bisher noch nichts darüber gefunden...
Da ich immer noch Probleme mit Abstürzen und nicht Verfügbarkeit habe wäre ich über jedes Update dankbar. Gibts dazu irgendwelche aktuellen Release Notes?
Version : 5.2-5592
(2015/07/01)
What's New
This update includes all bug fixes as well as security fixes in the previously released critical updates since DSM 5.2-5565.
Fixed Issues
Improved the stability of Synology High Availability system when excessive numbers of volumes are created on passive servers.
Improved the compatibility of network printers.
Upgraded Samba to 4.1.18 for issue fixes and stability enhancements.
Improved the stability when expanding volumes on RAID 5 or 6.
Improved the performance of Synology High Availability with SSD cache enabled.
Improved the USB storage compatibility on DS215j.
Upgraded PHP to 5.526 to address multiple security vulnerabilities (CVE-2015-3414, CVE-2015-3415, CVE-2015-3416, CVE-2015-2325, CVE-2015-2326, and CVE-2015-4598).
Upgraded OpenSSL to 1.0.1o to address multiple security vulnerabilities (CVE-2015-4000, CVE-2015-1788, CVE-2015-1789, CVE-2015-1790, CVE-2015-1791, and CVE-2015-1792).
Security enhancements on Personal Web Station.
Fixed a security vulnerability to prevent cross-site scripting (XSS) attacks.
Fixed an issue where system would reboot while disabling a connected iSCSI target with the Multiple Connection Session setting enabled.
Fixed an issue where High Availability Manager would fail to switch over after repairing read-write caches.
Fixed multiple issues with UPS settings.
Fixed multiple issues with Port Forwarding settings.
Minor bug fixes.
Mittlerweile wurde das aktualsisert ;-)
Super, Dankeschön.
Dann hoffe ich mal, dass entweder das Samba upgrade oder die Minor Bugfixes meine Probleme lösen.
Man sah es schon kommen mit dem Zeitstempel auf den Servern... :) - aber leider wieder ohne Apache-Aktualisierung auf einen neueren Stand :(
So, Update auf meiner DS1815+ ist durch.
Soweit sieht alles gut aus ;-)
Den Rest wird die Zeit zeigen.
Viele Grüße Olli
Interessant zu wissen wäre, ob die Diskstation nach diesem Update den Ruhezustand noch beherrscht, also Festplatten aus und so weiter.
Update1: Habe gerade meine DS215J mit dem Update versorgt und siehe da ... sie schläft gerade. Also es scheint als ob der Ruhezustand noch funktioniert. Das ist doch schon mal toll.
Selbst ausprobieren und berichten, sonst warten bis es die anderen tun :0)
Update auf der DS 212+ gemacht. DS1512+ warte ich noch ab.
Gruss Mike
Update auf meiner DS415play gemacht. Seit dem gibt es beim Hochfahren wieder eine Meldung/Mail, dass das Gerät mit einer USV verbunden wurde.
Na toll, wieder verschlimmbessert. Hatte mit dem vorigen Update keine Probleme mehr :mad:
Irgendwie verstehe ich das Problem nicht ganz. Ich habe auch früher schon (vor DSM 5.1) eine Meldung beim Hochfahren bekommen, dass die DS mit der USV verbunden wurde.
Fand ich immer ganz sexy...
Was ist daran schlimm?
Wenn dich die Meldung stört, kannst du sie sicher auch bei den zu meldenden Ereignissen gänzlich abschalten.
Bug, Feature...wie auch immer. Aber entscheiden sollten sich die Jungs bei Synology mal.
Es ging doch eher früher um das Problem, dass diese Meldung im Betrieb laufend unmotiviert kam (An- und Abmeldungen)... Beim Start ist das für mich völlig iO.
So wie es aussieht werden nach dem Update alle Medien neu indiziert. Das heißt meine mühevoll korrigierten Metadaten der Video Station sind wahrscheinlich wieder alle im Eimer :mad:.
Vermutungen bringen doch nichts - warte und berichte, wenn Du Klarheit hast.
Kann ich nicht bestätigen. Alles beim Alten. 713+/212j
Wenigstens werden die Protokolle im Widget wieder aktualisiert dargestellt.
Zusammen mit dem DSM-Update gibt's ja dann auch wieder zahlreiche Paketupdates (DNS-Server, CardDAV, usw.) - obwohl bei allen in den Release Notes steht, dass Installationsvoraussetzung DSM-5.0 sei, demzufolge sie mir auch im Paketcenter angeboten werden, obwohl bei meiner 713+ noch DSM 5.1-5055 läuft, lassen sich allesamt diese Pakete dort nicht installieren. Abbruch mit dem Hinweis, es sei mindestens DSM-5.2-5565 erforderlich.
Also wieder einmal ein Kuddelmuddel der Abhängigkeiten... und schade, dass - da die Paketupdates mit allerlei Sicherheitsbugfixes einhergehen - beim Benutzer der Druck aufgebaut wird, auf die 5.2 zu aktualisieren.
EDIT
Auf meiner DS111 lief soweit nach dem Update alles recht ordentlich, Probleme habe ich bisher nicht ausmachen können.
Das Update einer DS1515+ ist soweit normal durchgelaufen. Eine Neuindizierung der Medien konnte ich ebenfalls nicht beobachten.
Update lief eben fix auf meiner DS214+ durch. Bisher wurden mir keine Paket-Updates angezeigt.
Hab meine beiden heute auch aktualisiert. Die meisten Anpassungen in /etc/profile, ~/.profile musste ich neu eingeben.
Update ist sauber durchgelaufen...
Pakete wurden auch aktualisiert... bis jetzt keine besonderen Vorkommnisse festgestellt...
